Question about Uniden TRU8885 Digital Answering Machine
Can't enter phonebook numbers - Says memory full
When trying to enter phonebook numbers it says the memory is full even though there are 0 phonebook entries.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 84 Answers
Clear out your caller ID, These phones use a shared memory, once the caller ID is cleared, you should be able to store names/numbers in the phonebook.
Posted on Feb 27, 2009
Cant remember my code for Master Reset and Clear what must I do
Pleas e do the following step
Code to lock keys. Press together *7
Note: [] (pause) means the * key held in until box appears.
Select phone line - (use this to write things below the provider name):
[] [] [] 0 0 8 [] 1 []
Add phonebook to main menu:
[] [] [] 1 0 5 [] 1 []
Add messages to main menu:
[] [] [] 1 0 7 [] 1 []
Copy SIM memory (phonebook menu):
[] [] [] 1 0 8 [] 1 []
Eng Field options (main menu):
[] [] [] 1 1 3 [] 1 []
Slow (Frequency of search menu):
[] [] [] 1 0 1 [] 1 []
Medium (Frequency of search menu):
[] [] [] 1 0 2 [] 1 []
Fast (Frequency of search menu):
[] [] [] 1 0 3 [] 1 []
Enable EFR:
[] [] [] 1 1 9 [] 1 []
Function :
[] [] [] # # # [] 1 []
Change pin:
[] [] [] 0 0 4 [] 1 []
Unblocking using the "puk" number:
[] [] [] 0 0 5 [] 1 []
You can change GSM frequencies to 900/1800 by entering the enginnering model.
Following the below steps:
enter menu and press 048263* quickly,
then you will enter the secret engineering menu under "Opcode"
input 10*0*3 for GSM 900
10*0*4 for GSM 1800
10*0*5 for GSM 1900
10*0*6 for dual band GSM 900/1800
10*0*7 for dual band GSM 850/1900
To add extra message space 4 your Motorola C350 C450 C550 or C650,
press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.
press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.
You will receive an extra 50 msgs memory space.Switch phone off and back on.
Hope this helps.
Thanks for using fixya .
Jan 26, 2011 | Motorola Mobility V360 Cellular Phone
Tip
MOTOROLA TIPS
Motorola Secret Codes
IMEI number:
*#06#
Enable EFR:
Function :
Change pin:
There are lots of similar codes exist. If you change the last number to 0 you can deactive that code. The 3 digit number at the middle are from 0 to 999. I put the most interesting codes. (EFR):Enhanced Full Rate Codec.
You can change GSM frequencies to 900/1800 by entering the enginnering model. Following the below steps:
enter menu and press 048263* quickly, then you will enter the secret engineering menu
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
To add extra message space 4 your Motorola C350 C450 C550 or C650, press menu button, press 048263* quickly, then on the popup menu enter 47 press ok.press 50 and ok.press 1 ok.press 64 ok.press 1 ok.press 186 and ok.You will receive an extra 50 msgs memory space.Switch phone off and back on.(not tested)
Important!
Try these codes at your own risk! We don't accept any complaints.
Some of these codes may not work
on Sep 27, 2010 | Cell Phones
Tip
Motorola secret tips
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
on Mar 08, 2010 | Cell Phones
My motorola v360 unlock code and security code has been changed and now i cont entre my phone please help?
hello,
Enable EFR:
Function :
Change pin:
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Hope this helps.
If you are helped you can rate on the 4 thumbs and leave a short comment,because,
this is the free side and I can get the chance, to help people like you .
Jan 20, 2011 | Motorola Mobility V360 Cellular Phone
I have entered a name in the phonebook and connected it to a tune so when that person rings the tune should play but it doesnt even though its all turned on and the tone has been confirmed whats wrong
When you entered the person into the phonebook on the phone, did you include the area code? It's wierd because it won't register who is calling if the phone number in the phonebook does not match exactly how it is coming in on the caller id. Try this, if it doesn't help let me know.
Nov 04, 2009 | Lands Phones
Forgot how to add new phone numbers and names to my phone
Creating Phonebook Entries To store names and numbers in your Phonebook, please follow these steps: When the phone is in standby mode, press [phonebook icon] (on the left side of the four-way key). To create a new phonebook entry, press the NEW soft key. Edit Name appears. Enter the name for this entry (Edit Name). Use the keypad to enter a name for this entry; the name can contain up to 1 6 characters. (See page 1 1 for instructions on entering text.) If you do not want to enter a name for this entry, your phone will store this entry as No Name. Press the OK soft key when you are finished. Enter the number for this entry (Edit Number 1). Once you have stored a name, EDIT NUMBER1 appears next. Use the number keypad, [right] or [left] on the four-way function key, or the DELETE soft key to enter the phone number 1 ; the phone number can contain up to 32 digits. If you need the phone to pause between digits when it’s dialing (for example, to enter an extension or an access code), press [redial/pause] to insert a two-second pause. You will see a P in the display. You can also use more than one pause together if two seconds is not long enough. Each pause counts as one digit. Press the OK soft key when you are finished. EDIT NUMBER 2 appears next. Use the same procedure when entering the phone number 1 to enter the phone number 2. Press the OK soft key when you are finished. Assign a personal ring tone for this entry (Personal Ring). You can attach a personalized ring tone to each phonebook entry; the phone will use this ring tone when this person calls. Move the cursor to highlight one of the 20 different ring tone options. As you highlight each ring tone, you will hear a sample of that tone. When you hear the ring tone you want to use, press the OK soft key. If you do not want to use a personal ring tone for this phonebook entry, select the NO SELECTION option, and the phone will use your standard ring tone setting. Assign this entry to a Speed Dial number (Speed Dial). Your phone has 1 0 speed dial numbers, 0 to 9. Move the cursor to select the speed dial number you want to assign to this phonebook entry, and press the OK soft key. Select NO SELECTION if you do not want to assign this entry to a speed dial number. Press the OK soft key. You will hear a tone confirming that the new phonebook entry has been stored, and DONE! appears in the display. Note: When the shared memory is full, the oldest Caller ID message is overwritten.
Jul 19, 2009 | Uniden 5.8GHz Dual Cordless Phone
Uniden power max 2.4 ghz
I had the same problem but figured it out. For some dumb reason, Caller ID numbers count against your total phonebook memory. So if you just delete all your Caller ID numbers (press the "Caller ID" button and then the "delete" button) then you'll be able to store new numbers in your phonebook.
If I could get my hands on the Uniden engineer that is responsible for this, I'd smack him! :)
May 17, 2008 | Uniden Phone
Unlock codes
here are set of code that you can apply and play with. You should have included the model of your cellphone but i'm hoping that this would help.
Enable EFR:
Function :
Change pin:
under "Opcode"
10*0*4 for GSM 1800
10*0*5 for GSM 1900
Jan 04, 2008 | Lands Phones
Uniden TCX 805 phone book
i had to delete the caller id which was full. everything works now.
Feb 03, 2007 | Uniden TCX805 Cordless Expansion Handset
Uniden TRU8885 Digital Answering Machine Logo
196 people viewed this question
Top Uniden Lands Phones Experts
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
