Question about Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker
Drip pan is overflowing, ice maker works, no water inside refrigerator (side-by-side whirlpool). could it have something to do with the water filter?
    Prodigy:
    An expert who has answered 500 questions.
    Sergeant:
  • 531 Answers
Is not the filter water line frozen in refrigerator or water valve check and see if refrigerator door (ajar)
Posted on Apr 07, 2009
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
Drain Pan overflowing and water is leaking in refrigerator I can see drip pan overflowing but I do not know how to get to it
remove the back panel inside the freezer,then defrost the pan,then take a length of stiff wire and clear out the drain line from there down to the pan in the lower area near the compressor,as theres probably lime,mold growth build up in the drain line plugging the hose restricting draining of defrost water
Mar 03, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Water leaking from fridge
Generally, this problem can be solved by replacing the water filter. The water filters have o-rings that self seal when installed. If you keep the same water filter to long those seals will start to leak. Fortunately for us, the water filter housing is right over the drip pan, and when it leaks it conveniently goes there.
To make sure take off the toe panel to the frig. If you have problems taking the toe panel off don't worry, they need to be yanked. Start on on side and really give it a tug. Once you get that off you will see how it clips in and you can remove the other side with ease.
Now, if it is not leaking currently, have someone get water from the dispenser while you are on the ground watching. You will be looking at the filter mind you, underneath the frig. You should be able to see it dripping right into the pan.
Now of course you could have another leak, but that is most likely what has happened. Passed that, you will have to see the leak to know what is leaking. You can get water from the dispenser, but if that doesn't work you will need to wait for the ice maker to make some ice. Then you can see if that is the problem.
To simply cut off the water supply to the ice maker you would just need to turn the ice maker to the off position. Then it would no longer ask for water :)
If you need anything else let me know! good luck!
May 30, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool 25.6 cu. ft. side by side with overflow pan underneath spilling over.
make sure that condensor fan motor which evaporates that water is running..
May 21, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Drain pan over flowing
The rubber seal on the water filter is bad . Replace the filter in the bottom kick plate . When the filter goes bad , water will drip into the drain pan , causing it to overflow .
May 12, 2010 | Kenmore 57029 Side by Side Refrigerator
We are getting an overflow of water in the pan in the bottom of the refrig. What causes that and can the pan be removed to empty?
This may sound strange, but the cause of your problem may be your icemaker. The fill tube may be leaking before it gets to the ice maker and causing the pan uner the fridge to fill up too much. try turning your ice maker off for a few days and see if the issue stops. Or you can see if the tube is loose or iced up. If it is iced up, you may have a bad water valve. If you need more assistance, let me know. Hope this helps!
Dec 10, 2009 | Whirlpool ES5FHAXS Side by Side...
Water in ice maker drips
The cause of the constant drip is the inlet valve. Since the ice-maker water doesn`t travel through the filter but directly to the ice-maker, the valve must be faulty to allow water to travel through the valve when it`s not energized.
The valve part number most common for your type of fridge (manufactured by Whirlpool) is W10247725 and retail`s around $25-$30US.
**If you decide to service this on your own remember to unplug the unit and shut off the water to the unit.**
Hope that help`s. If so please take a second to rate the solution I provided for you here at fixya.
Good luck.
macmarkus :)
Dec 01, 2009 | KitchenAid Superba Architect KSCS25INSS...
Whirlpool Defrost pan overflow
check and see if the door to the ice chute is closing all the way, moisture can get in there and cause excessive frost build up also check the location of your defrost thermostat behind the back panel in the freezer, it should be attached to the top of the evap coil. also check your water system and be sure that there are no leaks under the refer dripping into the pan while the unit is cycling for ice fill or dispenser line.
Sep 19, 2009 | Frigidaire FSC23F7D Side by Side...
Overflowing drip pan under the fridge
for reallybsq
problem could be door seals not sealing completely and hence excessive ice formed on evaporator and excess water when it melts. however, i have found this problem many times with large larder fridges and really found no cure.
for guest.
towards the bottom of the back wall, there is a gulley with a drain hole in the middle. this drain is blocked. clear it with something flexible and make sure water flows away freely
Sep 06, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Whirlpool 21.0 cu. ft. Top Freezer Refrigerator with IceMagic Plus Ice Maker Logo
492 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
