Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Hourglass Shape getting the hour glass screen I watched my tv 7 hours ago turned it on this morning and I had the hour glass I did all the converges which made it sharp, but still hour glass almost waving flag! what should I do.
  • russell298 Feb 18, 2009
    it is not moving only staying in one place. Does this still mean I need a tech?
  • bevsavini Feb 23, 2009
    i have the same problem and now you double picture on the bottom as well. please help
    Novelist:
  • 184 Answers
If there is a hour glass shape to the image but convergence is normal, there are 2 possibilities. You either have a pincushion correction problem or if the hour glass seems to be moving, it will be an open filter capacitor in the power supply.
Unless you are electronically inclined troubleshooting this issue will require a factory trained service technician. You can expect to spend $300-$400 to fix this.
Posted on Feb 17, 2009
  • Billy Bauer Feb 19, 2009
    I just thought of something. You should take the front screen assy off and look at the mirror position. If you've moved the TV, its possible the mirror has fallen out of position.
    michtech
    Yes, you'll need a tech for this.
    michtech
Just recently my GE 46GW 948 46 in. Rear Projection Television when turned on goes from a good picture to an hour glass shape and an almost 3d like picture.When I turn it off then on I get a good picture...
Sounds like a loose solder connection on the Convergence board or the convergence power board. If you are savvy and electrically safe, tap on the boards with an insulated screwdriver to see which has the loose connection, and you can resolder to fix. Repair from a service center = $150-300
Jul 26, 2010 | GE 46GW 948 46" Rear Projection Television
Have you ever had this problem?
Sorry Ginko, but a convergence problem would have the curves down from the top and up from the bottom. The hourglass shape is a pincushion problem. This can be as simple as a bad capacitor in the pincushion circuit.
Could you please confirm the model number so I can look up the probable part?
Thanks,
Dan
Jan 08, 2009 | RCA F32632SB 32" TV
Philips 25PT2252
Vertical hold will adjust the frequency (refresh) which would remedy it if the picture was rolling. I had to open up my TV (not recommended unless you know what you're doing) and adjust a "pot" which will adjust your screen's hourglass problem. I hope this helps.
Jun 28, 2008 | Televison & Video
Tv screen has slight hourglass shape
A common fault are some of the electrolytic capacitors failing in the pin cushoning amp section, and probably in part of the scan amplifiers.
To service this will require the proper training and set-up to troubleshoot the set.
Take the set to a service center for an estimate. The cost can be at least an hour or two for the labour, and then the cost of the parts on top.
Jerry G.
Nov 06, 2007 | Sony KV-32S26 32" TV
Green Solid Hour Glass
possible convergence amp ic's failed should be under $300.
Sep 05, 2007 | Toshiba 46H84 46" Rear Projection...
Tv picture shaped like hour glass
The link you posted has been deleted, so I cannot see the picture you posted. If the sides bow in like an hourglass and the red, green and blue colors are still aligned then there is a horizontal width or pincussion problem, but if the sides bow in and the 3 colors have separated and are no longer anywhere near aligned then you have a convergence problem, both of which should be serviced by someone with experience in servicing projection TV's.
Jul 03, 2007 | Akai PT4298HD Rear Projection Television
Hourglass shaped red
I need to see a picture of the TV set. send a photo to techman32k@yahoo.com
Jun 05, 2007 | Akai PT4298HD Rear Projection Television
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
151 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
