Question about Samsung SC-DC164 DVD Camcorder
Write error I have a Samsung mini-DVD camcoder sc-dc164. I get a write error whenever I press record. It says to press OK to reset it, but it still does not work.
I had the same problem. Called Samsung, they told me not to use DVD+R DL discs (despite their presence in the compatibility table in the manual). They also said DVD+R discs don't need finalizing, which contradicts the manual. I can't get them to play in my PC. For the first two discs I tried, it seemed to get write errors halfway through the disc, as if it had trouble with the second layer. I didn't record long enough on the third to find out. The camcorder still shows video on the third disc, but I can't finalize it and it won't play on my PC. Glad I'm only borrowing this camera. Won't buy a Samsung, and probably won't buy a DVD cam.
Posted on Sep 30, 2007
SOURCE:
Samsung camcorder disc error
okay so i have founnd the solution happily and i am actually finalizing my disk right now!!! woooohoo plug the camera in and use the remote that it came with to navigate through the menu!! the finalize button is now able to function!! I hope this works for u!!
Feb 24, 2009 | Samsung SC-DC164 DVD Camcorder
Sony dvd305 camcoder tray not opening
Have you tried to reset the camera. There is a reset option in the manual that may help.
Jul 30, 2008 | Sony Handycam DCR-DVD305 DVD Camcorder
Recording to dvd RW's from mini dvd's from panasonic camcorder
I didn't understand your question.
All dvd player can play mini dvd's. Why do you want to transfer it on a normal dvd disc???
Jan 04, 2008 | Samsung SC-DC164 DVD Camcorder
I can't see the dvds into any dvd player
Most DVD players can't play DVD-R or DVD-RW unless it's finalized (if you record to DVD+RW, it may work ok, but fewer DVD players work right with RW format discs).
Obviously, you need to ensure you are actually writing to the DVD (eg, will they play back on the camcorder). You should see if there's a menu for finalizing the DVDs, that might do it. There are occasionally problems with finalizing discs on some of these DVD camcorders... these discs may not be readable on any DVD player, but might still work in a PC.
The other problem is that some camcoders record in DVD-VR format, which is a special "easily edited" format for DVD camcorders only... regular DVD players don't usually support this (well, some new ones might... this is one of those "evolving standard" issues). You'll probably need a PC to read the disc, edit, convert to a conventional DVD, etc. if you're using this format.
Jan 02, 2008 | Samsung SC-DC164 DVD Camcorder
Recording
iam having the same problem anyone know why
Dec 11, 2007 | Samsung SC-DC164 DVD Camcorder
Write error
I think i just figured it out. Somewhere else on the web clued me in that the disc got messed up (don't know how). I put in a new disc and it works. Other disc still doesn't though.
Nov 04, 2007 | Samsung SC-DC164 DVD Camcorder
Samsung SC-DC173(U)
I've been trying to find out the same information. We went to disney this year lost 3 full dvd's worth. Called samsung all they told me was to use memorex mini-dvd's. Thanks alot ):
Anyways hopes this helps a little.
Sep 04, 2007 | Samsung SC-DC164 DVD Camcorder
Video not found after finalizing disc on Samsung SC-DC164 DVD Camcorder
Put it back in the Camera and see if it tells you the disc is finalized when it tries to format the disc. If it does then you know for sure it is finalized..
Dec 21, 2006 | Samsung SC-DC164 DVD Camcorder
DVD Camcorder appears to have erased disc mid record!
I know it won't play in a dvd player till it is finalized. Leave it in camera mode, hit menu, and scroll down till you see the option to finalize. If you finalize it, it should play in a dvd player. I am having a problem with my camera(same model) where it won't finalize the disc. Any help out there?
Nov 16, 2006 | Samsung SC-DC164 DVD Camcorder
Samsung SC-DC164 DVD Camcorder Logo
632 people viewed this question
Top Samsung Video Cameras Experts
Marvin
Marvin
302lab
Level 1 Expert
Lawrence Oravetz
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
