Question about Insignia IS-LCDTV32 32 in. Television
Center speaker no longer works
A friend gave me speakers for my computer and now the center speaker don't work all the other 4 work fine
  • leeny1960 Feb 17, 2009
    plugged speaker into another connection and it worked however how do I get the plug fixxed for my woffer
  • 296 Answers
If you can open the woofer case or box, take the speaker out and check connections on the speaker. If connection is good then speaker is blown. Then you can eather look on ebay for a replacemet unit, or just find a speaker that size and and ohms and replace it that way.
Posted on Feb 17, 2009
  • James Bradburn
    James Bradburn Feb 17, 2009
    My bad i read this wrong. You said that your plugged to another slot. That one slot that dont work will need to be resoldered to the board. Becareful to not over heat.
  • 296 Answers
Wiggle the connection that the center one is plugged to. It starts static or playing then the internal connection is broke loose from the solder joint.
Plug another speaker to that connection. If it plays then the speaker is blown.
Tv and speakers buzzing noise
If the hum is a low note continuous hum, its at 'mains' frequency. The power cables to the unit (or inside it) are getting too close to the cables that carry sound signals to the center speaker. The mains power naturally hums and if mains wires are near to audio kit wires they pick up this sound and play it through their system/speakers. Check the wires to and from it make sure the connections are good and firm. Seperate these wires by at least one inch from any power cables, use tape to hold them down and away from each other.
Dec 15, 2013 | Bang and Olufsen Audio Players & Recorders
I have just got a computer from a friend, the speakers he gave me aren't working but they are the same ones he was using without any problems. I've gne through troubleshoot to no avail. The microphone...
you might try
control panel sounds and audio,volume you can select speakers or audio you will find the necessary adjustments to make there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Sep 29, 2010 | Polk Audio AMR50 Computer Speakers
Problem hooking up bose speakers
mcdevito75 here, The HP speakers that came with your computer work fine, the bose speakers work fine on your other computer, the plug on the Bose speakers is a little shorter than the HP speakers, and only the right Boss speaker is working, HMM, Check the Bose speakers, both of them for a volume control 1 of them may need adjustment on this particular computer. If that"s not it, I would speak to a Radio Shack, Staples etc.
Jul 04, 2010 | Bose Companion 2 Series II Multimedia...
No sound. I have owned the speaker system for over 10 years. The speakers had been working fine until after I disconnected them to travel with in my car trunk, then reconnect to my desktop computer, also...
Try changing the fuse. It's located below the power cord. A friend gave me the set I now have because they had stopped working. Turned out the fuse had blown.
Dec 17, 2009 | Altec Lansing ACS 495 Computer Speakers
Left speaker blown or melted?
This isn't usually in the satellite speakers. The amplifier is usually in the sub and these have a bad habbit of blowing/burning up. Return or replace. Pretty common in this model.
Sep 27, 2008 | Logitech Z-2300 Computer Speakers
Soundsticks Sub
he has to configure his sound from internal speakers to the new configuration, via control panel. His speakers must be pluggen in when he does it
Mar 09, 2008 | Harman Kardon SoundSticks II Computer...
My iPod stopped playing through speakers- but only at work...
Esmurfette
First things First!
1) check on other speakers to see if your iPod work fine
2) check connector for loosing electric connectivity.
3) check with your headphones to see if your iPod play music well.
4) Check, power on the computer spk. you got. or the input that is working right.
Good Luck
Jan 29, 2008 | Apple Logitech Inc MM50 Portable Speakers...
Z5300e center speaker no longer works
Hi Phineasj
It is possible the speaker is bad, and defective, time to change,or repair, or RMS, try carefully, open and see the cables, you also can welding the cable again the cables IF broke.
good luck
Nov 25, 2007 | Logitech Z-5300E (970102-1403) Computer...
Insignia IS-LCDTV32 32 in. Television Logo
121 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
