Question about Canon CanoScan 8600F Flatbed Scanner
Scanner is asking for twain - Canon CanoScan 8600F Flatbed Scanner
  • Canon Master
  • 13,433 Answers
Hey,
it should come with the drivers
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=13977
click on drivers and downloads, select your windows version and download the drivers and software and install them
Let me know if you need anything else.
Thanks,
Ekse
Posted on Feb 17, 2009
Could not find TWAIN
Hi there
If you want to get a twain scanner,you can just refer to this program,which i have used for a long time.It offers a free trial for new users.You can have a try.Hope to help you.
TWAIN TWAIN Scanning in Overview
Nov 24, 2013 | Canon CanoScan 4200F Flatbed Scanner
Twain driver for hp scanjet G2710
I just wonder how to choose the right twain scanning API for the scanner. By the way, you can ask your question at HP support forum, also, like
http://h30499.www3.hp.com/t5/Scanners-Experts-Online-Now/64-bit-Twain-driver-for-HP-ScanJet-G2710/td-p/2337525#.U3k8IHYoZ2M
VB NET TWAIN TWAIN Scanning Using VB NET
Jan 18, 2012 | HP Scanjet G2710 Flatbed Scanner
When i am going to scan at that time in the screen select the twin source. what is the twin source of canon canoscanlide25
The prompt is probably asking you for the TWAIN source to use. In that box, simply select the Canon TWAIN source. If one isn't present, install the TWAIN drivers for this scanner.
Hope that helps,
MyEfact
Jan 04, 2011 | Canon CanoScan LiDE 25 Flatbed Scanner
Keeps saying "scanner failure" What do I do?
Scanners are a real legacy issue within windows - they have been there forever and yet the software controlling them hasn't been improved on - TWAIN it is the name of the Toolkit which communicates with your scanner and the proprietary software sits on top of that. TWAIN stands for "Toolkit Without An Interesting Name" - I think says it all. It hasn't been improved on much through the various releases of Windows. But to help you more we would need a lot more information.
- Platform Windows 7 .... Mac ...
- Scanner name and manufacturer
- Type of connection to the scanner ( USB ¦ WIRELESS )
- Whether you have had the scanner working in the past on this machine.
- Does the scanner work on another machine - Do you have another machine on which to try the scanner.
- Do you have the original disks for the scanner. And the original Windows Disk - so that you can load up the TWAIN software.
- How did you install the software for the scanner
- Have you come across this TWAIN driver ( perhaps you haven't installed that - because the Manufacturer's software doesn't include the TWAIN driver ( you have to load that from your Windows disk )
If you haven't loaded the TWAIN software - then perhaps - you should de-install the Manufacturers software and then install the TWAIN driver from the disk ( although - it may already be resident in the bowls of the Windows environment on the machine ) and then finally re-install the Manufacturer's software ...
So more questions than answers - but I hope that helps ....
Greg McC
Jul 02, 2010 | HP PSC 750 All-In-One InkJet Printer
Will not dow load to vista it can not find twin
I think you mean TWAIN.
twain is a sub process that is used to make scanning easier between different applications.
Part of what you want to do depends on the application you are using to scan your document eg word, photoshop, etc etc.
Quite often when you install the software for a scanner it will ask if you want to install the twain components. You should click yes.
I would try to re-install the software for the scanner including any updated drivers from cannon support on the web.
Some applications may offer other methods besides twain to get yoyr scan. If you select one of those and try again.
Hope this helps
Aug 11, 2009 | Canon CanoScan N650U Flatbed Scanner
I have installed the UE 404090, but cannot scan to my PC. It says no twain compliant found. If I press scan/file on the machine it says select destination _ what can I do there?
Have you at some point installed a second scanning device on the system..
Reason being TWAIN is configured slightly different by every manufacturer to optomise the working of their hardware.
It some cases when you install a TWAIN device for Scanner A this can interfere with Scanner B
Usually its because your trying to use TWAIN(scanner A) on Scanner B
Make sense?
Make sure (if you have installed another scanner device) that you are using the TWAIN software that came with .
You might need to reinstall the entire set up from beginning.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 06, 2009 | Panasonic PanaFax UF-8000 Laser Fax
I have a Canon scanner 5000f. All of a sudden the computer won't recognize it and says it is "unable to select Twain Source." What do I do?
First you need to follow the instructions for installing the scanner. It is important whether you connect the scanner before the software is installed and whether you work from the new hardware found box or just install the driver as software. It sometimes varies between operating systems as well.
Sometimes the twain files can become corrupted. Since other devices like digital cameras use the twain files they aren’t erased with a driver uninstall or overwritten with an install. If the twain files are gone the driver install will also install them.
Uninstall ScanGear (I think that is the Canon driver software) and remove the scanner if it is still showing in device manager and control panel under scanners. Unplug the USB.
Do a search for twain and delete all you find in the Windows folder. There is probably a folder and several files – delete them all. Do not remove any twain files not in the Windows folder.
Dig out the instructions and reinstall the scanner exactly according to them.
Jan 14, 2009 | Office Equipment & Supplies
Twain drivers
The problem was with the scanner,it was not twain compliant
So the 2 ways left with me was :
1.Download twain drivers for my scanner and install it.
2.Use wia32.dll
I chose second option as i didnt found any twain driver for my scanner.
Hope this can help any one.
Aug 30, 2008 | Office Equipment & Supplies
Twain driver for scansnap s300
The scanner can not be used with Twain.
3 TWAIN or ISIS® applications cannot be used directly.http://www.fujitsu.com/us/services/computing/peripherals/scanners/scansnap/s300.html
Apr 12, 2008 | Office Equipment & Supplies
Downloading software (Twain??)
The download website for your scanner is here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=351&modelid=8008
A TWAIN driver is simply a generic scanner software driver that your specific Canon software can hook into and use.
I recommend starting with this one and see if it installs the TWAIN driver you need:
"CanoScan Toolbox v2.2.3 for Windows 98/Me/2000/XP"
Nov 18, 2007 | Canon CanoScan N656U Flatbed Scanner
Canon CanoScan  8600F Flatbed Scanner Logo
132 people viewed this question
old marine
old marine
