Question about Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph Xact JTAS - 10XL50 - 1PK 3HP 1Ph Xactasaw Left with 50 Ence Table and Legs , Tablesaws -
I own a Jet Left Tilt Cabinet Saw Mdl 708663PK. The on-off switch seems to stick and does not always start the saw. The saw runs normally when it starts. When it does not start, the on switch depresses and does not feel like it is connected to anything. The off switch does not fell like it is contacting any form of a reset switch. This seems to be worse when cold. Any ideas?
I took the front cover off of the switch and noticed the portion of the switch the off button contacts was fully depressed and would not slide back to its proper position. I lubed (silicone) the slide portion of the off switch and cycled it manually to free it up and distribute the lubrication.
Posted on Feb 19, 2009
I have a jet 10 in. left tilt exact-a-saw that will not tilt. The shaft is keyed to the hand wheel and even wi
First guess would be a lock bolt is tightened down. Second guess would be a 90 degree latch or stop. Take a look at this link from "mikestools":
May 12, 2014 | Jet 10" Xacta Saw Left Tilting Arbor...
I have a delta 34-444 table saw, is it a right or left tilt, or how do i find out?
Left-tilt, right-tilt refers to the direction the top of the blade can be tilted when it is not straight up and down. There will be an indicator on the front of the saw, normally pointing to zero. When you adjust the blade away from zero, if it tilts to the left, it is a left-tilt saw.
Feb 05, 2013 | Delta Machinery Delta 34-555 Sliding Table...
Breaker trips after two seconds
Could you explain the problem a little more for me? Does it run OK on start up and when you go to cut you have the problem?
Oct 25, 2011 | Powermatic 1660802K Model 66 Special...
My saw will not tilt fully, it keeps jumping the gears. I have cleaned all areas, i have checked for foreign objects jamming the saw but cannot locate the problem.
Make sure the inner ring on the locking lever has not loosened up allowing it to apply some gravity pressure and is trying to catch.
this happened to me...i could not get the blade to tilt very far and it started "clunking" inside the saw when i got just "so far". It sounded like it was "jumping a cog". I checked everything, a allen wrench" would tighten. Even outside heads on the cabinet . Sprayed everything with silicone. At the end of trying everything, checked the "lever" behind the wheel where you adjust the saw blade up/down (left turning wheel) and accidently discovered the lever had become loose and was tightening just from weight of the lever alone. I loosened the tension fully and the tilt works correctly now. No jumping. Dumb Luck discovery.RGS in Kentucky
Oct 13, 2011 | Hitachi C10FL 10" Stationary Table Saw...
The table saw shutdown where is the restart button
Usually the reset for table saw is on the motor itself
Crawl under the table and check it out & check your motor name plate (use a digital camera to photograph the name plate so you can see it large on your computer and have a record of that information)
Look for oil caps at the bearing ends of motor, to see if your motor can be oiled using 3-in-1 oil
If your saw is shutting down, you may not have enough electricity for the motor
Look at motor name plate for volts amps or watts.
Now figure how much electricity your saw need using the formula Volts x Amps = Watts
Next, look at the circuit breaker and size wire
15Amp breaker = 1440+watts
You can figure the breaker load using V X A = W
Next look at your wire going to table saw
14 gauge wire for 15 amp breaker
12 gauge wire for 20 amp breaker
10 gauge wire for 30 amp breaker
You might benefit by running bigger wire to the saw. And adding some oil in the oil caps.
I oiled my table saw and then ran a dedicated 30Amp wire to it, and it runs real good for a 25-year-old craftsman.
Oct 20, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
May 25, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
Saw kicked out on overload,reset buttion will not reset
did it trip your outlet breaker? check breaker with volt ohm meter. hope the motor didn't go to ground.
Jan 19, 2010 | Jet 708663PK JTAS-10XL50-W1 10-Inch Left...
Our Powermatic PM66 will not start... the motor will run if the contacts are manually engaged but the contacts will not pull in using the start switch
If the motor runs without the switch then the problem is the switch. Pull out and blow it clean of sawdust and try again. Also check the connections at the switch to make sure they are tight.Hook a meter up and turn the switch on to check for continuity. Remember, switches wear out also and need to be replaced.
Oct 14, 2009 | Powermatic 1660802K Model 66 Special...
Vibration in powermatic model 66
No. Unplug saw remove saw blade grasp shaft that saw blade was on wiggle back and forth. Should not be too much play. After 10 years motor bearings are proably worn. Easy to replace
Aug 07, 2009 | Powermatic 1660802K Model 66 Special...
Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph Xact JTAS - 10XL50 - 1PK 3HP 1Ph Xactasaw Left with 50 Ence Table and Legs , Tablesaws - Logo
211 people viewed this question
Top Jet Saws Experts
Are you a Jet Saw Expert? Answer questions, earn points and help others
