Question about Kenmore Elite 45986 Front Load Washer
What is the best front load washer for repair and maintenance?
  • 121 Answers
GORENJE,CANDY,SIEMENS this are the best.
Posted on Feb 17, 2009
    Genius:
  • 2,920 Answers
Maytag is the best
2 Suggested Answers
blueextc3221
  • 15935 Answers
SOURCE: Elite 45986 Front Load Washer: My 2002 Kenmore elite front load washer (stackable...
1. Find out where the leak is coming from. Does it leak constantly or during one part of the cycle?
A constant leak means the leak is in the valve where the hoses hook to the washer, the supply valves, or the lines to the washer from the water supply.
The other two options are when the washer is agitating or pumping the water out between cycles.
2. See if it leaks during both cycles and the test there would be to lift the lid just as it starts to drain and wait to see if the water stops leaking.
If it doesn't, then run the drain cycle to see if it gets worse or better.
Results may not be immediate as it would take a few minutes for whatever water there to finish dripping.
3. Wait until the water has been pumped out, lift the lid and check the drip again.
When the location of the leak has been determined, unless the washer has been frozen, most leaks can be fixed without parts and just using hand tools.
If you have an older, top load washer, the back or front will come off so you can observe where the leak is coming from.
WARNING. You are working with a moving, electrically hot machine that could flood.
You must take your time and not put your hand or hair in somewhere that can catch you.
You should not have to get into the upper control center, thus reducing the shock hazard.
4. Before turning the machine on, remove a cover. On some washers, there are two screws on the bottom L & R front corners that take the front panel loose.
Once the screws are removed, the front cover is hinged at the top and you simply pull the bottom away from the machine until it comes un-hooked, and set the cover aside.
There shouldn't be many exposed wires or ends, but a few. Don't touch the terminals or lay something metal in the machine that could fall on the terminals.
5. Take a flashlight, look for obvious leaks or better, water stains around nuts, hose clamps, etc.
Most likely you'll see some water residue here and there and that would be normal as a washer is wet. Look for puddles, long white streaks, calcium deposits.
Most likely, you won't find standing water, but some clues of where you should look when the machine is running.
Unless this leak is so obivous you can see what's wrong, you don't need to start it and you should repair the problem.
Once possible areas have been identified, you should start the machine as if you had a load in it and start to watch for the leak.
WARNING- Make sure you have no tools laying in the machine and you are out of the way. There are spinning parts and live wires once you turn the machine on.
Stay clear, and watch your hair and hands.
Once the machine is full and starts its cycle, look for leaks.
Let the machine do its cycle and as it goes into each part of the cycle, look for the leak.
Once you find a drip, stop the machine by lifting the lid or pulling out on the control knob, and now observe more closely.
Remember, water runs down; where it drips is not necessarily the place of origin.
6 Find the leak and make the needed adjustment (which will be all that is necessary most of the time).
If it is a part you need, get the make, model number and serial number of the washer and call an appliance parts dealer or repair service if you don't think you can repair the problem.
If the washing machine leaks water while it is filling, pull it away from the wall and see if the water drips from the inlet hoses or valves as the unit fills.
If it does, tighten the faucet packing nuts. Then, inspect the hoses and replace them if they have become cracked.
Also look for cracks in the casing of the inlet valves. Unplug the unit and lift the top to better inspect the valves.
Replace any valves that are cracked.
Valves usually crack when the hot water in the house water supply is heated to greater than 170 degrees.
They also crack if the house is left cold during the water and water is not drained from the unit. A cracked inlet nozzle can leak during fill.
The leaking water will drip down the outside of the tub and collect under the unit. Be sure that the hose connected to the inlet nozzle is tightly clamped.
Replace the nozzle if you find cracks in it.
If the leaking occurs at some time during the wash sequence other than when the machine is filling with water, unplug the unit, remove the back panel and examine the parts under the machine.
You can make a closer inspection by tipping the unit over onto it's front or side.
Tighten hose clamps that have become loose. If water is leaking from the pump, replace the pump.
The gasket between the tub and the splash guard may wear out and leak. To check the gasket, lift the top and remove the snubber and splash guard.
Replace a worn gasket. A hole in the bottom of the tub can develop.
If the hole is less than 1/4 inch in diameter, remove the agitator and basket and seal the hole.
If the hole is larger, replace the washing machine or tub.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
How do i replace the lid on a stackable washer
Good Morning Kim, thank you for your post!
