Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Blinking green light under 'Timer' flashes there is no picture
When I turn on the TV I get a blinking green light below the 'timer' button. There is no picture but there is sound. I've been told this means the fan is inoperable.
    Novelist:
  • 184 Answers
If you have a green blinking LED that runs continuosly, its the widespread problem of failures of capacitors on several circuit boards in the TV. Currently Mits is having authorized service centers remove the chassis and send it them for rebuilding. Its an expensive and time consuming repair.
Posted on Feb 17, 2009
Put a new bulb in that i got from e-bay, tv switches on perfect but after a little while it turns itself off then red and green light start to flashing. i don't know what the problem is ????
Hello, I try to help. But your questions not spesific.
Below are conditions lamp indicators that appear blinking and solutions (for samsung) :
1. If Timer and Lamp blinking --> Auto timer on/off was been set, picture will appear ~ 25 second.
2. If Timer and Standby/Temp blinking --> A cooling fan inside the set is not operating properly.
3. If Lamp and Standby/Temp blinking --> The lamp cover on the rear of the set is not installed properly.
I hope that solve your problem.
Thanks
Mar 14, 2011 | Televison & Video
Blinking Green Light on Mitsubishi DLP 52525
the circut that detects the bulb has been also failing in these sets
and the conversion chip that controls the picture , and the transformers are not putting out the full power they are supposed to.
this set will need to be tested to determine the exact cause or causes
Oct 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Hello I have a Samsung TV Model# HL50A650C1FXZA I have 3 lights blinking 2 green and 1 red light what is the problem
Below are conditions lamp indicators that appear blinking and solutions:
Thanks.
Feb 22, 2011 | Samsung DLP HL-P5663W 56" TV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Lamp problem
The DM is failing to complete the boot sequence thats why the power led is continuously blinking green. The V26 DLP DM repair kit will usually repair that issue you can get the kit at the following link which includes the replacement capacitors and step by step instructions with pictures on how to do the repair.Its listed under the repair kits category.
http://servicemanuals.vstore.ca/
Mar 26, 2009 | Mitsubishi WD-62526 Projection TV
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Replace the 1000uf capacitors on the DM board. thats whats causiong the problem. If you need further help go to this link they have your service manual available for emailing after purchase and that will entitle you for free tech support and one of their techs can fix those sets in his sleep he will walk you through the repair which parts are only about 20 dollars to fix the problem.
May 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
389 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
