Question about Zenith E44W48LCD 44" Rear Projection HDTV
I just replaced my lamp in my E44W48LCD HDTV and everything went smooth but I the instructions that the manufacturer sent it says to reset the lamp timer press the ? key and enter 9876 and then push the OK button but my remote doesnt hve a ? key on the remote and its the original remote that came with the set/ waht do I do ?
  • rharms2 Apr 01, 2009
    I just replaced the lamp in my E44W48LCD HDTV and can not figure out how to reset the lamp indicator? someone must know how to do this and why didn't they put it in the owners manual?
Try pushing the menu button on the tv and mute biutton on the remote at the same time and hold for 5 to ten seconds a reset screen should appear
Posted on Mar 30, 2009
You push mute on remote and enter on tv. the lamp reset screen will pop up. then just press the right arrow and then the enter/select key
Posted on Jan 22, 2013
TB25-LMP replaced but TV will not work
Sounds like the ballast is having an issue. The ballast is easially replaced and should be available from www.tvcircuitboards.com
Feb 10, 2013 | Toshiba 56HMX195 52" HDTV DLP Projection...
Looking for a Halogen lamp parts number and price for a model E44W48LCD.
PN# 6912V00006C
Mats has them for $99.00 1-800-628-1118
Look On EBay
Oct 22, 2010 | Zenith E44W48LCD 44" Rear Projection HDTV
I have an older 48" LCD projection TV (model E44W48LCD). The lamp light came on so I ordered a replacement bulb and installed it. Now i get no picture or sound. Is there a reset switch I might of missed?...
It sounds like you may have a lamp door interlock problem. I have a tip at http://www.fixya.com/support/r5207658-dlp_tv_run_after_replacing_lamp which tells you how to troubleshoot this problem. Let me know if I can provide any additional help.
Thanks for using FixYa and for the generous rating.
hardrocko
Jun 29, 2010 | Zenith E44W48LCD 44" Rear Projection HDTV
I want to know how to reset the lamd on panasonic
HI; The instructions will come with the lamp itself for your model Television, as long as the lamp was an OEM type lamp.(Original Equipment Manufacture)>>>
Dec 21, 2009 | Panasonic PT-50LC13 50" Rear Projection...
Zenith E44W48LCD will not power on
I would suggest a bad lamp then...This is a DLP projection correct?
Aug 14, 2009 | Zenith E44W46LCD 44" Rear Projection...
REPLACEMEN BULBS
just a screw driver. very simple to replace the lamp. Just dont touch it with your fingers as this will shorten the life of the lamp.
Mar 27, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Lg rear projection model: RT52SZ60db
You need to use the original LG RT52SZ60DB remote.
  1. Press MENU buttons on the REMOTE and on the TV at exactly the same time and hold for about 3 seconds (TV buttons are just below lower left of screen)
  2. Scroll down the SERVICE MENU to No. 14 LAMP REPLACE
  3. Press VOL |> button to enter lamp hours
  4. Press OK button to RESET hours, or CANCEL/EXIT to Exit menu
Hope this helps.
Cheerz ;^)
Feb 29, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Zenith e44w48lcd Won't turn on
need manuals for model z32Lc2d ser719192169807
Jan 05, 2008 | Zenith E44W48LCD 44" Rear Projection HDTV
Won't turn on.. Operation indicator is red, Lamp indicator is flashing red??
According to the E44W48LCD service manual, the temperature indicator red light states the projection TV shut down due to overheating. Red (flashing) states the projection TV shut down, check the cooling fan.
Nov 09, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
ZENITH E44W48LCD Ballast
Could be a bad ballast or light light control circuit. I have also seen a burned or bad socket cause a problem with this set. Good Luck
Jun 18, 2007 | Zenith E44W48LCD 44" Rear Projection HDTV
Zenith E44W48LCD 44" Rear Projection HDTV Logo
425 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
