Question about Dell 3100cn Laser Printer
The top wheels grind and make as a growling sound.
The window says 10-397 and to restart printer
  • 49 Answers
Reseat the fuser. Under the plastuc grating on the top rear side of the printer.
Posted on Feb 27, 2009
Signs of awheel bearing going on a daf cf85 430 articulated lorry 2004 ?
Wheel initally with start making a washing machine noise or grinding sound when doing sharp turns the opposite of the wheel side as the outer race will generally go bad first. You may also notice the rim heating up due to friction. Grinding at low speed or a growling sound would dictate an inspection.
Mar 19, 2015 | DAF 44 Cars & Trucks
Chevy Tahoe Right Rear Wheel grinding noise
Sounds like a rear wheel bearing that needs replacing. If you have the tools check out Scotty Kilmer's handy video http://youtu.be/OeSykJguOjY
Jul 21, 2013 | 2006 Chevrolet Tahoe
Drivers side wheel noise
very possible a wheel bearing failing allowing the disc rotor to touch the caliper housing. Also check cv joints.. Jack up the wheel suspected and hold the wheel top and bottom and see if you have movement in and out. There should be none.
May 19, 2013 | 1994 Buick LeSabre
Noise in left front wheel
Grinding noise, growling noise, thumping noise? Something else? If it's a grinding noise, more than likely it is during stops. In this case it is probably metal on metal in the brake pads. If it is a growling it can be in the wheel bearing or CV shaft which usually gets louder with turning or banking. Is it is a thumping can be from a tire issue, a strut, a sway bar link banging around etc. Need to clarify the noise and how you are hearing it.
Mar 08, 2013 | 2003 Buick Century
I am having a problem with tha front and rear brakes, I change disks and brake pads, drums etc. and still I have the same problem. noise front and rear.
what type of noise squeal or growl or grinding if it is grinding or growling i would look to wheel bearings if it is a squeal it is the material the pads are made from
May 03, 2010 | 2000 Dodge Grand Caravan
F-150 Front end grinding
if its coming from your front tire more than likely it your front wheel bearing.
jack up the front end and wiggle the tire at the top and bottom. if it wiggles around in the hub, (Not the suspension) your wheel bearing is worn out. you will also probably notice your tire is leaning in or out not straight.
Apr 09, 2010 | 2005 Ford F-150
HP Laserjet 4L - Grinding or Growling noise when job sent to printer
goto feedroller.com
http://www.feedroller.com/Store/index.php?cPath=1_17_86_25
purchase a maintenance kit.
replace the piper pickup roller.
since the the printer is old and lots things need to be replaced. it is easier to replace all of the necessary parts when you have the printer apart.
the job is not difficult, just time consuming.
Nov 02, 2008 | HP LaserJet 4L Printer
2004 ford ranger
Its most likely either or, if its a high pitched sound its probably the wheel bearing. If its a growling/grinding/clunking sound its probably the CV Joint. However, your problem more than likely lies in either/both.
May 15, 2008 | 2004 Ford Ranger
Dell 3100cn Laser Printer Logo
182 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
