Question about HP Officejet 4315 All-in-One Printer
Won't copy or fax, scanner failure
All of a sudden, I cannot copy or fax anything. The printer works fine and I recieve faxes no problem, but when I insert anything into the loader to either copy or fax and hit start, the machine just says " scanner failure, unable to scan, copy or fax, press OK." When I press OK it just says copying but does nothing. When I hit cancel, it says copy cancelled, the exclamation mark light blinks, and that is it. I have to turn the unit off to reset it.
  • soundconcept Feb 17, 2009
    Any way to get rid of the scanner? I never use it.
  • 2,120 Answers
Uneconomical to replace the scanner assy. sorry
Posted on Feb 17, 2009
When we send fax or copy it comes out black , can recieve faxes and print off fine .? hplaser jet 3050
Scanner's lamp damage
Try to open the lid on where we copy sheets of this paper hold down the sensor and press the copy button, see if the scanner lamp light, lamp power can be interrupted
Oct 27, 2009 | HP LaserJet 3050 All-In-One Printer
Copying problems
You must change the power supply
Apr 03, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Hp 6210 won't print or read anything that goes through top feeder
The scanner unit is not coming to the home position for the ADF, you can't get individual parts.
Mar 05, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scanner failure when faxing of coppying
I need help also my black ink stop working also but think it is dry and that is why it won't wor. but still have same fax and copy problem exactly even the grinding noise
Feb 09, 2009 | HP OfficeJet 7410 All-In-One InkJet...
HP 5510 Scanner/Copier/Fax Stuck
I had the same problems some months ago. I only solved it when I deleted the printer settings from my computer and reinstalled the software, making sure that I installed all the components from the CD. Also make sure that the printer is on fax default setting when you are using it as fax. You can check this by going to My Computer then Control Panel, then choose Printers and Other Hardware then choose Printers and Faxes. You can then set as default hp Officejet 5500 series fax. Hope these suggestions help.
Jan 08, 2009 | HP Officejet 5510 All-In-One Thermal...
HP C6180 prints but won't copy or fax...
i can not recieve faxes. It use to work fine. I can send them out, but not receive.
Jan 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Brother intellifax 4750e
if the copy comes out black and/or sends black the Contact Image Sensor in the scanner may be needed.
Hope that helps...
Jun 17, 2008 | Brother IntelliFAX 4750 Plain Paper Laser...
OfficeJet 7310 FAX issue
Did anything happen prior to the issue? It almost sounds as if the DC controller (main board) has gone bad. What happens if you try to make a copy on it?
May 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
559 people viewed this question
Ben Johnson
