Question about HP Officejet Pro L7780 All-In-One InkJet Printer
Feeder won't pull paper
The feeder on top of the unit has worked great until recently. Now it won't even pull in one sheet of paper to copy. Cleaned rollers and flat scan area and messed with the rollers to see if they just weren't making good contact with the small piece of cork underneath. Wondering if we have just worn out the cork til it is so smooth and indented that it won't grip the paper to pull through? (HP Officejet Pro L7780 All-In-One-Printer)
  • 1 more comment
  • Anonymous Mar 18, 2009
    same problem. Mine has never worked properly. Need to scan a packet of documents forget it. It will not pull the paper thru
  • Waldruh Apr 07, 2009
    The paper feed works at times , at other times it just spins and says reload.
    Don't know what to do.
  • Anonymous Apr 16, 2009
    I sometimes have the same problem...sometimes the feeder (when sending a fax) will take the paper and other times it just makes the noise, but the foot isn't dropping to make contact with the paper...the one solution that I have found that sometimes works, is using the Guides on either side of the paper, and pushing them closer together, making it more of a snug fit for the paper and so that it straightens the top portion of the paper that is not inside of the feeder... Not a solution but sometimes it works!
  • HP Master
  • 3,780 Answers
The arm in the printer is a cog setting you may have inadvertently knocked it out of alignment, it has free movement on a pivot and spring but when the printer uses it, it pushes on the mechanism to grip the paper and the roller at the bottom freeds it though, sometimes using to thick paper can do the samething. you would need to open up the device and locate the mechanisms, and make sure there is noting in the way of the controller's, i've seen a tiny piece of silver rapper make the same problem.
Posted on Jul 02, 2017
SOURCE: Lexmark 321/323 rollers
Change the D roller AND the cork block (paper separator pad assy.) If either are worn it can pick multiple sheets.
Posted on Sep 20, 2008
  • 1996 Answers
SOURCE: HP L7780 wont copy from the glass
HP instructions for this operation here. See this article. and this article to change the default settings.
If these settings are correct and you still can't copy from the glass, try a partial reset as outlined here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 08, 2009
  • 746 Answers
SOURCE: We need a user guide for our HP Officejet L7780
Dear! Click on this link and download required userguide:
100 % Guranteed
Please Response me back.
Good Luck
Posted on Sep 18, 2009
SOURCE: The auto-document feeder on our HP L7780 OfficeJet
I put an elastic band around the black roller as it doesnt seem big enough and it works nearly every time now. Have done this with another L7780 Pro as well which fixed it completely on that one.
Posted on Dec 22, 2009
SOURCE: Top paper feeder roller rotates but does not draw in the paper
I had the same problem... If you take the upper feed roller assembly off you there should be a grey rubber pad about 1.5 inches wide. This pad is held in place by a small metal clip. You will probably find that the pad has pulled out of the clip. I bent the clip to hold the pad a little tighter and has worked fine since. There was no problem with the rollers.
Posted on Apr 17, 2010
Paper jam I've cleaned sprayed,etc must be something I can't see w/o going deeper. How do I remove cover to get to paper rollers in MX340
Removing the covers is not the answer. Most jams on rear feed printers/faxes are due to some object falling in the sheet feeder. When you pull the paper back out (Very slowly) of the sheet feeder after it has jammed , you will see a nick in the paper. This is because the paper is hitting something and cant get past it. put the paper back in the sheet feeder and the nick will indicate where the object is. Find a large paper clip and unwind it and bend the top of it to 90 degrees. use this to hook the object out and then tip the printer upside down and watch it fall out. Good luck
Dec 11, 2016 | Canon PIXMA MX340 Wireless Office...
Paper feeder pulls multiple sheets of paper
Dec 28, 2012 | Canon PIXMA MP460 All-In-One InkJet...
Multiple pages feed when printing on hp 7410
  • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
  • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
Please Click on this link to know more in detail.
Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
Vertical paper feeder for the copier not grabbing next original sheet
I'm having a similiar problem. Can't consistantly feed one sheet at time. If i load several sheets it pulls all through, etc
Sep 03, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Jams but only w/sheet feeder
Theres is a spring clutch in the adf that goes out. Once that is fixed it should work just fine.
Aug 13, 2008 | Sharp AR-507 Copier
Top feeder won't work properly
have you tried cleaning the separator pad inside the automatic document feeder?
try to Load one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.
If the problem persists, clean the rollers and separator pad manually
May 07, 2008 | HP Officejet Pro L7680 All-In-One Printer
Paper either just rolls through without printing or won't catch and sits there
This has occured to a 2.hand printer I just bought. First head was clogged very much. I disassembled the head, used a paper towel soaked in luke warm water to clear off the over-gooed printing head surface. It is quite easy to get the head out and back in. Unfortunately my cyan ran out during clean-cycle, so I can't say if it also cured the passing paper problem.
Jan 12, 2008 | Epson Stylus Photo R1800 InkJet Printer
Dell 1600n Will only print with sheet feeder open
Rollers may be worn out and not properly grabbing paper or a gear may be broken. You should be able to inspect by lifting cover to feeder and watching as paper is pulled through.
Dec 04, 2007 | Dell 1600n All-In-One Laser Printer
Document feeder
Its most likely to be the pickup roller and separation pad which will need replacing. as a short term fix try cleaning them with some isopropyl alcohol
Sep 22, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Erratic operation thru top copy/fax function
I don't really want to get into this, but you sound desparate. i don't work on your model very often, so bear with me. When a sheet jams, don't just pull it out. Open the document feeder as far as you can and note where it stopped (the side tha DID NOT feed). Look for a possible obstruction or even spot of something that looks dirty or sticky. If so, remove or clean it. Look at the leading edge of the jammed sheet, see if there are any indentations that could possibly line up with a sensor flag, roller edge, etc. Last suggestion. Press down of the side of the document feeder that DID NOT feed through. If this helps, then there is a problem with the latch that holds the document feeder closed. Without seeing the unit it is difficult to diagnose correctly. Let me know one way or the other. Any observations will be helpful. Ed One more thing! Make sure the leading edges of the pages you are sending are perfectly straight and smooth. Make sure that they HAVE NOT been stapled at one time (the indentation can cause a problem)
May 31, 2007 | Canon imageCLASS D880 All-In-One Laser...
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
124 people viewed this question
Ben Johnson
