Question about Kirby G5 Bagged Upright Vacuum
Kirby g5 suction problem
My kirby g5 is not sucking like usual. have replaced bag and checked for clogs, what else could it be?
  • royzee May 11, 2010
    Is this when its an upright or with the hose. Please check with both
    Hi
    is this when it is used as an upight?
    Have you tried taking off the head and tried the hose?
    Rob
  • 134 Answers
If its not picking up as an upright but does with the hose, youve either not connected the belt or the belt is broken
Posted on Feb 21, 2009
There isNo suction on Kirby sentria
  1. Put the hose and see if suction is good. If it is - you may have had nozzle installed wrong or brush roll may be worn out (bristles must be sticking out of the nozzle by about 1/8 of an inch).
  2. If there is no suction with the hose either - check if bag is not overfilled to the point where dirt is blocking the fill tube hole.
  3. If two above are fine - something must be blocking the air passage from the fan to the bag. Check for clogs in the fill tube (tube inside the cloth bag) and mini emptor (bag bottom plastic part) and also see if there is something blocking the exhaust on the vacuum. You may not even see it so use a piece of wire. Once I found a sock there and it was so close to the fan that I could not see it in the hole and was only able to get it out using a homemade hook made from a coat hanger.
how to check for a clog in your Kirby
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
May 28, 2014 | Kirby Ultimate G Bagged Upright Vacuum
How do I fix suction on kirby sentria upright vaccum
www.goodvac.com
1-800-775-6586
May 20, 2014 | Kirby G3, G4, G5, G6, Ultimate, Diamond,...
My Kirby is not sucking, seems to be blowing?
replace belt first. then make sure cloth bag blows up when switched on. if not then theirs a blockage,
Sep 25, 2013 | Kirby G5 Bagged Upright Vacuum
My kirby g5 is not picking up, there is no blockage, but suction has dropped significantly, what could be the problem?
Not to question your description of the problem, but are you sure the suction has dropped? Kirbys don't usually lose suction unless there is a mechanical or electrical problem. When you turn the machine on does it fill with air and expand? If so, then you probably have enough suction. If the bag doesn't fill and expand and your machine is extremely noisy then the fan may be broken and need to be replaced. If you see excessive sparking near the bottom of the handle then you may have a motor problem like stuck or too short carbon brushes or a bad armature. On rare occasions, with Kirby owners who live close to a beach area and vacuum large amounts of sand, the sand actually wears down the vanes of the fan enough to make it useless. To check the fan; first unplug your Kirby from the electrical outlet, remove the brush roll nozzle, slowly spin the fan/belt pulley while observing the surface of the fan, look for cracks or breaks. The fan vanes should be about 3/4 of an inch deep.
If none of the above fixes your problem, look at the brush roll and belt. If your belt has not been changed in the last 12 months, install a new belt. If this is the original brush roll, install a new brush roll.
May 18, 2010 | Kirby G5 Bagged Upright Vacuum
Kirby g2000 not picking up dirt
It is most likely the belt. You cannot reverse the suction. First check to see if the bag is expanding when running. If the bag is blowing up then it is the belt if not it is clogged just take the bag off from the vacuum and remove the head you will see the obstruction.
Dec 16, 2009 | Kirby G6 Bagged Upright Vacuum
Kirby G6 without suction
you probably have a clog in the feed tube going from vacuum head to the bag try removing bag and check for clog there hope this helps
Aug 20, 2008 | Kirby G6 Bagged Upright Vacuum
Kirby blowing out aire
Unplug the vacuum and clean out the hose that goes from the beater to the intake. The hose is either plugged with debis or has become disconnected or BOTH. You may have to use a screw driver to remove the plate over the beater brush.
Mar 08, 2008 | Kirby G5 Bagged Upright Vacuum
Removal of Outer Bag for washing
Here is a link to my guide for cleaning the Kirby cloth bag...
http://reviews.ebay.com/DEODORIZING-CLEANING-THE-KIRBY-VACUUM-OUTER-CLOTH-BAG_W0QQugidZ10000000003719865
It should be helpful. :0)
Marci
Oct 04, 2007 | Kirby G5 Bagged Upright Vacuum
G5 does not suck:)
un-plugthe vacum andget a broom stick and slide it throuh the hose! it's clogged!and change the bag!
Jul 29, 2007 | Kirby G5 Bagged Upright Vacuum
Kirby G5 Bagged Upright Vacuum Logo
228 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
