Question about Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41)
Cannot reset router after Firmware upgrade failed
As above, I tried up upgrade the Firmware for my BEFSR41 V3 Linksys Router. Following their instructions, the Upgrade failed. NOW....I cannot get into router Setup at all........EVEN after using "Reset". Their is absolutely no router function. Trying to get back into Setup simply yieldsa the Message that the server cannot be contacted.
Ang Help GREATLY appreciated. Thank you.
    Brigadier General:
  • 5,158 Answers
You may have bricked it... there is a solution that i've successfully done i'll get you the website
Posted on Feb 17, 2009
  • 13,433 Answers
Hey,
Hold down the reset button for 30 seconds to restore the defaults, if the router still doesn't function you will need to contact linksys support on how to reload the firmware they may need you to send it to repair.
Let me know if you need anything else.
Thanks,
Ekse
  • 19,396 Answers
You need to setup the router after doing the upgrade.
  • Ginko
    Ginko Feb 17, 2009
    If the router is totally irresponsive then the firmware had been damaged, I will give you instructions.
  • Ginko
    Ginko Feb 17, 2009
    Try again reset using the pinhole button.
    If you can communicate with the router then restart the firmware update.
    If the router is still irresponsive then the firmware has been damaged.
    In that case contact Linksys and tell them that you foowed thoroughly the instructions. Insist for a replacement, sometimes first line customer support are a bit strict on replacements.
    Here is contact: Technical Support Contacts
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to upgrade firmware on Linksys router.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Losing connection constantly, when I hok up computer directly to the modem I have no problems, but with the router my internet does not work. The lights on the router are flashing and indicate that it is...
have you done a chat with Linksys? What do you use to manage your network?
May I suggest you get Network Magic, a free download and eval period.
Using Network Magic, you may find you have settings on the router that prevent your getting past your 'fire wall'.
Oct 12, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Router suddenly dropped connection. Have been using this same router without issue for about 8 years now (Linksys BEFSR41 router). When I tried resetting the router and plugged the power back in, the power...
If the power light keeps blinking it means that the router has reached its end point or else you have short circuited the board, or the router is reached up to the maximum whereby it has totally failed. The best would be to replace that router now or try to use a software named tftp to get into the router interface if it is possible then upgrade the firmware/ You can get tftp by searching in google.
Jan 21, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Idle
befsr41 it seem to be a old router......and it have old firmware on it.....so upgrade latest firmware ....and i hope you will not any issue with the router.
Apr 06, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Firmware update.
Get the latest firmware Upgrade from Website
www.linksys.com/downloads
Mar 08, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Linksys BEFW11S4 upgrade problem
hi,
Download the TFTP---set up file for BEFSR41 v2 and also download the latest firmware of ur router.
Double click on the TFTP file and connect to the router using the default gateway address (192.168.1.1_ and upload the latest firmware....before that do a hard reset for the router foe one minute.
Feb 11, 2008 | Linksys BEFW11S4 802.11b Wireless...
Need to be able to stream
This patrticular b router from linksys is a older version, it is not compatible for certain products, try upgrading the latest firmware for the router through, www.linksys.com/downloads, or else replace the router and check..
Jan 20, 2008 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
How to upgrade the firmware on a BEFSR41
Firmware upgrades may erase all previous settings to your router's configuration. Before upgrading your firmware, make sure to record your settings. 1. Unplug and disconnect all computers from the router except for one. This computer must be plugged into the router directly. There can be no other network activity on the router during the upgrade, so be sure to power off all other computers. 2. Go to http://www.linksys.com/download 3. Select the model number of the Linksys router you have (BEFSR41) as firmware upgrades vary by model and version. You can find your router version underneath your router after the model number. For example, ?BEFSR41 Ver. 3?. 4. Click the Downloads for this Product button. 5. Once you arrive on the download page, click the Firmware button. 6. After the firmware page opens, click the link that says ?Click here to download the latest firmware...? and download the firmware file to your computer. 7. Once you download the firmware Zip file, unzip it. If you do not have an unzipping program, go to http://www.winzip.com and download WinZip, which will allow you to unzip the file. 8. After unzipping the firmware files, one of them will be called TFTP.EXE. Double click on it. 9. When the ?Upgrade Firmware? window opens, you will have three prompts. The ?Server? field is for the IP address of your router; by default this would be 192.168.1.1. 10. Enter the routers password into the ?Password? field; by default the password is admin. 11. Browse for the file in the Firmware Upgrade utility program by clicking on the button next to file with the '?' symbol on it. Look for the file named 'code.bin' in the folder where the firmware files were extracted to. 12. Highlight the code.bin file and click on the Open button to direct the TFTP loader program to put that file into the "File" box. 13. The full path should be displayed [example: c:\linksys\code.bin]. 14. Click on the Upgrade button to begin the upgrade process. 15. The upgrade should take about 1 minute, and you will be prompted after the upgrade is complete and successful. If you are still having troubles, contact Linksys Technical Support.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys BEFSR41 Cable/DSL Router W/4 Port Switch, Retail Box (DSLSBEFSR41) Logo
1,146 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
