Question about Roper RAS6233KQ Top Load Washer
Roper Washer ras6233kq1
I have a problem and my machine is leaking. I think it is coming from the plastic housing where the drain hose comes out of. The real problem I have is I can't figure out how to take the machine apart. Thanks for any help.
  • 640 Answers
Defective pump...remove 2 screws on console corners..flip console back...disconnect lid swich harness,,,remove the 2 brass or gold color clips on each side,, now pull cabinet towards you..you see that plastic piece with 2 black hoses replace it...onthejob
Posted on Feb 17, 2009
  • 121 Answers
Under machine is screws and behind there is a lot of screw.
My washing machine is a Roper top load washer. The problem I am having is that the pump from the cold water drain from under the washing machine. Do I need another pump? The hot water will work. I use the...
This model is a direct drive with only one pump, the drain pump. If the drain pump leaks, which is a common problem on these models, it will leak no matter what temperature wash is selected! If you a have a leak on cold, it will probably also leak on warm wash. Your problem is your solenoid operated fill valve on the cold side. Only one fill hose comes off of this combination fill valve to your fill plenum at the top back of your tub. So if it leaks on the cold, but not hot, check for a crack in the plastic housing of the valve on the cold half. The valve is located on the inside back of the machine on top right when looking at the front of the machine. They are fairly inexpensive and easy to replace.
Hope this helps
kcomp1863
Jan 18, 2011 | Roper RAS6233KQ Top Load Washer
Roper Washer is leaking at the base, It appears to be coming from the water pump.
Its not uncommon for these drain pumps to leak fortunately the are very easy to replace. Place a small pan under pump remove both hoses and then pop off the retaining clips and pull the pump forward. line up the new pumps drive slot with the drive shaft coming off the motor reinstall retaining clips and hoses Good Luck
Nov 14, 2010 | Roper RAS8445KQ Top Load Washer
Washer is leaking water on bottom of unit
If the water is gushing from the washer, check the small plastic air dome hose on the lower right hand side of the wash tub. Sometimes the hose can come loose and come off. This will cause the water to begin pouring out of the bottom of the the washer when it begins to fill. The following link lists some other items you may consider as well:
http://www.fixya.com/support/r3576648-washer_leak__top_loader
The link explains how to remove the exterior washer case in order to accurately inspect the washer interior components for the source of your leak.
If the leak is more like a constant drip, another common source of leaks with Whirlpool manufactured top loaders is a leaking drain pump. These pumps are not serviceable and if damaged, must be replaced. The following link explains how:
http://www.fixya.com/support/r3794382-replacing_water_pump_whirlpool_top
Don't forget to check all drain hose connections under the washer and the center tub seal.
Replacement parts (if required) can be purchased at any of the following websites:
searspartrsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. the first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need.
If you have any questions, please post back and let me know. I hope this helps you.
NOTE: Roper washers are manufactured by Whirlpool, so these instructions will apply.
Jun 22, 2010 | Roper RAX4232KQ Top Load Washer
Washer leaking water while spinning
Check the drain hose where it leaves the machine, if the square section of it is not in the plastic housing it will cut on the cabinet, if this has happened replace the hose they are difficult to repair, Other possibilities, pump is leaking, and check that the inlet hoses are not leaking and have washers in every connection.
Apr 19, 2010 | Fisher and Paykel GWL11 Top Load Washer
Washer runs water all over the floor, but not every load, it's not coming back out of the drain
Most likely the problem lies with the pump. Its a plastic box attached to the motor beneath the machine. Most likely there is a puncture in it somewhere or possibly a loose hose underneath. Check out the hoses and the pump for issues. The pump is generally a gray plastic with two black hoses coming out the left side.
Dec 12, 2009 | Roper RAX4233PQ Top Load Washer
Roper washer leaks when filling
It's in the drain hose somewhere,during the fill the water gets as deep in the drain hose as it does in the washer,during the wash the pump runs in reverse keeping the water level in the hose low,during the drain the hose is filled again.
Prop the washer up in front on a couple bricks or boards,start putting in water until it starts to leak and take a peak under the machine.
Sep 27, 2009 | Washing Machines
Leaking wash machine
Depending on where exactly the leak is coming from, it could be a drain hose, drain pump, or tub seal. If this is a top-loader, here's how you can tell:
1. If the leak is coming from the BACK area under the washer, this can be caused by a leaking fill hose, dispenser hose, drain hose, or fill valve.
2. If the leak is coming from UNDER the center area of the washer, this could be your tub seal, a crack in the tub, or an air dome hose leak. NOTE: If the air dome hose is leaking, the washer will fill continuously and not turn off.
3. If the leak appears to be coming from the FRONT under the washer, this could be your drain pump, or drain hoses.
Posting a model number, could assist with determining how your washer is configured. I suspect you may have a drain pump leaking as this is the most common cause, but I want to be sure.
Apr 27, 2009 | Washing Machines
I have roper washing machine
I don't know if the agitator is turning or not but the whole agitator is lose from the bottom part of the agitator. The washer also leaks. We have checked all of the hoses etc and there is no problem with that. We wonder if the leak isn't coming from the agitator being lose.
Nov 07, 2008 | Roper RAS8445KQ Top Load Washer
Putting the belt back on a roper ras6233kq1?
HI thanks for your question. so I assume you have the dryer apart, and just don't know how to install on the pulley. . after the belt is on the drum and the belt is hanging.. double the belt and push under the idler pull y , and then on to the motor pulley. thanks . please rate my answer. thanks the appliance doc.
Oct 11, 2008 | Roper RAS6233KQ Top Load Washer
Roper RAS6233KQ Top Load Washer Logo
126 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
