Question about Microsoft Windows XP Professional
Can not view Hidden Files/Folders
I do not have a "Folder Options" folder under control panel nor in Explorer "tools" menu
    Brigadier General:
  • 5,158 Answers
When you have a folder open... tap on the Alt key... you should see your menu now... folder options should be in tools... click on it... then click on the view tab... you will see show hidden folders in that list.
Robert
Posted on Feb 17, 2009
  • Roberta Smith
    Roberta Smith Feb 17, 2009
    unless you are logged in as an administrator you won't see that option
    Robert
  • 139 Answers
In the tips section check the tip i have released and u will get a solution for your problem
scan ur system with mcafee 8.5i
Dvd drive is full of files but only shows a empty file folder, how do you open the file
The folder might contain a lot of what are called "hidden files"
To view hidden files, press the "Alt" key in your explorer window and go to "View -> Folder Options"
Then navigate to the View tab and under advanced settings select "Show hidden files and folders"
Or:
Go to the Control Panel -> Appearance and Personalization -> Folder options -> View -> Advanced settings -> Show hidden files and folders
That should fix it
Aug 29, 2012 | Computers & Internet
Documents and settings is hidden
First, open Folder Options either through the Control Panel, or click the Tools/View menu on Windows Explorer and click Options or Folder Options. Click the VIEW tab then locate and select the SHOW HIDDEN FILES AND FOLDERS option, then click APPLY/OK. Afterwards, you should be able to see the DOCUMENTS AND SETTINGS folder. You may then right-click on it and choose Properties then uncheck/deselect the HIDDEN option and click APPLY/OK. If you prefer, you can then go back to the Folder Options to hide HIDDEN FILES/FOLDERS from Windows Explorer again.
Dec 06, 2011 | Dell Computers & Internet
How to find a hidden doument that is taking up loads of memorey on a almio pro
If you are using Windows XP, to show hidden files:
1.
Open Folder Options in Control Panel.
Click Start, and then click Control Panel.
Click Appearance and Themes, and then click Folder Options.
2.
On the View tab, under Hidden files and folders, click Show hidden files and folders.
For Windows Vista and 7:
1. Open Folder Options by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33.png, clicking Control Panel, clickingAppearance and Personalization, and then clicking Folder Options.
2. Click the View tab.
3. Under Advanced settings, click Show hidden files and folders, and then click OK.
May 08, 2011 | Computers & Internet
My C drive shows 29 GB full but when I check my folders it only adds up to 7 GB! Can you help to find the rest?
open command prompt
type the code exactly as written
cd/ (press enter)
dir /a:h (press enter)
If it shows two files like hiberfil.sys and/or pagefil.sys do lemme know
There is nothing to worry it happens some times. I will give you the cure if the same.
rate if you like
Feb 15, 2011 | Microsoft Windows Vista Business with...
Some file show on memory card when scan with PC (antivirus). but not show file when explore or open it
They are hidden or system files, and you have to change settings in order to see them.
To see hidden files:
1.
On the Tools menu in Windows Explorer, click Folder Options.
2.
Click the View tab.
3.
Under Hidden files and folders, click Show hidden files and folders.
Oct 27, 2010 | SanDisk 2GB microSD Memory Card
How can i view hidden files in windows xp?
Kindly follow the following steps to view your hidden files in your PC...
1. Double click & Open the 'Windows Explorer / My Computer'
2. From the file menu bar select 'Tools'
3. Select 'Folder Options'
4. Select the 'View' Tab on the Option Window
5. In that tab you will find 'Hidden Files & Folders' with a folder icon
6. Select the 'Show Hidden Files and Folders' by selecting the radio button.
7. Then select 'Apply'
Now you will be able to view the hidden files & folders in your system. I have enclosed the screen shots for your better reference.
Jun 14, 2010 | Microsoft Windows XP Professional SP2
Lacie USB 2.0 No files or folders displayed in backup folder
Did you try showing "hidden folders and files"?
In the Explorer, select the Tools menu, and pick Folder Options.
Select the View tab and in the list enable "show hidden files and folders".
You can also try showing system files (so choose not to hide them).
That should show you all files and folders on the disk.
Do make sure you are logged in as a user with admin rights.
May 13, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
I can't view hidden folders in Windows Explorer
I assume you have a Vista machine since you can't find the Folder Options under Tools. It's been moved (who knows why!) to the Control Panel. Open Control Panel, double-click Folder Options, and there are the choices you're looking for.
Apr 08, 2009 | Dell Latitude C840 Notebook
Can set up Windows XP to show hidden files/folders
go to controal panal in start then folder options then the view tab
You will have a option to view all hiden folders xp by default will have this turned off Thanx for using Fixya
Feb 17, 2009 | Microsoft Windows XP Professional
Iam not able to view hidden folders
Click on "My Computer"
Click on "Tools" at top of screen
Click on "Folder Options"
Select "Show Files and Hidden Folders"
you're done!
Jan 08, 2009 | Computers & Internet
Microsoft Windows XP Professional Logo
63 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
