Question about Haier HWD1000
Spin cycle error - UNB
The washing machine will not complete a spin cycle at the end of a quick wash or an individual spin cycle selection. If shows 'end' then flashes 'UNB'?
  • 3 Answers
Haier have had one or two problems with there spin,
option 1 make sure the machine is balanced perfect [no rocking at all ] use a level on the machine [ truly ] it works.
option 2 you can not wash one item [ underload the machine or overload the machine this will give same result UNB .
option 3 if you have had the machine a few months and this has just started [ clean the armature on the motor with emery cloth and a quick spray of W D 40 please plug out the machine first
0161 355 8254 if you need help , good luck
Posted on Mar 04, 2009
  • stuart freeman Apr 27, 2012
    My haier machine does this quite often especially when washing light items such as bed sheets. It thinks its unbalanced due to the weight. To get it work properly (spin the contents) i have had to drag machine out of hole under the work top and lift one edge slightly and drop from an inch or so high. It then seems to correct itself. Bit bizaar, but when no other option left you take drastic measures. Silly complicated sensors on machine!
Oko 72630. Why is it stuck on rinse cycle?
Could be several reasons:
- Selected the "Night cycle" program (means standing with the drum full of water, reason: too much noise in the spin cycle)
- Set to the "Rinse hold" (means standing with the drum full of water, reason: wrinkles on the clothes)
According to your description I think that this is not a failure otherwise error E20 will be appears on display.
Once the washing programme has come to an end, END illuminates on the programme progress display.
If RINSE HOLD was selected, the display beside the START/ PAUSE button flashes.
1. After a rinse hold, the water must first be pumped out:
- Either press the START/PAUSE button (the water is pumped out and the washing is spun according to the completed programme;
After the START/PAUSE button is pressed again, the spin speed can still also be changed during spinning), or
- Turn the programme selector to PUMP OUT and press the START/PAUSE button (the water is pumped out without spinning),or
- Turn the programme selector to SPIN or SHORT SPIN and press theSTART/PAUSE button (the water is pumped out and the washing is spun or gently spun).
At the end of this programme step, the END indicator will illuminate.
2. Open the door.
As soon as the DOOR indicator lights up green, the door can be opened.
Dado
Aug 15, 2015 | AEG Washing Machines
I have a samsung washing machine wf7600naw washing machine that won't spin and is displaying the error code SE. How can I fix the problem?
WATER DRAIN ERROR - Display shows 5E.
5E is displayed if the water level frequency detected is 25 KHz or less in the initial phase of the UNB -detecting cycle. The Water Drain error can be cleared by turning POWER SW OFF and back ON.
Dec 11, 2010 | Samsung Washing Machines
My clothes are still very wet even after cycle is finished. It is like they are not fully spinning out, even when I select to do an additional spin cycle. Does anyone know why?
I'm an owner as you and do all my repair on multiple FAV6800A machines.
I don't feel from the info supplied that you have a drain pump/drain line issue because you do not take a "ND" error code for "no drain" during the wash cycle.....the wash cycle completes. I don't believe you have a stuck slightly open water inlet valve in the machine because I feel the machine would eventually over fill and flood the laundry area in time.
Is there any standing water in the wash basket when you remove the wet clothes after the final Spin Cycle?
I would place the machine in Service Mode and run it thru a Quick Spin Test (with a wet load) and record the fastest RPM speed the wash basket will spin up to.
You need the Service Manual to help you get into Service Mode to do the test. Are you going to DIY or call in repair service?
If you want to run the Quick Spin test I will look for a previous post on this forum where I called out the process steps.
Oct 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Code LL flashing. Will not complete a cycle.
The LL error code is not documented very well.
Can you tell me what point of the Wash Cycle the Cycle Status LED is in when you error out with the LL error code?
I believe it will be in the Spin Cycle of the wash cycle.
You could try a Quick Spin test and see if the wash basket will spin up to 850 RPM with no laundry in the Wash Basket. See Page 14 of the Service Manual and see if the Wash Basket will spin up to 850 RPM.
You could also check the TDS for proper range of motion using the SM or this typed out process.
Tub Displacement Sensor Diagnostics check.
It is possible the Tub Displacement Sensor may have failed try this check which is in the Troubleshooting guide stored in your washer console or refer to the SM.
a. Enter the Service Mode by pressing and holding the Enviro Plus and Spin Only keys for three seconds or the display reads “00”
b. Press the Super Wash key display reads “in”…something like that.
c. Press Delicates the Display will show “UC” (Unbalance Closed).
d. Push tub to the back right corner of the machine the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
e. Press Hand Wash.
f. Pull tub to the front left corner while pushing the tub down the display should change to “UO” (Unbalance open). Release tub and the display will show “UC” (Unbalance Closed).
If you fail this test it would be time to remove the machine front cover check if the TDS sensor has fallen of its mounting position between the Tub and the washer frame.
Jul 11, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing is not draining completely. I then try to...
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 19, 2010 | Frigidaire GLTF2940ES Front Load Washer
The machine will start a cycle normally, but after the timer reaches a certain point it stops counting down and the machine will continue to agitate until you force it to stop.
Thank you for verifying the model type so many folks post non FAV6800A/FAV9800A questions in this forum machine specific topic area.
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference.
You will need the Service Manual for support. I’m an owner like you with a solid repair skills on the machine and will try to help you DIY the repair if we can ID the issue through troubleshooting.
Do you have this condition in all wash cycles? Will a Quick Wash cycle complete? Do you see the Cycle Status LED ever indicate the machine has moved to the Spin Cycle during the wash cycle? This could be a Control Board failure but we need to troubleshoot.
I want to make sure the Wash basket will spin up with a Spin Only cycle selection. Can you select a Spin Only cycle with a empty wash basket. I would release the washer top so you can observe this test. I want to rule out a broken Clutch large wrap spring.
Page 33 of the Service Manual will show you how to release the washer top from the base. In Spin Only cycle raise the top just enough to make sure the wash basket is rotating Counter Clock Wise – CCW with the Spin Only cycle selected and operated.
If the above test doesn’t indicate an issue I would like you to try the Quick Service Cycle test on page 15 of the Service Manual and see if your FAV6800A will pass that test with no clothes in the washer. When you put the machine in Service Mode press and hold simultaneously the Enviro Plus and Spin Only keys until the machine beeps and the LED display reads 00. Then press Wash/Rinse Temp to start Quick Service Cycle test. Did the test complete with a PA indication in the display? It will only display the PA code for a few seconds. End of cycle will beep washer will unlock and Cycle Status LED will indicate complete.
Waiting for your reply….Rich
Dec 24, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine wont' spin out at end of cycle.
check your "no spin" mode maybe you selected i saw this probleme many times here in egypt
Jun 06, 2009 | Frigidaire Affinity ATF7000E Front Load...
Spinner not spining on quick wash
THE cloths is not dryed anough till it spind lavamat w 80 washing machine
Oct 19, 2008 | Washing Machines
Maytag neptune mah8700. Will spin at the end of quick rinse cycle but not on any other cycle. Error code I get is SUSP. Washer does drain out.
Hi
My name is Gloria, my neptune washer will not spin on the last spin cycle of any of the washing cycle. A code of uC comes up.
Aug 08, 2008 | Maytag Washing Machines
Haier HWD1000 Logo
1,847 people viewed this question
Top Haier Washing Machines Experts
Gerry Harvey
Gerry Harvey
Owen Barnes
Are you a Haier Washing Machine Expert? Answer questions, earn points and help others
