Question about Insignia Digital-to-Analog Converter for Analog TVs
How do I connect my digital converter box, direct tv to my tv
  • lault Apr 15, 2009
    I have satellite tv but not local channels. Local channels I get through antenna. How do I connect converter box to tv and connect satellite and antenna
I have a dta8oov1 and the box will not get a signal
Posted on Feb 18, 2009
Magnavox converter box. How can I tell if the box is the problem or the TV? I have no picture, but it isn't the picture tube.
I assume that you are attempting to use the Magnavox converter box to convert digital TV signals received by your antenna system into analog signals for use on an older analog (non-digital) TV set. If that is the case then your first step at troubleshooting the problem should be to view the Magnavox installation instructions to ensure that the converter, antenna, and TV are all properly connected.
http://transition.fcc.gov/cgb/consumerfacts/setup-converterbox.pdf
Feb 23, 2015 | Audio Players & Recorders
How do I get my to work with an antenna
If its a standard analog tv made before the digital changeover it will no longer work directly connected to an antenna as there are no more analog tv transmissions,to use it you will have to get a digital to analog converter box to connect between the tv & antenna it will convert the incoming digital signal to analog so the tv can work again,the same goes fore vcr's they will no longer record directly from an antenna.Some cable systems still supply the cable signal in analog older tv's will still work without boxes on these systems.
Oct 05, 2014 | Televison & Video
Can I connect two tv to one television converter box to watch local channels
If neither TV has a digital TV tuner, you will only be able to watch one channel on both TVs with one converter box. You will also need some sort of RF repeater if you want the person in the second room to change the station without moving the box. You will need a splitter/amplifier connected to the converter box TV out. (I'll assume you are using the coax out.) If you will only watch one TV at a time, then use an A/B switch on the converter box TV out.
If one of the TVs has a digital tuner, put the splitter/amplifier between the antenna and the converter box and the TV with the digital tuner.
Note: amplifier/splitters and switches do fail. If you get a "no signal" message, take out the splitter and connect the converter box directly to the antenna or one of the TVs depending on your set up.
I hope this helps.
(I use an A/B switch between the antenna and the TV and converter box for feeding an old VCR/DVD recorder.)
Mar 08, 2013 | Televison & Video
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
Will this tv work with an antenna or does it need a converter box?
All LCD tv's made in the last 10 years support digital tv out of the box and do not need a converter box. However if you want to pick up local stations over the air, you may need an external antenna. Otherwise if you have cable tv or other services, you can connect your service to your tv directly.
You may also want to call your service provider (if applicable) if you have issues connecting it to your tv.
Mar 25, 2011 | Sylvania 6615LE LCD HDTV
While watching tv, we lost sound. We thought it was the tv but when we use the wii or netflix through the wii, we have sound. We are using a Zenith tv digital converter as well as have things routed...
Reboot the digital converter box by unplug,replug it back like 10-20 mins later.If u still getting the same problems no sound,tries by checking out the RCA cable connections,tries take out the red wire and check for damages and plug it back in or tries changes another RCA cable set all to gether.After new set of RCA cable should be working 100,if not the digital converter box is the problems,than now must change the digital converter box,this box no longer on sale by those big box stores.If u require to change the digital converter box tries websites like Amazon.com,Ebay.com to buy those converter boxes.
Feb 17, 2011 | Televison & Video
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
Sanyo TV, older model, tv converter box, terk antenna, will not p
DP models are already digital there is no need of a converter box. connect a outdoor antenna to the tv directly.
Mar 04, 2009 | Sanyo DP32746 32 in. LCD Television
Digital
Nope. Not a digital Television. I'm guessing it's an older one. Most TV's sold nowdays are Digital TV ready.
Jan 02, 2008 | RCA F32665 32" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
279 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
