Question about Samsung 61" 1080p Slim-Depth DLP HDTV
Humming noise It sounds like a fan that is going bad and it is getting louder and louder. Is that possible, and what should we do?
    Novelist:
  • 184 Answers
It may be a fan but its more likely the color wheel assembly. This is a common issue with these TVs. You can probably locate a company that sells them advertizing on this site. Wheels are in the $100-200 range. Its not tto difficult to replace but if you're not too comfortable with a bit of disassembly and disconnecting plug connectors and the like contact a local Samsung service center. The repair will cost $350-500.
Good Luck!
michtech
Posted on Feb 17, 2009
MY 1998 FOR EXPLOYER ELT HAS A LOUD HUMMING NOISE THE FAST I GO THE LOUDER IT GETS CAN ANY ONE TELL WHAT A POSSIBLY CAN BE .MY HUSBAND SAYS THE SPINDLE????
Humming Noise Front End- Any Ideas? - Ford Explorer and Ranger ...
www.explorerforum.com > ... > Stock 1995 - 2001 Explorers
Dec 18, 2008 - 19 posts - ‎16 authors
Have a 98- Eddie 4.0 SOHC, 4WD with a 100,000 mi. When driving it has a humming noise, it almost sounds like a bad tire, or a ... I start to hear the humming noise at 20 mph, it is very loud at 40 to 50 mph ... 94 XLT-95 FX4. humming gets louder as speed increases
May 27, 2010
How to: IAC valve cleaning thread (w/pics)
Oct 29, 2007
humming from air intake
Jun 6, 2002
Loud humming noise coming from the air filter
Oct 6, 1999
More results from www.explorerforum.com
Jan 12, 2016 | Cars & Trucks
I hear a sharp snap then a loud humming noise which sounds electrical. If I turn the refrigerator switch off, then on, the humming stops. Otherwise, it lasts 10 to 15 minutes. Its getting louder.
DID U CHECK UR EVAPORATOR FAN AND LISTEN IF THE NOISE IS COMING FROM IT? COULD BE BROKEN OR IMPEEDED IMPELLER HITTING SOMETHING ON START UP THEN GOING INTO A HUM?
May 20, 2015 | Sharp Refrigerators
Making a loud humming noise accelerating over 30mph. Soon has you reach below 30 mph, the noise stops.... RWD.. Please help!!!! Where do I start??? It sounds like a lawnmower if that helps and I can feel...
It sounds like a bad tire, possibly a broken belt. Check the sidewalls and tread of all the tires for bulges. If good it probably is a bad wheel bearing. Try to isolate from where and what side. If the noise gets louder turning one direction but not the other, then more likely a bearing. If it stays constant both directions but gets louder with speed, then suspect a tire.
Mar 02, 2011 | 1998 Chevrolet Blazer
Cooling Fan noise
Another possible source for the noise is the Color Wheel. It is spinning at a high rate and the noise will get louder as it wears out. You should be able to replace the part yourself. Take a look here first: http://www.fixya.com/support/t372149-samsung_hlp4663w_color_wheel_replacement
Aug 04, 2009 | Televison & Video
The humming noise from my hitachi 42hds69 television seems to have gotten a little louder. This humming sound is more prevelant on various stations. The humming sound seems to be normal/better on dark...
usually it means your screen is going bad unless it is a fan or some mechanical part thats humming if it comes from the screen itself the screen panel going bad.now you can check cables and eveything else for this a signal loss type of short but if you have allready checked all cables or recievers or connected devices for this then its a simple main panel humm means a bad screen panel sorry to say but i hope this helps..
Jun 24, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Tv makes a humming noise
check for bad color wheel....may sould like a grinding sound
Mar 01, 2009 | Samsung HC-P4752W 47" Rear Projection...
Humming noise from tv
Yes a humming noise on that model is usually related to the color wheel It will get progressively louder
Jan 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
2003 Altima rear end noise
it is either a tire or you have a wheel bearing going bad. sounds like a bad bearing. you can usually narrow down side by driving and turning the side that is bad will get louder when weight shifts to that side and quieter when weight shifts off
Dec 08, 2008 | 2003 Nissan Altima
Samsung 61" 1080p Slim-Depth DLP HDTV Logo
Henry  Thomas
Henry Thomas
