Question about Ricoh Office Equipment & Supplies
Vertical lines slanted on photocopier
Ricoh 1015 photocopier . Vertical lines are slanted by 3mm . Any ides people
  • everett_bott Feb 17, 2009
    Thanks for reply
    Vertical lines are slanted using both . Paper snug in tray , Scanner 1&2 aligned as in workshop manual & cannot find anything loose .
Is it the same result when you place the original on the glass as when you use the Automatic feeder? If copy is straight when you use the glass, then the rollers on the feeder need cleaning (with a damp cloth) -Lift the cover where paper feeds and clean grey rollers,also, and more importantly, clean the darker roller which has a plastic white roller pressed to it with a heavy spring assembly.
If copies are slanted either way you make a copy, make sure to check the paper guides in the tray are snug
Posted on Feb 17, 2009
  • Anonymous Feb 17, 2009
    You mean that the whole copy is slanted right?...in other words a full page document, like a letter, is skewed??
    If so, it is likely then registration roller, and/or vertical rollers within the machine that need a good scrub.
Have more lines what I do
More lines when printing or photocopying?? What color lines? For lines when printing, clean charge rollers of the respective PCUs. If not, replace PCU drums. For lines that are appearing only when photocopying, check if the slit glass or flat bed glass have white out liquid correction ink markings on them. If yes, clean them. If not, clean scanner lens and mirrors of the scanner assembly.
Mar 11, 2014 | Ricoh Aficio MP1600SPF Copier
Reset counter
The problem can be solved exactly from the maintenance manual download here:
http://support.ricoh.com/bb_v1oi/pub_e/oi/0001026/0001026506/VG1398504/G1398504.pdf
Sep 23, 2013 | Ricoh Aficio MP 1600 Black and White...
Photocopies are not clear even after increasing image intensity.
if you have over approx. 60-100k copies on the machine it sounds like you may need regular maintaince on the machine.
to check how many copies you have press the user tools/counter button and then press counter.
Jul 13, 2013 | Ricoh Aficio 1045 Black and White Copier
Line thru the documents when using top feeder
you didn't state model #, but raise your feeder up and look for the "skinny" piece of glass on left side of your large glass and make sure you clean it well.
hth,
razors
Nov 28, 2011 | Brother Office Equipment & Supplies
I have ricoh aficio mp 2000, it's photocopy print black lining
if it background like faint toner all over copy need to replace developer powder/drum/blade/gears
Oct 08, 2011 | Ricoh Aficio MP 2000 Black and White...
Large broad grey lines on all photocopies
Hello sir; The problem you have , you do need a drum cleaning blade to replace and also image transfer roller need to clean with alcohal.
May 26, 2009 | Ricoh Aficio 1013F Copier
A series (10) vertical lines on print outs
See Charge roller my be dirty or Catriges PCU Units
Jan 22, 2009 | Ricoh CL3000E Laser Printer
Ricoh Aficio 1018 photocopier
MY PHOTOCOPIER IS ASKING FOR CODE SC194
Nov 30, 2007 | Ricoh Aficio 1018D All-In-One Laser...
Problems with taking pictures of horizons and buildings
This Nikon's expertise to fix - contact customer support- they may repair or offer a replacement.
Jun 04, 2007 | Nikon D50 Digital Camera with 18-55mm Lens
220 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
