Question about HP Pavilion zt1170 Notebook
"...missing or corrupt\system32\hal.dll..."
When I start my laptop, I get a DOS error message: "Windows could notstartbecause the following file is missing or corrupt: \system32\hal.dll Please re-install a copy of the above file."
How do I get the file and how do I re-install it. I have tried "starting up with a RegCure Setup disc in the machine, but it does not get read.
Thank you for your help.
  • act4yew Feb 18, 2009
    Sorry, but a part of the problem is that I don't have my Windows XP cd's.. I am in search of HP Pavillion zt1170 Recovery CD
  • Anonymous Mar 15, 2014
    and the file c:\windows\system32\cnfig\software cant be read
    Master:
  • 474 Answers
Boot from windows install CD, when it loads, press "R" for repair.
It will go out to dos.
when it gets to dos, type: CHKDSK C: /P then press enter and let it repair, when done
just type EXIT, it will reboot, remove the CD and see if it reboots. If this doesnt work or you need more help, let me know, i can be more detailed if you need, Im just at work and dont have alot of time to type.
Posted on Feb 17, 2009
My acer one has no cd rom and has an error report windows could not start because the following file is missing or corrupt <window root>\system32\hal.dll please re-install copy of the above file
You need to repair your windows, with either using Recovery or get the external CD then reinstall operating system. Hal.dll usually still in your system32 folder but corrupted..
Aug 05, 2011 | Acer Aspire One PC Notebook
Keep getting this message <window
  • "Windows could not start because the following file is missing or corrupt:
    <Windows root>\system32\hal.dll.
  • "<Winnt_root>\System32\Hal.dll missing or corrupt:
  • "Cannot find \Windows\System32\hal.dll"
  • "Cannot find hal.dll"
The "missing or corrupt hal.dll" error displays shortly after the computer is first started. Windows XP has not yet fully loaded when this error message appears. CauseCauses of the "missing or corrupt hal.dll" error include, naturally, a damaged hal.dll DLL file or a hal.dll file that has been deleted or moved from its intended location.Additional causes may include a damaged or missing boot.ini file or possibly a physically damaged hard drive.
    Please let me know you have any further questions or concerns.
Thanks.
May 08, 2010 | HP Compaq 6720s Notebook
Systemroot/32 /hal.dll missing
You can download hal.dll here http://www.dll-files.com/dllindex/dll-files.shtml?hal (but are you sure it's missing and not just "hidden"?)
Nov 15, 2009 | Computers & Internet
  1. Verify the boot.ini file is found on the computer by using a boot diskette or use your Windows CD to get to the MS-DOS "C:\>" prompt.
  2. From this prompt edit the boot.ini, verify that it is pointing to the correct operating system, and that no anomalies are found within the file. Below is a listing of what to verify
  • If only one operating system is on the computer verify that the boot.ini only has one operating system listed. In some situations an alternate configuration line may be added for the same operating system, leaving the improper line.
  • Verify that the "default=" line as well as the operating system line are the same and that they are pointing to the correct operating system.
Verify that the computer has the hal.dll file
From the MS-DOS "C:\>" prompt quickly determine if your computer has the "hal.dll" file by typing "dir hal.dll /s" at the prompt. If the computer returns a "File not found" message, the hal.dll has been deleted.
To recover this file boot the Windows operating system CD and choose the option to "Restore", "Repair", or "Recover." This option will prompt you for the Windows installation to use, the administrators password and will allow you to restore the proper file. At the MS-DOS prompt type the below command.
expand C:\i386\hal.dl_ D:\windows\system32\
In the above example "D" would be the letter of your CD-ROM drive and "C" the letter of the drive your operating system is installed on. For example, your disc drive may be D: and your hard drive is likely C:.
Jun 04, 2009 | Compaq Presario 5000 PC Desktop
Missing <Windows root>\system32\hal.dll.
Yes, if you do run the recovery disk, it will reinstall windows and the bundled software package, thus removing all of your personal data on the computer. I would highly recommend picking up an external notebook hard drive enclosure, so that you can remove the hard drive from the laptop, and plug it via usb in another computer, so that you may begin the backup process. Unfortunately with those kinds of error messages that you get, the only real cure is to reinstall the entire OS (provided that your hard drive is also intact, it may not be a half bad idea, to try and run SeaTools for Windows (or DOS) on your laptop's hard drive to make sure it's not failing).
May 23, 2009 | Toshiba Satellite M45-S169 Notebook
Tosiba laptop could not start not even with safe mode.
The error message refer to system files it cannot load dur to either corrupted or missing files.
You can try to do a repair with your Windows CD install disk and if this does not work you will need to reinstall Windows again together with any drivers that Windows didn't install and your programs.
Note you will lose you data in this process, hoped you backed up your files.
Mar 03, 2009 | Toshiba Satellite A100-S8111TD Notebook
Windows>\system32\hal.dll. corrupt
HAL.DLL Missing or Corrupt
If you get an error regarding a missing or corrupt hal.dll file, it might simply be the BOOT.INI file on the root of the C: drive that is misconfigured
Insert and boot from your WindowsXP CD.
At the first R=Repair option, press the R key
Press the number that corresponds to the correct location for the installation of Windows you want to repair.
Typically this will be #1
Type bootcfg /list to show the current entries in the BOOT.INI file
Type bootcfg /rebuild to repair it
Take out the CD ROM and type exit
Regards
Mar 26, 2008 | HP OmniBook XE3 Notebook
Missing or corrupt \system32\hal.dll
You didn't need to replace the hard drive if there is a missing NTLDR file, it just means that the boot sector is missing or corrupt. You can fix it by putting in your WinXP CD, and choosing REPAIR.(This is known as the Recovery Console and it's in DOS just to warn you...) Then you can type the following at the dos prompt: fixmbr - Fixes corrupt master boot record fixboot - Fixes corrupt boot sector bootcfg /rebuild - Fixes corrupt or missing boot.ini
Mar 28, 2007 | Western Digital Scorpio WD800UE 80 GB Hard...
HP Pavilion zt1170 Notebook Logo
495 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
