Question about Metra Turbowire 71-1858-1
Need wire color diagram for a metra harness 71-1858-1 to install in a 2002 cadillac escalade
Need wiring diagram fo 1994 nissan quest gxe premium stereo
A picture requires an installation, which is what you are doing. You should invest in a vehicle specific wiring harness. The wiring colors match for the connection and said harness then plug into the factory harness. If the factory harness no longer exists then you need the wiring diagram for the vehicle. You mention the vehicle has a premium stereo, the Metra part number is 70-5510. It's for an amplified system.
Aug 11, 2012 | Nissan Vehicle Parts & Accessories
I installed a aftermarket head unit in my 2002 Malibu; right now I did the fuse tap thing that came with the metra 70 - 2003 wiring harness but the head unit doesn't cut off when the car is off. Then I...
The radio accessory wire is brown at the ignition switch. If the ignition switch is to the left of the stereo, remove the stereo to access the ignition wires.
Apr 04, 2011 | Car Audio & Video
My 2002 Escalade's dash, radio display, and the S.I.C lights go out when headlights are turned on? All the display lights work when the daytime running lights are on. What could this problem be?...
If you have an aftermarket stereo, you need to check your wires. You may have an incorrect wire connected. Disconnect the radio harness and turn the lights on and see if the dash lights go out. If they don't the stereo wiring is the problem.
Feb 11, 2010 | 2002 Cadillac Escalade
Stereo diagram for 1990 geo prizm
Hello stoogieprezi,
You should have gotten a plug-in harness with your new Alpine. To avoid cutting or tapping the wires on your vehicle, you need to purchase an aftermarket wiring harness. It appears that the Metra 70-1782 is the correct one for the 1990 Prizm.
Then you simply match up the wires on your Alpine harness with the Metra harness. The wiring color code for the harness is shown on the bottom left of the "description" tab and matches up with the Alpine color code on page 18 of your owners manual.
Hope this helps.
Jun 10, 2009 | Alpine CDM-9821 CD Player
2007 kia spectra radio wire color diagram
Are you trying to install a radio? Is the factory harness still in it? If so pick up a metra installation harness #70-1004. This will make your life so much easier.
May 07, 2009 | Car Audio & Video
Car audio wiring diagram for 1998 volvo s-70
CLICK HERE for your vehicles full service manual. If you are cutting wires.
Be warned your vehicle has a factory amplifier installed, and needs to be bypassed to hear the speakers if you are just wiring behind the dash.
Metra makes a harness you install on the aftermarket radio, then simply plug into the vehicle's harness.
All the wires are labeled for easy installation.
70-9220 is the metra part number. Click on the number to see an eBay auction.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Apr 09, 2009 | 1998 Volvo S70
Installation of new cd player in 2002 VR-X Lancer
There are aftermarket wireharnesses available. I suggest the $15-25 purchase. The wires usually match color for color to the aftermarket stereo saving a major head ache if attempting to figure out the factory harness. These adaptors are available at many audo part stores and local installation shops. To check the harness you need, Metra, on of the main aftermarket wire harness manufacturers has an application chart on line, see metraonline.com or a search for American International or Scosche.
Nov 14, 2008 | 2002 Mitsubishi Lancer
Wiring harness
you should never cut the wires on your factory harness... metra and other companys have harnesses that fit your car and would provide you with a correct wire color code you need to hook up a aftermarket stereo keep that in mind but i will post the wire diagram u are looking for
Aug 08, 2008 | 2002 Honda Civic
Car Audio & Video Logo
219 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
