Question about Blaupunkt PCxt652 Coaxial Car Speaker
6x9 hook up
I have a 2000 grand am and have already taken out the old 6x9 speakers. i put in new jl speakers but no sound somes out. the old 6x9s had two little copper wires attached to them and when i took out the old ones they ripped off the speakers do i have to attach these copper wires to the new speakers? cause just connecting the clip doesnt work.
  • james kappers
    james kappers May 11, 2010
    those two copper wires are most likley the two outputs from your radio for the speaker. can you clarify on the clip
  • 58 Answers
Yes conect the wire to the new speakers and it has to work
Posted on Feb 19, 2009
How to hook it up to system with two 10s 400 watts per sub and two 6x9s at 200 watts each?,subs behind seats, 6x9s in doors. IF i need another amp i have one,to help push. But either way i need your help...
Hello www_mitzjohn,
I'd definitely use another amp.
The 2-channel Sony is well suited for powering the 6X9's but a monoblock would be better for the subs. The different types of speakers running from the same channel will not sound very good and likely it'll be impossible to get the impedances to match.
You'll want to set the Sony to send higher frequencies to the 6X9's, but not to the subs. You can't adjust the channels individually. So, just connect each 6X9 to one channel of the Sony and use a monoblock subwoofer amp for the subs.
Hope this helps.
Oct 31, 2009 | Sony XM-2150GSX Car Audio Amplifier
I have 2 6x9 speakers up front 4 6 1/2 3-ways
Hello rjmiller4039,
Although amps with 5 channels are pretty rare, you can get one. Alpine, Boston Acoustics, Infinity, JL audio, MTX, and Polk all have 5-channels ranging in price from around $350 up to around $1,000. The Alpine PDX-5 will output 75X4 watts RMS for the front and rear stereo channels and 300 watts to the mono sub channel. It is priced at $599.99 at Crutchfield.
Hope this helps.
Sep 18, 2009 | Jl Audio 500/1 Car Audio Amplifier
Bassles Powerplant 6x9s
try reversing the polarity on one speaker.
they might be out of phase.
what happens is the speakers cancel out.
put the balance to one side,and if it has bass,then that is the problem.
if there is no bass with only one playing,then phasing is not the problem
Sep 01, 2009 | Fusion PP-FR692 Car Speaker
I need help on sound built in
u may be able to custom fir the 6x9 into the rear of the vehicle, if you don't want to do that, you may be able to fit them into the spots in the doors, but that still may be a custom job. u could always go with boxes, individual boxes that you could put on the floor on maybe on the back deck where usually the 6x9s would be located. if you dont like that idea, you might try a body shop or electronics retailer because there is definitely a way to fit those speakers in the doors or on the rear deck, it just won't be an easy job for a beginner, you have to cut holes
Aug 09, 2009 | Car Audio & Video
What speakers fit in my 02 Ram Quad Cab?
In the front door, that's a factory 6x9 speaker. There are some aftermarket 6x9s that will fit. In the rear deck, they use a speaker similar to a 6 1/2 but the bolt pattern doesn't match up, so there are a number of 6 1/2 and 6 3/4 sized speakers that will fit, but you'll have to redrill the mounting screw holes.
Jun 04, 2009 | 1995 Dodge Ram
SPEAKER CONNECTIONS
You can go to checkers or auto zone and they can assist you with purchasing a tool that is designed specifically for pulling the fasteners that hold the door panels snug to the door frame itself-or you can use a good sized flathead screwdriver to do it and if any get damaged you can get new ones at the same stores to replace them-as far as the 6x9 speakers go you can most likelyjust plug them in parallel wired to the amp or at the speakers but it will drop your ohms a little(resistance) assuming that the speakers that are already in the vehicle are all 4 ohm speakers wiring the 6x9s parallel with a set of them would give you a 2 ohm load per channell at the amp-most amps today are stable at 2 ohms so it should be fine
May 28, 2009 | Audio Pro 15PLB76 15 Inch 800 Watt Woofer...
No Sound From Speakers
Replace the 37 year old radio, it has retired.
May 20, 2009 | Cadillac DeVille Cars & Trucks
6x9s cone not working!
can you swap speakers with other one?if so do this and if speaker still sounds bad it is definately the speaker. there is really no way to take speaker apart and repair
Oct 02, 2008 | Infinity Reference 6412cf Coaxial Car...
Blaupunkt PCxt652 Coaxial Car Speaker Logo
186 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
