Question about Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Electric Dryer
My dryer is now two years old and I have noticed the last couple of weeks that my clothes are still sorta damp after it has ran its fiull cycle and I have to add additional time to dry. I have made sure the vent is cleaned, I washed the lent tray. What could be causing this
  • bjquinn927 Feb 17, 2009
    The washer is spinning the clothes out very well and the vent leading out the house is in great condition and the air flow out of the new damper flap is very strong. Could the heating element in this be going out?
    When you say flame are you meaning a gas dryer cause mine is electric
  • 640 Answers
Make sure your washer is spinning out the clothes well..check vent leading out the house,,and make sure the damper or flap is in cgood condition...onthejob
Posted on Feb 17, 2009
  • onthethejob1
    onthethejob1 Feb 17, 2009
    -ok lets take a look ok..take the bottom panel off ..there three screws holding it...careful please...steart the dryer on a normal cycles and watch the flame is it sucking to the back fast and smooth,,it must burn straight to the back of the heater housing...onthejob,,,first step
  • onthethejob1
    ok same problem,,you should be able to see the coil or element glow bright red,,is it..onthejob
Whirlpool duet electric dryer leaking water
Check and clean your venting from the dryer to the outside. If it is plugged it will trap the moisture in the machine. Remember heat doesn't dry the clothes without air flow to push the moisture out.
Mar 04, 2013 | Whirlpool Dryers
Whirlpool duet dryer - when using the settings that automatically sense if the clothing is dry the dryer is saying the clothes are dry but the clothing is still damp
Easy fix: Look inside the drum below where the filter goes in. You will see two metal strips. They sense the wetness. Now get this: the dryer sheets rub against them and a thin wax buildup on them prevents the controls from properly determining wetness. The control has no clue the clothes are still damp and thinks everything is kosher; so it advances to the end. Solution. Clean the stuff off of the sensors so that they can sense the true wetness once again.
May 22, 2010 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Dryer, Dampness sensing only partially working.
inside dryer there is 2 metal strips clean tham off with a eraser if that dont cure it make sure vent clean going out of your home if both are done and still does it depends on dryer if its a sencer are control board
Oct 03, 2009 | Whirlpool GEW9250 Electric Dryer
My Whirlpool Duet shrinks my clothes.
If you did not have good success with the unit - I would advise against getting another one.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a gas Whirlpool Duet dryer and sometimes the cycle wont complete and the clothes arent dry ( very damp). when i use the timed dry option i ave the same result. last week my washer overflowed and i...
Check your exit vent outside of your house... what you can do is remove vent hose on back of your dryer... run dryer and feel the air coming out of the vent right behind your dryer.. now reinstall your vent line and check outside,,, see if you feel the same or about the same air flow... if your air flow is block, then your heat will not come on regularly to dry clothes... good luck
Jan 19, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool electric Dryer has water in vent
take the vent hose out of your dryer and try to dry the clothes, if it works your dryer is fine and the vent is clogged
May 10, 2008 | LG DLE7177 Dryer
Damp clothes
the dryer is not the problem the problem is the house vent it is restricted some where
May 02, 2008 | Whirlpool LER6636PW Electric Dryer
Whirlpool GEW9250 Electric Dryer Logo
164 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
