Question about Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac
Need to program autopage 5b remote
How do i program this remote for my f150 2003 ford 6cyl truck ?
  • Dallas Konecny May 11, 2010
    What exactly is the model number of the alarm becuase it's not coming up in my list of existing Autopage manuals?
    New Friend:
  • 103 Answers
Note: This mode will only retain the last 4 remote transmitters programmed. If the transmitter memory is exceeded,
the security system will start deleting transmitters from memory in chronological order.
1. Turn the Ignition 'switch ‘OFF/ON’ 3 TIMES and stay in ON position. Within 15 seconds.
2. Push the Valet switch 3 times and holding in on 3rd push until a long chirp is heard then release the valet switch.
You are now in the Transmitter programming mode.
3. Press and hold any button of the transmitter until the siren responds with a confirming chirp, indicating the signal
has been stored into memory.
4. If you have additional transmitters (up to 4) that need to be programmed, repeat step 3 for each transmitter.
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. 3 long chirps & 3 parking
light flashes will confirm exit.
Posted on Aug 13, 2010
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Does anyone have an installation manual for an Autopage RS-610 Plus? I need to program a new remote.
Note: This system can keep up to 4 remote transmitter in its memory. If
more than 4 transmitters programmed, the system will keep only the last
4 transmitters.
PROGRAMMING THE REMOTE TRANSMITTER
Enter:
1. Turn the Ignition 'switch 'OFF/ON' 3 TIMES and stay in the 'ON'
2. Push the Valet switch 2 times (Holding in on the 2nd push) until you
hear a long chirp. The transmitter is ready to program.
Program:
1. Press any button on transmitter until the siren responds with a
confirming chirp the first transmitter is now programmed.
2. Press button on the second transmitter until the siren responds with a
confirming chirp, the second transmitter is now programmed.
3. Apply the same procedure to program 3rd and 4th .
Exit: Turn Ignition to 'OFF' position, or leave it for 15 seconds. A 3 long
chirps & 3 parking light flashes to confirm exit.
Apr 12, 2017 | Autopage Vehicle Parts & Accessories
RS855LCD 2-way remote and key fob dreain batteries
I see this is a old post but, I have this unit in a used van that came with no remotes. A local audio shop paired it up with a AUTOPAGE XT-33. I can lock,unlock,start with this remote. Just remember to keep the drivers open while doing these steps.
2. Push the Valet switch 2 times and hold in on the2ndpush, when a long chirp is heard then release the valet
switch. You are now in the Transmitter programming mode.
Program:1. Press the Lock button on transmitter 1 until the siren
responds on Car with a confirming chirp; the first
transmitter is now programmed to Car.
seconds. 3 long chirps will confirm exit.
Note: If more than 4 transmitters programmed, the system
will only keep the last four.
The Valet switch is a little Red Push Button that should be
mounted under the lower left side of you dash or in the lower
left kick panel near the E-brake pedal.
Jan 14, 2012 | RS855LCD AutoPage MultiChannel 2 Way...
I am having problems with my alarm/ remote start system. My remote is not comunicating with my truck
I am the senior tech support person for Autopage. You will need to do 2 things. First you need to unplug the antenna and let it sit for a few seconds. Then plug it back in. Attempt to hit unlock on the remote. Next step is to completely reprogram the remotes. This can be done by turn the ignition ON 3 times, and then leaving it in the ON position. (ON/OFF, ON/OFF, ON) then press the RED VALET switch 2 times, and holding on the second push (push valet and release, then push valet and hold). Once the siren lets out a long chirp, then release the valet switch, and program the remote by hitting the LOCK button on the remote itself. Program all your remotes you have, until you have programed 4 remote controls into it. It will cancel any prior remote codes. If you still cannot get this correct, you can call my technical support office at 1-800-945-2527 x600. And i will walk you through it.
Aug 23, 2010 | C3 RS900LCD 900MHz SixChannel Alarm System...
Program remote
REMOTE TRANSMITTER PROGRAMMING
Enter:
2. Push the Valet switch 2 times and hold in on the 2nd
Program:
Jul 09, 2010 | RS855LCD AutoPage MultiChannel 2 Way...
The headlights are not working. Could this be
Usually no. The autopage system is designed to operate the parking lights only.
Apr 15, 2010 | 2001 Ford Mustang
Need replacement remotes for Autopage RF-420
www.autopageusa.com. right from the source
Nov 22, 2009 | Vehicle Parts & Accessories
I need to program an autopage xt-33 remote. the remote needs to be programmed im not sure if it has a valet chip or not
Autopage is a pretty trouble free system...but if the battery is near-dead or dead they can do evil things...swap out the battery and try again...If you can't...go to your local car stereo installation shop and ask them NICELY to help...lots of times it's free..if it is, buy the dude lunch...what, $10?
Good Luck
Jun 15, 2009 | Vehicle Parts & Accessories
Megatronix - TW71 - 5 Button 2 Way LCD Motorcycle Transmitter Remote Replac Logo
205 people viewed this question
Top Autopage Vehicle Parts & Accessories Experts
John
John
Charles Osborn
Are you an Autopage Vehicle Part and Accessory Expert? Answer questions, earn points and help others
