Question about GE DBXR463EBWW Electric Dryer
Dryer won't start all the time. can hand start unit.
Dryer md # is maytag LDE7334ACE . dryer will start and run fine for weeks and then will not come on at all sometimes. you can hear a slight hum when pushing in on the start button like a relay hum. the hum stops as soon as you let up on the button. you can tape the door switch and hand spin drum while pushing the start button and unit will run through cycle fine . then it will not start back unless hand spun. some times the dryer will also just stop while running and will have to be restarted.
  • 3 Answers
Hate to be the bearer of bad news but it sounds like ur motor is going out. Had this happen to my last dryer. If this is the case it will eventually just stop. Try running it without any laundry in it. if this works, then load it and see if it still works. (poor little motor has to work a bit harder with a full load) good luck.
Posted on Feb 18, 2009
I have a maytag dryer that sometimes when I hit the start button will start and run for only a few minutes and stop and wont start again for a while and does a humming noise when it does star why?
Sounds like the motor is going into thermal overload (Getting hot) it may be caused by the motor itself, or could be overloaded by bearings or fan etc
Jul 28, 2014 | Maytag Dryers
Kenmore dryer mod @ 110.67422600 won't start
Plan on changing this start-button.
Sep 15, 2012 | Kenmore Dryers
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Admiril Electric dryer Mod. # ADE7005AYW. For the
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 31, 2011 | Maytag Dryers
Maytag dryer model number lde7334ace wont spin a full load of clothes we put a new belt on and fan blade now it wont spin a full load
recheck the belt, Tim:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 06, 2011 | Dryers
When start pushed dryer just hums
you more than Likely have a slipped or broken belt ,, (it might have just popped off the tensioner,, ) I'm guessing the humming your hearing is the motor running,, if not,, the motor is fighting to start , and would need replacement
Aug 02, 2010 | Maytag Dryers
Maytag dryer quit drying, no heat Model NO. LDE7334ACE
If the rest of the dryer is operating, make sure the exhaust is not blocked any where from the lint screen to the outlet damper outside. If it's clear then you will need a meter to diagnose further.
Oct 06, 2009 | Maytag PYE2300AY Electric Dryer
Hum but wont start
The slight hum you are hearing is the start windings in the motor. This is a common problem in the kenmore dryers and there is nothing you could have done to keep it from happening. the part number on the motor is 279827 and price from sears is $105.99.
Oct 03, 2009 | Kenmore Dryers
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
GE DBXR463EBWW Electric Dryer Logo
226 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
