Question about HP OfficeJet 6110 All-In-One InkJet Printer
No display only red light
HP 6110 all in one printer. after moving unit I plug it in an only get the red exclaimination point to light up. no displays or anything in the display...please help....could it be wrong power cord?
Try unplugging power cord and phone line at back of unit. Let set for 2 minutes to recycle then plug both back in and see if it re-booted.
Posted on Feb 18, 2009
My hp officejet 6110 all-in-one carriase are stuck completely and cannot remove cartridges either my hp officejet 6110 all-in-one carriase is stuck as for left and want move at all
Try to power off and unplug the printer, then force the carriage to move with your hand
When the carriage moves, place it in the extreme right position, then plug in and power on :D
Aug 17, 2014 | HP OfficeJet 6110 All-In-One InkJet...
How do you preform a "hard reset" on an H.P. 6110
Hello
Do the following
1. While the printer is on remove the power from back of the printer
2. Hold # & 9 key and connect the power pin to the printer
3. Release the keys after a while
4. Printer will display full reset
You are done.
Jul 15, 2011 | HP OfficeJet 6110 All-In-One InkJet...
How do I reset my hp officejet 6110 all-in-one printer? It keeps asking me to align cartridges.
Press menu and then press the Right Arrow key until you get to maintenance screen then press enter.
Option 2 is you align print cartridges.
Automatic cartridge alignment
Perform the following steps to align the ink cartridges:
1. Disconnect the power cord from the unit, wait five seconds, and then plug it back in. This will reinitialize the unit.
2. Print another alignment test page. If the Press Enter to align message is not currently on the front panel display, complete the following steps to print an alignment page:
1. Press Setup or Menu on the front panel (depending on the model).
2. Press the right arrow button (>) until Maintenance or Tools is displayed, and then press Enter or OK (depending on the model).
3. Press the right arrow button (>) until Align Print Cartridges is displayed, and then press Enter or OK (depending on the model).
3. To determine if the automatic alignment is functioning correctly, look into the output tray as the alignment page is printing; a blue light should be visible periodically on the page as the cartridges move back and forth. If this light is not visible, the product will not be able to align the cartridges and will require service. Service the product.
4. If the blue light is visible and the alignment pages are printing correctly, but the alignment pages still fails, there still may be a hardware problem with the unit.
If there are no other printing problems and you wish to continue, use the information in the Bypassing the ink cartridge alignment section below to bypass the alignment. The information from last successful alignment will be used.
If the message keeps reappearing or other print quality problems occur, service the product.
Mar 30, 2011 | HP OfficeJet 6110 All-In-One InkJet...
Officejet 6110- do display/needs attention light on continuously
try this
turn on/off, unplug, plug in, should reset configs. might have to do this a coupe of times
go to applications folder for your computer, dbl click printer icon for make of printer. check settings. print 'test document and clean cartridge heads', this should ensure proper printing formats.
hope this helps and good luck
Apr 28, 2010 | HP OfficeJet 6110 All-In-One InkJet...
Scanner Faliure
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
8011
Jan 16, 2009 | HP OfficeJet 6110 All-In-One InkJet...
The LCD screen on my HP OfficeJet 6110 All-In-One displays the following: Open Door Clear Carridge Jam, then Press ENTER Have changed all cartridges, cleaned inside the printer with pressurized air, tried...
apply greese material on the steel rod on which the carriage moves.or it could also be the problem of the sensor which detects the paper in the printer ,that sensor is moved from its orignal position.
Dec 08, 2008 | HP OfficeJet 6110 All-In-One InkJet...
LCD Display
Check the options on the printer for a contrast or brightness setting. Did you have any problems before?
Sep 18, 2008 | HP OfficeJet 6110 All-In-One InkJet...
Power on,amber loight led on and no action
Exclamation light
The amber light in the shape of an exclamation mark (!) blinks when the unit requires attention. The display will give further information. The light is off when no attention is required.
Sep 25, 2007 | HP OfficeJet 6110 All-In-One InkJet...
HP OfficeJet 6110 All-In-One InkJet Printer Logo
93 people viewed this question
Ben Johnson
