Question about SanDisk Sansa m200 (2 GB) MP3 Player
How to delete songs from sansa 2.0 gb - SanDisk Sansa m200 (2 GB) MP3 Player
SOURCE:
Syd_
  • 47 Answers
SOURCE: BAD TRACK FOR EVERY SONG
Hi tooky. Getting a "Bad Track" message on the E250 may be an indication of memory corruption, music file corruption, or outdated subscription/license info. One solution would be to format your player in Windows Media Player (version 10 or 11): 1. Make sure your player is in MTP mode by navigating the menu as follows: Menu > Settings > USB Mode You would get a choice of "MTP" or "MSC". Please select "MTP". If your player is an "E250 Rhapsody series" player, select "Plays for Sure". 2. Plug your player to your PC and run Windows Media Player. Click on the "Sync" tab and make sure the E250 is listed. Look for the "Format" button (it would look like a "pencil" on Windows Media Player 10) and click on it. Follow the on-screen prompt. 3. Re-load your songs by either copying/pasting your songs to the player or by using Windows Media Player's "Synchronization" feature. You could also format the player while in "MSC" or "Rhapsody" mode by browsing the player in Explorer, right-clicking the drive letter corresponding to the player, then select "Format". Follow the on-screen prompts Another solution would be to update the firmware of your player by downloading the Sansa Firmware Updater using this link from the SanDisk website (instructions are found on this site as well): For standard E250 or E250R "Rhapsody Series": http://www.sandisk.com/Retail/Default.aspx?CatID=1376 Make sure your player is set to MSC mode, or "Rhapsody" Mode The type of music file might also be the cause. If your music files are licensed, purchased or acquired via subscription, you may want to contact the provider for more info on how to re-download the music files. I hope this helps. There are other procedures available but these might actually make your player work normally again. Hoping for the best :)
Posted on Apr 25, 2007
SOURCE: [Sansa e250] Deleted songs and now...
what you really have to do is: 1: Double click my computer 2:Double click Sansa e250 drive 3: Right click on the icon that looks like a disk drive and click format BE SURE TO HAVE BACKUP OF SONGS BEFORE YOU FORMAT!!!
Posted on Aug 23, 2007
SOURCE: deleting songs
If your computer says you don't have any, but your MP3 does you can delete it from your MP3 player. Click on the song that you want to delete and go down to delete song. Click on it and whala! the song is deleted
Posted on Dec 27, 2007
  • 758 Answers
SOURCE: delete songs from sansa e280
Open up your windows media player and click on the sync tab..your device should be listed there..and also it will show you all the songs you have in there...or you can just format the whole player..formatting will erase everything in that player...
Posted on Jan 04, 2008
  • 5 Answers
SOURCE: Sansa e260 How to delete songs ?
This MIGHT fix the problem: Make sure that Windows Explorer is set to show hidden files and folders. In Windows XP, click TOOLS, FOLDER OPTIONS, VIEW and make sure you have selected "Show hidden files and folders".
Posted on May 24, 2008
I am trying to delete songs on my playlist. I
connect your sansa to the computer and via usb cord check computer the hardrive letter e,f,d, whatever right click that letter and then format. this will delete all the songs. or you could open windows media player click sync and then drag and drop songs from your computer to your sansa or visa versa.
Jan 28, 2010 | SanDisk Sansa m200 (2 GB) MP3 Player
Sansa clip+ 4 GB mp3 player. How do you delete
Select the song/book (you want to delete) to play, press down button (Music Options), and press all the way down until you meet delete song/book, press delete song, select yes.
Good luck
Jan 21, 2010 | SanDisk Sansa Clip MP3 Player
How do I remove songs from my Sansa m200 series MP3 player?
pluge the sansa into the usb. go to my computer/computer. look for the sansa icon in that folder. double click, go to music, then right click on the song u want to delete and click delete
Mar 23, 2009 | SanDisk Sansa m200 (2 GB) MP3 Player
Files invisible to Windows still play, can't delete.
Format
This will format your Sansa c200 player’s internal memory. (and erase all songs therein)
1) Select Settings from the Main Menu.
2) Select Format.
3) Select Yes to format the internal memory or No to cancel.
Feb 28, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Need help
The only solution is to delete some songs, if it is a 2 GB and it is a Sansa Clip then the max songs you can get is 450-550
Feb 08, 2009 | SanDisk Sansa Fuze MP3 Player
Erasing music from my sandisk sansa express mp3 player
If u use Rhapsody,pull up the list of artists and song,verify the one that u have 2 of......right click and delete it
Mar 10, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Sansa e250 2.0 GB media player
Ist person, I don't know, but second person, try other USB port.
Feb 22, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Deleteing songs
You can delete them thru My Computer. Double click on the Sansa (m200), inside you will see a Music Folder. Inside is your individual tracks, separated by album names. You can add or delete all music from here. Best of Luck.
Oct 09, 2007 | SanDisk Sansa m200 (2 GB) MP3 Player
Deleting
You can manually delete the music thru My Computer. My Computer>Device Name (c250)>Media>Music You can see all of the music by albums and delete what you want. Please add to this question if you need more assistance. Best of Luck.
Sep 26, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa m200 (2 GB) MP3 Player Logo
23 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Gyula Lacz
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
