Question about Omega Cycling
Crankarm fell off electric bicycle.
On the second time I rode my new Cozybike, which is an electric bicycle that was shipped to me in a huge box, the crankarm fell off after only driving about 7 or 8 blocks. I hired a guy to put pedals on and the other work needed to set up the bike. He seemed to have all the right tools and experience. The problem that happened, was the area peddling was making noise and feeling strange, then the crankarm with the pedal still on it came off on the street. Turns out this product is made in China. How can things go wrong so fast and how would it be repaired?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
Thank You for the good advice. It will work now.
Posted on Feb 19, 2009
    New Friend:
  • 77 Answers
Crank bolts are rarely ckecked when building a bike, they are usually tight from the factory and don't need to be looked at.
Sometimes they are not, but you can fix it at home if you have metric socket tools and a ratchet handle.
Grab a small flat blade screwdriver and pry off the grey plastic cap, you should find the nut in there, you'll need that!
Rotate the arm that is still attatched so the pedal is at the bottom,  Move to the other side of the bike and slide the other arm onto the axle with the pedal at the top and facing away from the frame. Thread the nut on by hand. Grab the ratchet and tighten it tight (same weight as doing a push-up or lifting a 50lb bag of something), go to the other side, take the grey cap off tighten that arm as well. Then put both caps back on and ride in peace.
Electric bicycle
Contact the seller for a manual http://www.omegastores.com/cozybikele.htm
First remove the battery then find someway to support the bike as removing the rear wheel also removes the stand...
Remove the 2 Philips head screws securing the rear mudguard and the 2 on the LHS rear axle cable protection cover & slide the cover off. Disconnect the rear brake. undo the rear axle nuts. Loosen the chain adjusters and slip the chain off. You may also have to deflate the tyre to get it past the mudguard.
Mar 23, 2014 | Electric Bicycle Motor, Bike,electric...
Manual for cozy electric bike
who to put together a Cozy Electric Bike?
Jan 12, 2013 | Little Tikes Cozy Cruiser Trailer
What are the threads and pitch for a Mongoose Mtn. bike pedal - Right side?
The make of the bike does not define the crankarm on it which might define the spec of the threaded hole.
A simple web search for "bicycle pedal thread pitch" leads to..
http://www.sheldonbrown.com/gloss_p.html
Look for "pedal threading"
Aug 19, 2011 | Cycling
Sigma wireless bicycle computer. Model BC 1606L. Wireless cadence monitor has abruptly stopped working. All other functions of this unit working perfectly. Transmitting unit and receiver have new...
Did you throw the magnet on the crankarm? If not check the alignment of the transmitter and the magnet - sometimes they need to be quite close. Sometimes they just fail. I have seen instances where cadence worked and speed didn't and vice versa - so the unit is transmitting perfectly, but one of the sensors has gone bad.
Jun 12, 2011 | Sigma Sport BC1606L Dts Wireless Bike...
Its stoped reading the cadence sensor
First check your settings and make sure that cadence is turned on. Then:
#1) check to make sure that your cadence sensor has not moved and is still within 1-2mm of the magnet on the crankarm.
#2) make sure you still have a magnet on the crankarm.
#3) if #1 and #2 are good, does a little red light come on (body of sensor) when the crankarm magnet pass the sensor.
If all these things have been satisfied and you still do not get a reading, then you have a dead battery and you need to replace the sensor.
Dec 05, 2010 | Polar CS100B Cycling Computer Heart Rate...
Bike pedal fell off on a brand new huffy how do i put it back on
If, the threads aren't stripped, you can put it back on by getting a pedal wrench, and standing in front of the bike, now take the wrench and turn it towards you (clockwise) to tighten. But, if you rode with it loose, then you need a new crank arm. If, the store put it together go back to them but if you did, it is not a defect and you have to pay for one.
Oct 05, 2010 | Cycling
WIPER MOTOR
Here's a great video I'll add to the post that will show you how to replace the wiper motor.">
Apr 19, 2009 | Chevrolet Venture Cars & Trucks
Cycling Logo
180 people viewed this question
Top Omega Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you an Omega Cycling Expert? Answer questions, earn points and help others
