Question about Gateway 7330GZ Notebook
I have gateway 7330gz I can not open back (for cleaning)
I take of all secrw but I can not take part it mowes but it can not able to open
  • ocean_27 Feb 23, 2009
    I need to
    replace my power button but I cannot take the top piece off. I took ALL of the
    screws out but it only separates on one side. It will not completely unatach
    and I am afraid of breaking something if I try and force it. If there are any
    know solutions please post.
Put all the screws back in except for two... on the bottom of the case the one directly above the "ew" in Gateway 7330 and the screw that is about 3 inches to the left of that sticker.. For further clarification, but not at the outside corners they're both near the back of the computer.
After those are removed, open the laptop with the screen completely open so the computer almost lays flat. Use a precision awl or flathead screw driver to pry up the strip at the top where your power and sound buttons are... I had the best luck prying it up from the left. Be careful about the ribbon cable that is under the buttons that goes to the motherboard... if detached it is difficult to reattach.
From there it should be pretty easy to see the 2 screws for the keyboard and then 4 screws on a metal plate which once removed will give you access to most of the motherboard.
Posted on Mar 16, 2009
The momentary switch on my Gateway 7330GZ laptop is defective. If I can slide it to the proper location, it will work. How do I remove the display portion to access the screws to remove the top panel and...
Here is a video on how to open the monitor on a Gateway notebook, although if the switch isn't working anymore I assume there is a part of it broken inside and you might need a replacement.
Dec 07, 2010 | Gateway 7330GZ Notebook
Gateway 7330gz Laptop Won't Charge
Could be your connection inside the laptop itself.
They tend to go easily in gateways.
The wear and tear from plugging it in and out.
Cost approximately $70.00 - $100.00 to repair.
Can usually get the best price at a small computer repair store
Jan 12, 2009 | Gateway 7330GZ Notebook
Power jack repalcement Gateway 7330GZ Notebook
you have options....#1 send it out to gateway for an arm and a leg...(i have the same model and had the same problem), #2 find a local computer repair store...they will most likely charge about 30 for the part.(that's what i was charged + 60 an hour for labor took 2 hours...) or #3 do it yourself, if you can solder then i can talk you through most of the dis assembly..plus you can get the part remarkably cheaper
Nov 08, 2008 | Gateway 7330GZ Notebook
MY GATEWAY LAPTOP SCREEN WENT BLACK AFTER 20 MIN OR MORE
Look for cracks in the hinges. It is a big problem with the Gateway 7330GZ.
Sep 30, 2008 | Gateway 7330GZ Notebook
Numbers and backspace on Gateway 7330GZ not working
You might check and clean the keyboard connection to the motherboard. However, usually this indicates keyboard failure. It's most likely that you're have to replace the keyboard.
Aug 21, 2008 | Gateway 7330GZ Notebook
Gateway 7330GZ PC Notebook screen going off and on
Ya, my 7330GZ has been having this problem. I did end up taking the screen apart.
Removing the little black nubs around the screen allow you to remove the screws, then you just use a flat headed screw driver to unclip around the edges (some can be stubborn, especially along the bottom).
The screen is glued to the casing along the top and bottom, so you have to gently separate the two.
After you have it opened up the screen has 3-4 screws along the left and right side (the right side is a pain to unscrew since the wireless antenna casing runs right along it).
Once you remove those screws you can take the screen out and get access to the ribbon cable running along the back.
Aug 11, 2008 | Gateway 7330GZ Notebook
Screen problems
Try the power save options.
Nov 13, 2007 | Gateway 7330GZ Notebook
Gateway 7330GZ Notebook Logo
622 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
