Question about Panasonic SC-HT70 System
D disc slipped inside machine on panasonic home
Sorry-my system is SC-PT660
cd disc slipped inside machine on panasonic home theater system w/5 disc changer I just bought. How can I get it out?
  • mlw1658 Feb 19, 2009
    I did try this--took the top off and found the disc exchange part was enclosed in a sealed plastic box, inaccessible to see where the missing cd might be so I just closed it up and reattached everything. It seems to work fine--just hope I don't lose any more cd's.
    mlw
Unscrew the case n c were it is maybe u can grab it out
Posted on Feb 18, 2009
How and where can i get a new panasonic dvd for my home theather system. model number sc-pt660. the disk changer does not open and close.
Considering that this unit comes as a bundle it wouldnt be profitable for stores to carry the parts seperatly. The best bet here would be if it still is within the 30 return policy then to take it back to the store you purchased it from to swap out for another. Since Im sure this isnt the case or you would have already done this you can try to save a dime by searching ebay for part systems and repairing or replacing the problem part in your tray (specifically being the tray motor). Theres plenty of tutorials for similar products found on DIY.com. Heres a link...
http://cgi.ebay.com/Panasonic-SA-PT660-5-disc-DVD-player-SC-PT660-AS-IS-/370503039935
May 05, 2011 | Panasonic Televison & Video
I have a Panasonic SA-PT660. It is just over a year old...and I get the 5 Disk changer to open. I turn the unit on and it just clicks (sounds like machine gun) going off. It says Disk Changer Error....
Hi there
Q: Did you push the CD Door by force?
If yes ...
1: you have misplaced the mechanical wheels ..
or broke some thing.
2: Or the second possibility is that the Driving motor rubber is broken
the answer is to service it.
Good Luck
Hope this helps
Nov 19, 2017 | Panasonic SC-PT660 Theater System
My disk changer tray is stuck in open (out) position.
Hmmmm, It may have fallen off the track.... Try jiggling it around a little, but be EXTRA CAUTIOUS because if you do this too hard it may break and we wouldn't want that..... You could try forcing it in, but again don't put too much force.....
Jan 11, 2011 | Panasonic SC-PT660 Theater System
Blu ray connect to my sc-pt660
as far as hooking up your blu ray player to the sc-pt660, the only real way to utilize the surround sound (with true surround sound) is through the optical audio out. You need to connect your blu ray player through hdmi to your tv and then connect your blu ray player to your surround sound using the optical audio out/in. I, personally have the sc-pt660 hooked up through component cables so I don't waste an HDMI input on my TV. Except for cd's, there is no reason for you to use the actual dvd player part of the surround sound considering you have a blu ray player. In conclusion, hooking your blu ray player and the sc-pt660 up to get better video simply isnt possible (your blu ray player alone gives the best possible resolution, 1080p). As far as audio goes, run an optical audio cable from your blu ray player to your sc-pt660 to get true surround sound.
Mar 23, 2009 | Panasonic SC-PT660 Theater System
I just bought the sc-pt660.Is there any way for me to hook my regular tv(not a flat screen or hdtv)or my time warner cable box to this to get sound from movies on tv.I dont see any audio in ports.thanks
You can use the PANASONIC AUX IN ports for your TV or CABLE BOX audio, unless you run the DIGITAL CABLE into the PANASONIC, this may be available on the CABLE BOX or your TV, my suggestion is if you use the Cable box to view TV then use the CABLE BOX AUDIO OUTPUTS, you would be better with the CABLE BOX digital output INTO YOUR panasonic, but if it is already being used take the AUDIO out analog connection from your cable box into your Panasonic AUX INPUTS, then set the Panasonic to AUX IN mode.
Feb 28, 2009 | Panasonic SC-PT660 Theater System
Problems connecting phillips tv to panasonic sc-pt660 home theate
I just bought a sc-pt660, I have a philips tv too, the TV only available output is digital coax but the home theater only has digital optical input, you may buy a digital coax to optical converter like this one:
http://www.amazon.com/Cables-Go-Coaxial-Optical-Converter/dp/B0002J2MV4/ref=pd_cp_e_3?pf_rd_p=413863501&pf_rd_s=center-41&pf_rd_t=201&pf_rd_i=B000I98ZQY&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=1BS8MKCZ1CWQR071S8RN
Alternativelly you can also use the headphone output that is near the side input in the TV and buy an RCA adapter like this one from radioshack: http://www.radioshack.com/product/index.jsp?productId=2103225
Jan 04, 2009 | Panasonic Home Theater System System
Panasonic SC-HT70 System Logo
151 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
