Question about Tecnik TKC195/3 Electric Single Oven
Timer switches off oven, regardless of time left.
Just had a HB2TI2T1/HB2TI5T2 installed and when we set the timer, it turns off the oven after a few seconds, even though the timer says there is 5,10, 30, 100 minutes left. It seems to work in manual mode...
2 Suggested Answers
SOURCE: Main Oven Issue??
Thank you so much! Holding the two (autocook on and off) buttons together got rid of the A and now the bottom oven works! Great!
Posted on Sep 15, 2008
  • 15 Answers
SOURCE: Electric oven will not switch on. No heat, no fan.
Hi. You probably have to switch the oven onto manual control. Auto would turn oven on at a preset time. Is there a button with a hand symbol on it? This might be manual. Timer should show clock when in normal manual operation.
Posted on Aug 22, 2009
I have a whirlpool oven which I bought from Ikea a few years ago but at the end of a timed programme the beeper is not going off can you tell me the answer please.
Timer
To Turn Tones Off/On: Press and hold TIMER SET until a tone
sounds. The display will show "TIMER" and "NA9 On" or
"TIMER" and "NA9 OFF." To remove from the display, press
UPPER OFF, LOWER OFF or OFF/CANCEL. Repeat to turn
back on.
Feb 26, 2015 | Whirlpool RBS305PDS Electric Single Oven
How do I set the timer on the EOG9330XN oven
If the oven is switched off on the wall or there is a loss of power, the clock will stop and you will not be able to use the oven. This also applies when you switch on oven for the first time.
Always you have first to set the time of day, then is possible to turn on the oven. Read user manual.
Dado
Oct 09, 2014 | Electrolux EOG9330 Gas Double Oven
Turn on oven cleaning, but clean indicator stops after few seconds
hello
what this need is to set the reprograms
here are solution below
You can set the timer on a Corning ware slow cooker to automatically switch to a warming setting when you estimate Foods will finish Cooking The programmable features allow you to leave food stewing at home while you are out of the house, freeing up your day. Set the timer on a Corningware slow cooker to let the kitchen appliance do all the Work, and come home to a fully cooked meal.
  • Fill the insert of the Corning ware slow cooker with food and cover it with the lid. At least a quarter of the insert should be filled with liquid to keep the environment moist during long cooking times.
  • 2 Press the "On/Off" button on the left side of the electronic control panel in the front of the appliance. This will turn on the slow cooker to the low heat "Warm" setting.
  • 3 Press the "Cook Time" button on the right side of the electronic control panel to add hours to the timer which will show a total time in hours with a red digital display. Continue to press the button until the display indicates the desired cook time in one-hour increments up to 10 hours. The cooker will automatically adjust the temperature setting based on the amount of time you programmed on the timer. Cooking times of six hours or less automatically start on "High" heat and times of seven hours or more will start on "Low" heat. A small indicator light will come on below the word to tell you the cooking temperature.
  • hope this hope ?
    thanks
    Oct 03, 2010 | Ovens
    How do I reset the clock on a shacklock multifunction oven? Has 5 buttons, timer, a picture with what looks like steam above a square, auto/man and a knob that can turn either left or right.
    press timer (picture with bell) adn cooktime ( picture with what looks like steam above a square) buttons simultaneously while turning adjacent knob clockwise until readout registers current time. Release both buttons and clock is reset.
    Oct 09, 2009 | Ovens
    Trying to set oven timer
    Hi, switch off the mains for the cooker, wait for about 15 seconds then press the 2 buttons on the left and hold them, and then press the - or + button to set the time.
    Cheers
    Feb 19, 2009 | Belling XOU482 Electric Double Oven
    Double oven will not switch on hotpoint ew91
    Press 2 buttons at the same time on the the left of the the timer unit, and then press one otjher button on right of timer unit, this should bring it off auto setting.
    Dec 25, 2008 | Miele Novotronic H350-2B Electric Single...
    Ovens on cooker
    DEPENDS ON THE MAKE AND MODEL EACH TIMER OPERATES DIFFERENTLY, BEST SOLUTION IF YOU DONT USE THE AUTO FUNCTION IS TO HAVE THE TIMER WIRED OUT SO OVEN COMES ON REGARDLESS IF THE TIMER IS SET OR NOT.
    Feb 14, 2008 | Ovens
    Smegg Oven Model Number and problems ... please help =)
    It looks like an S551X-5, I think the timer is a safety mechanism, maybe just set it to full when in use and turn it off when you finish.
    Go to http://www.smeguk.com/KitchenStudioLine/Product/S551X-5.aspx to see features, etc.
    Jan 28, 2008 | Smeg SE399X/5 Stainless Steel Electric...
    Ovens Logo
    32 people viewed this question
    Top Tecnik Ovens Experts
    Richard Roth
    Richard Roth
    Andrew Taylor
    Andrew Taylor
    Are you a Tecnik Oven Expert? Answer questions, earn points and help others
