Question about Epson Stylus Photo RX620 All-In-One InkJet Printer
"Clear paper jam" error, but there is no jam!
My MP130 gave me an error message that read "please clear paper jam and press ok", but there is no paper jam. I've tried a few steps that Canon gave me (remove cartridges, off & on, etc.) and I've tried pressing ok, and reset, but nothing works.....thanks! Same deal - was printing fine then keeps flashing E 3 tried resetting, cleaning rollers, powering down - nothing has worked so far. GRRrrrr!!! my printer thinks its jammed but its not, it is an epson stylus photo rx620. help please
  • Anonymous Mar 30, 2009
    I have the same problem. The roller just spins but the message remains with no way to clear it off the screen
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • Epson Expert
  • 97 Answers
Use flashlight to shine inside of all possible visible areas of printers. Especially to the very right or very left. I'm sure you will find something. Remove it
Posted on Jun 07, 2017
SOURCE: hoe to connect the epson stylus to my computer
Hi there, Don't know if this helps, but if it is like mine, the USB cable connection to the printer is INSIDE the printer - underneath the scanner unit. Cheers, Nick
Posted on Aug 21, 2007
kram26
  • 544 Answers
SOURCE: paper jam, with no paper jam!
try to re open again your machine and look very carefully inside remember even how small the paper it will still cause for a paper jam.
if not try to send it to a service technician to give a look to the printer head and rollers.
thanks,
Posted on Jun 14, 2009
SOURCE: Epson Stylus 580rx won't identify vellum paper
Ran into the same problem. The problem is that the printer's paper sensor sees through the vellum and therefore doesn't think any paper moved into the print position. To use vellum, fold up 1/4" edge on a standard peice of print paper and place the leading edge of the vellum under the flap. Place the paper and vellum into the printer and print. The printer will pull in the paper and the vellum together. Make the paper fold tight and straight to prevent jamming. You will need to feed one sheet at a time. Also the Epson inks take a long time to dry on vellum. I let mine dry overnight.
Posted on Jul 29, 2009
roit
  • 28 Answers
SOURCE: "Clear paper jam" error, but there is no jam!
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prirweto-i-23
Posted on Sep 04, 2009
SOURCE: keep getting the error message "Paper jam"
mine does too! help
Posted on Sep 18, 2009
MX860 error message reads: ''Rear cover - The paper is jammed. Clear the paper and press OK.'' Opened rear cover and there is no paper. Cover is properly closed. Pressing ''OK'' just redisplays same...
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 27, 2010 | Office Equipment & Supplies
Paper jam error message..no jam
Hello There this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Jan 22, 2010 | HP OfficeJet 6210 All-In-One InkJet...
PAPER JAM / CARRAGE JAM
Hello there this may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
Jan 05, 2010 | HP OfficeJet 6310 All-in-One Printer...
Canon MX860 Rear Paper Jam
I have a small piece of paper jammed in my Canon MX-860 that Cannot be seen from anywhere. Can you help me find so I can clear it
Jun 27, 2009 | Canon Office Equipment & Supplies
The error message "Service Error 6A00" and cannot fix it. HELP!
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Apr 02, 2009 | Canon PIXMA MP750 All-In-One InkJet...
E appears on my printer
why dont u contact cannon abt r problem i can not think of anyhing but hte cannon printers is faulty.........
Oct 09, 2008 | Canon PIXMA MP160 All-In-One InkJet...
hi,
prirweto-i-23
Sep 18, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Try cleaning the rollers, it's the maintenance tab on the printer's properties. Maybe this will help.
Feb 28, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Epson Stylus Photo RX620 All-In-One InkJet Printer Logo
135 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
