Question about Maytag HYE3658AY Electric Dryer
Clothes are drying slowly. Moisture is leaking
Clothes are drying very slowly. Moisture is leaking around door and out vent pipe in rear. I replaced the door seal but moisture is still leaking. Could a clogged vent pipe be causing this?
  • Anonymous Mar 30, 2014
    Cleaned venting everything and still doesn't dry
  • 4 Answers
I also recently had the same kind of problem.
I took the front off the dryer, and the lint collector, past the screen, was FULL of lint, sand and dirt. Imagine balling up a large tshirt and stuffing it in there. That's how full!
I'd definately look at how to clean out the lint and exhaust lines as well as possible. That wet air has to be able to get out.
Posted on Feb 17, 2009
Hello I have a Indesit tumble dryer that works but keeps flooding the kitchen floor? Model number IDC 85s Help!
Moister in the dryer:
This means that the moist air is not escaping correctly and that is why it is taking so long to dry your clothes - if they dry at all.
a good start at cleaning out lint blocked areas, I suggest go to the back of the dryer and take off the vent pipe or hose and check things out with a flashlight. Clean out all the lint and dust you can, even use a vacuum cleaner on it. Make sure the vent pipe is completely clear of any obstructions.Non-rigid ventshas much worse air flow than smooth piping, so you might want to upgrade tosmooth piping.
Once you have all the lint and dust cleaned out of the dryer, go to where the dryer vents outside. Again, clean the area thoroughly. There is usually a trap door that opens when the dryer air is on and closes when it is not operating. It should be completely clear of lint and opening smoothly.
Also, look into the exhaust area on the dryer carefully to see if there is a hole or gap in the dryer's internal air ducting. Without the vent pipe connected and with no clothes in the dryer, start it and let if run for a few seconds and make sure there is strong air flow from the exhaust port. You should feel it strongly on your hand.
Re-connect the vent pipe and start the dryer again. Feel all around the bottom to see if any air is blowing out from under the bottom. This would indicate there is a break or gap in the dryer's internal ducting. If you do feel air, you will need to call a service technician to see if it can be repaired. If your dryer is very old, there could be a rust hole in the duct.
In conclusion Cause ·Poor venting is a common reason why water might leak into a clothes dryer. Since the dryer works to expel moisture, it is important that the dryer's vents are properly installed so that the humidity can escape.
Effect ·If the humidity in the dryer is trapped, it will eventually turn to water. This will lead to poor drying results or longer drying times, depending on the amount of leakage.
Prevention/Solution ·Faulty dryer venting can be prevented by making sure that the humidity is directed outdoors. Also, vents should be cleaned of lint and other debris before each load so that water can readily escape. Taking these precautions can ensure that the moisture will meet dry, open air.
Read more :http://www.ehow.com/facts_7167266_would-water-dryer_.html
Nov 13, 2016 | Indesit Dryers
Why does my condensed tumble dryer leak water when drying?
Why Would Find Water in My Dryer eHow
Apr 26, 2016 | Dryers
What is causing water leakage at the end of dryer program when it goes into cool?
Mar 29, 2016 | Dryers
Why is there moisture in the exhaust piping?
The moisture from the clothes is heated up from the drying process and is exhausted through the vent pipe. When the warm air with that moisture cools in the vent pipe it condenses and forms water droplets again much like the water that forms on the outside of a glass with ice water in it.
May 27, 2015 | Dryers
May tag Neptune dryer forming moisture inside tub
Oct 10, 2014 | Dryers
Water in basket
Aug 02, 2014 | Fisher Paykel AquaSmart WL42T26DW1 25 Top...
Hirundo washer/dryer fills with water during the dry cycle so clothes come out hot and soaked what could be the cause?
Jun 09, 2014 | Equator EZ 3612 CEE Front Load...
Takes 3 cycles to dry clothes even on towel cycle
If the clothes are hot when they come out but moist or damp it mean the moisture is not getting vented, Check your vent pipe for blockages or leaks.
Apr 30, 2010 | Frigidaire Affinity AEQ6000WH Dryer
Stopped heating
The exhaust is clogged.
Clear or replace the vent pipe and openings.
The clog is often found where the pipe exits the home. Sometimes the whole pipe has built up lint and needs top be replaced. Often times the end is just clogged with lint, birds nests, or other dibri and can be cleaned.
Many states require a metalized pipe to meet code because the plastic pipes can be a fire hazard in situations such as yours.
If the hot humid air cannot be vented properly, the moisture stays in the dryer and the heat just builds up until the high temp limit switch cuts the unit off.
Aug 26, 2009 | Whirlpool LGR5636L Gas Dryer
Moisture in dryer
you have a clogged vent, somehow your vent has become clogged either with in the hose, or where it exits the house, the moisture being removed from the wet clothes is not leaving the unit. CHECK YOUR VENTING POTENTIAL FIRE HAZARD!!!!!
Oct 26, 2008 | Frigidaire FEQ332E Electric Dryer
Maytag HYE3658AY Electric Dryer Logo
219 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
