Question about Onkyo TX-SR573 Receiver
No audio on my onkyo ds578
No speakers working on any channel
  • galacticmagi Mar 14, 2009
    I have maybe the same prob. my son rolled over on the remote & now there is no sound coming thru the speakers for the "cable" HDTV. I have a post also. My prob is with a Onkyo Receiver TX-SR573 Model. Thanks.
  • Anonymous Apr 09, 2009
    It started when my boy rolled over on the remote about 4 months ago. Yes, it worked fine till that fateful day. I believe it still worked for the other "sources" - DVD player, tuner, CD player,.... "Is it in Protection?" (Not sure what you meant by that except maybe meaning the remote buttons are locked.) Multichannel off? (If that means 2.0 Ch., 5.1, 7.1, and whatever else they have; then I say the 7.1 sound was on.(?) Not sure if that last one is a question or a statemeant.
    Everything worked great till my boy sat on the remote. I appreciate you replying to my concern...Thanks... and I hope my dry humor on some of the answers to your questions doesn't offend you. Oh and my receiver (actually its my dads) does not have a tape deck that I know of. Thanks again.
    -GM
    Brigadier General:
  • 8,546 Answers
When did it start? Did it ever work? All sources? Is it in Protection? Multichannel OFF? TAPE button on receiver and no tape deck playing?
Posted on Apr 08, 2009
My Onkyo HTX-22HDX one of front speakers is not working, please help.
If you swapped the wires at the receiver, and the bad channel changed, that tells you that the problem is in the receiver itself. If it didn't change, then either the wire is bad to one speaker, or one speaker is bad.
Jan 01, 2015 | Onkyo HTX22HDX 2.1 Channel Home Theater...
Onkyo 545 one channel don't work
Use headphones or Computer Speakers
and plug in to your headphones jack.
If the audio is present on both channel , check your speaker system
or the jack circuits.
If symptoms are the same, follow the troubleshooting on the link
above.
Oct 09, 2012 | Onkyo TX-SV545 Receiver
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-DS 595 receiver surround channel unrealiable
How you power off the amp won't hurt it generally. I used to fix ONKYO amps under warranty, and I can tell you now, it will be full of dry solder joints. Take you unit to your local repairer, and they will resolder all the offending PCB's inside. This type of repair will fix 99% of strange audio noises and cutting in and out etc. for ONKYO recievers. Otherwise this is quite a good product.
Oct 27, 2009 | Onkyo TX-DS595 Receiver
One speaker only works in Mono mode
I would be checking the set up mode , you might have it set to left or right channel only , but in mono mode both speakers will come on through one channel
May 25, 2009 | Onkyo TX-SR875 Receiver
How to connect 6.1 speakers to 7.1 receiver
Using the Onkyo display setup, you can turn off one surround speaker, and your receiver should realize it's using the 6.1 channels instead of the 7.1
If you don't want to go that route, use the mic setup that came in the box and your Onkyo will determine by itself the 6.1 channel layout.
It should work fine.
Nov 14, 2008 | Onkyo TX-SR605 Receiver
Audyssey won't initialize the left rear channel speaker input during set-up
had the same problem found that the rear speakers were connected to the wrong inputs on the receiver, try changing them i think you will find that this will work
Aug 28, 2008 | Onkyo TX-SR605 Receiver
Center quit working on my onkyo htr 500
You can download the user manual from onkyo website-free.
To be able to get "Stereo" FM, you need to connect the antenna.
May 18, 2008 | Onkyo HTR500 Receiver
Onkyo Tx-SR55
did you swap the left from speaker with the left front?
if still crackels after that them you have bad left output.
Jan 09, 2008 | Onkyo TX-SR500 Receiver
Onkyo TX-SR573 Receiver Logo
75 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