I see that your question is listed under a front load washer. Please help me understand if the question you are asking is related to a front load washer or top load washer; and, if you are speaking about the door? Also, do you already have the part for exchange? I would first ensure you have the appropriate part number to match your specific appliance model. If you already do, and you are having difficulty replacing this particular part, I would recommend connecting with the manufacturer to either assist with the exchange or locate a professional appliance repair tech near your area.
Best regards.
Feb 09, 2014 | Frigidaire FTF530FS Front Load Washer
What is the best thing to use to clean the inside of the front door seal that has sludge in it.
Bosch Classixx WFC 2465 Front Load Washer how to
clean door seal.
This video will show you
how to change a door seal on this Bosch front loader washing machine .
we have all bosch repairs in our channel
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 22, 2011 | Bosch Classixx WFC 2465 Front Load Washer
Wide gray rubber gasket between door and drum is ripped
the rubber will need to be replaced the cost is around $ 150 you can find washer repair service techs under washer repairs in your local phone book
best of luck
Jan 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
During spin cylces very load noises----bearings gone less than three old got estimate of 4-500 to fix does that sound right?
Yes, that is a good price for a main bearing repair. I wouldn't recommend it. I would buy either a whirlpool top load washer with and agitator ( we are doing to many repairs on the wp washers without agitators), or I would buy the super capacity front load duet. You will save more money in the long run with the front loader. Both of these have been the best washers built in the last 30 years. Good Luck, Appliance Specialists
Dec 15, 2010 | Kenmore Oasis 27042 Top Load Washer
Dear sir, We want to buy 02 nos of whirlpool make 8.5 kg washer 02 nos and one nos of dryer. We need the same for our factry on contineous operation so we want the best...
Hi and welcome to FixYa, I am Kelly.
I understand you want a whirlpool washer. What are you washing? It does make a difference on what would be recommended. The other question is does it have to be a front load machine or is a top loading washer ok?
Right off the top of my head for an 8.5 kg washer I would recommend the top loading MAT Series by Maytag (owned by Whirpool) These manual timer machines can take a beating and over loading only causes belt wear that is inexpensive and easy to replace. The only drawback is that the top loading machines use more water per cycle than a front loading machine. My thought is this... water is cheap... smaller front loading commercial machines used in continuous manner end up costing you more in repairs than you would pay for the water.
Product info: http://www.maytagcommerciallaundry.com/on_premiseslaundry/top_load_washers/commercial_energy_advantage__8482__top_load_washer_mat15mnaww.pro?scr=category
Once you see the linked pages select "on premises lanudry"
What I will tell you about commercial laundry machines is this. Keep the controls simple such as the MAT series. Maintenance parts are available on line and your down time will be minimal. The Maytags have the best warranty also.
As for the dryer Gas or electric? I am going to assume electric since you said "Factory"
For this I would recommend the MDE17 series Dryers, The dryers are 4 roller drum type dryers so the weight is carried equally front and rear of the drum so that the drum seals have a very long life.
I have been a Maytag repairman since 1970 and started in a family owned business. These recommendations are from years of experience. You may pay more up front on the initial purchase but over the years the continued in service time and minimal maintenance required make these units extremely cost effective. If I were to start my own business with 8.5 Kg per cycle washing requirements The MAT Washers and MDE Dryers Maytags are exactly what I would use.
Remember Maytag was purchased by Whirlpool years ago.
All Maytag parts can be obtained through Whirlpool.
I do wish you the best, Thanks for choosing FixYa,
Kelly
Dec 12, 2010 | Whirlpool Washing Machines
Help, my dryer stinks like sewer smell when running, my husband just vacuumed out all of the vents, and it still smells foul!
This is common for front loader washers. They make cleaner that you run through your washer once or twice a year to correct this problem. Take a look at this page there is a link to where you can buy some of the cleaner under the section called clean washer http://www.appliance-repair-it.com/dryer-maintenance.html
Oct 05, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
How do you get rid of the moldy smell?
They make cleaner for washers that you should do once a month or so. This page will direct you on where to get the cleaner from. http://www.appliance-repair-it.com/dryer-maintenance.html
Sep 24, 2010 | Whirlpool Duet GHW9150P Front Load Washer
LG front load washer leaks from door gasket
This is best left for a proffessional to repair
Affordable Appliance Repair
LAke Forest, CA. 92630
Aug 21, 2009 | LG WD-3274RHD Front Load Washer / Dryer
Kenmore Elite 45986 Front Load Washer Logo
93 people viewed this question
Sal De
fordexpert
Robert Rankin
