Question about SanDisk Sansa c200 MP3 Player
Battery charge my sansa mp3sandisk 1gb won't charge up on the computer, it keeps saying low battery.Can I open it up and change the battery or will you accept a return?
  • 8,596 Answers
Two things:
1) You will have to unlock the the lock switch on the side of the player - it is on the same side of the player as the Record button.
2) We are not the manufacturer - we are a tech support web site, so we don't do any returns here.
If the player is unlocked, and it still doesn't work:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Feb 28, 2009
My mp3 is not charging and it says connected but it still says battery low. what do i do. i need help now. please help.
Here is the full barrage of methods you can use if that fails:
-Tha Mp3 Doctor
Jan 21, 2009 | SanDisk Sansa c200 MP3 Player
Battery won't hold charge very long
Try this: disconnect the player from the computer, turn it off, hold in the volume + (REC button for Sansa e200 series) button, and reconnect the player to the computer while holding the volume + (REC button for Sansa e200 series) button in. Keep holding the volume + (REC button for Sansa e200 series) button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
-Tha Mp3 Doctor
Dec 20, 2008 | SanDisk Sansa e250 MP3 Player
Battery not charging
Use the volume + method listed below:
-Tha Mp3 Doctor
Sep 02, 2008 | SanDisk Sansa Clip MP3 Player
Battery too low comes up on black screen
-Tha Mp3 Doctor
Jun 24, 2008 | SanDisk Sansa e250 MP3 Player
My player is messing up
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
or
-Tha Mp3 Doctor
Apr 12, 2008 | SanDisk Sansa e260 MP3 Player
Charging SanDisk Sansa
Go ahead and do this, in case the DB is corrupted:
Mar 28, 2008 | SanDisk Sansa e250 MP3 Player
Prombles with charging
-Tha Mp3 Doctor
Oct 03, 2007 | SanDisk Sansa e200 MP3 Player
My sansa wont fully charge
-Tha Mp3 Doctor
Jun 12, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa  c200 MP3 Player Logo
57 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
