Question about Canon Cameras
I have a canon power shot A550. After i take a
I have a canon power shot A550. After i take a picture, the screen is black for quite a few seconds. It takes a long time for that to clear for me to be able to take another picture. i tried getting a new memory chip but that didnt solve anything. any ideas? it wasnt always like that.
  • Canon Master
  • 4,738 Answers
What is the speed of the card? It should say so on the card, or list its class (look for a "C" with a number centered in the C). If it doesn't say so on the card, and if you've payed only a few dollars for it, it's likely a low speed card and can cause this problem.
This can also occur due to charging time of the flash capacitor. Try turning off your flash and see if that dramatically improves the shot turn around time. If it does, you may also want to consider higher power batteries to improve charge time. Recommend NiMH rechargeables, rated 2500 mah or better. Look on the package, it should state the power rating. If it doesn't, avoid the batteries as they are likely low power.
Posted on Feb 18, 2009
How to remove flat battery from canon power shot A550
Look at the little door labeled CR1220 in this picture. Pry it open with your fingernail, and take the battery down to your local drugstore to buy a replacement (should be around $3).. Note that W-mart for some reason is expensive for the common CR1220 battery compared to retail drug stores.
Jul 27, 2011 | Canon PowerShot A550 Digital Camera
How do I change the shuuter speed on my A550 power shot canon camera
Since there is no shutter or aperture priority mode on the A550, the shutter speed is predetermined by the shooting mode. You can try changing the ISO speed when in a certain mode, but the camera may compensate by changing the aperture setting rather than the shutter speed. You'll have to experiment.
You can place the camera in Long Shutter Mode, however, when you want exposures times between 1 and 15 seconds. You set that by pressing the Function menu and Func. Set button when in [Camera icon]M mode, then using the < and > buttons to cycle through the long shutter settings.
Hope this helps!
Mar 10, 2011 | Canon PowerShot A550 Digital Camera
Were can i buy gear for canon a550 power shot.im camera technician
If you're a camera technician, we should be coming to you for camera gears.
Aug 19, 2010 | Canon PowerShot A550 Digital Camera
Have been given a canon power shot A550 camera without the manual and am having trouble using it. Canon PC 1230 no. 5142118051
Hi dear, The manual you need can download from (http://www.retrevo.com/support/Canon-A550-Digital-Cameras-manual/id/918ag324/t/2/)
Have FUN !
Jan 21, 2010 | Canon Cameras
Black screen on canon a 550
Sounds like you accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on or off to save batteries. You would then use the optical viewfinder, just like you've been doing. To turn the screen back on, press the button once more.
Oct 11, 2009 | Canon PowerShot A550 Digital Camera
Black screen
Not to worry, this a very simple problem. Your display is set to off. All you need do is set it back on. And this is how you will do it.
To the right of your screen where you have your buttons, look for the display button. Below it is usually labeled DISP. Press this button again and again and watch as the screen display changes. At one of those instances it goes blank/off, but at the others it displays the view in deferent manners. Stop at any of those display options where it shows the view.
Sep 04, 2009 | Canon Photography
Black screen problem with Canon PowerShot SD 750
Did you accidentally press the DISP button on the back of your camera? This manually turns the screen on and off to save batteries. Try pressing this button one more time to see if it turns the screen back on.
May 27, 2009 | Canon PowerShot A550 Digital Camera
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Cameras Logo
76 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
