Question about LG Refurbished GOLDSTAR COLOR CGA COMPATABLE 14INCH MONITOR GOLDSTAR
Picture on my CRT 14" Standard TV is going bad, not clear, is "fuzzy" pretty sure I need a new TV but not liking the LCD's as I have tried one but as the TV was on a stand and if I looked at the TV lying my bed, I saw darkness instead of the picture which I think most of the LCD's have nowadays. I have a small room so need a 14" if possible. I have been looking at the normal tv's but need recommendations Thanks
SOURCE: My picture looks like cartoon characters from new commercials
I had recently noticed the same thing happening with mine.Then the left half of the screen turned black and has various red, green, and blue vertical lines. The right half of the screen shows has the picture just fine. It's exactly right down the middle of the screen.
Posted on Jan 03, 2008
SOURCE: 42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Posted on Mar 09, 2008
SOURCE: Fuzzy picture and in a different language
click on "menu".
then move to the "hand" while clicking on lightview
then clivk select/auto
it should automatically select the third from above
then move to the top while clicking on lightview
and now change the language with the "sun" buttons
Posted on Apr 17, 2008
jerryg50
  • 1673 Answers
SOURCE: LG 36" LCD Flashing Picture
Most likely cause:
Backplane lamps, and or the backplane power supply is defective.
I don't know the particular model, but in most of these models, these parts are replacable. I suggest giving out the set to a tech who is experieced at doing this type of work. The parts would have to be ordered from the manufacture.
Jerry G.
Posted on Jul 01, 2008
  • 10 Answers
SOURCE: has fuzzy spots all the way across the screen and just scrolls up
Is the picture fuzzy whether you are waching tv or a dvd or a tape. If it's only fuzzy on tv or dvd or tape then it's the source. If all inputs are fuzzy suspect a bad tv.
Posted on Apr 05, 2009
Fuzzy picture
Sounds like an AGC [Automatic Gain Control] problem with its video IF stage circuit. Contact any service technician, or service center. This is not a user repairable fault.
Gopakumar Gopalan Google
Feb 09, 2014 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Picture went completely fuzzy. What could the problem be?
The tv CRT( picture tube) have a radiaton posion infected in ur tv picture tube.This is how u discharge the CRT(picture tube) get the posion out.Take the tv back cover off.Take video board that connected to the CRT(picture tube) out.Plug it in,so u have a live current to the CRT(picture tube).Find a wire like an AV cable,should be find.One side of the metal,grounded to the metal frame somewhere.Take a long needle plier grab the other side of the AV cable wire,not the metal,(Caution high voltage live current).Come very close to the open CRT(picture tube).U will have a live current arc,than u,will hear a big "POP".U,just discharge the CRT(picture tube).The tv now the CRT(picture tube),now it good,it clear of posion infected in ur tv picture tube.Now,unplug ur tv.Put ur tv,back together.Hook up ur tv signal cable and plug in ur tv,now ur tv picture,will be clear,completely.I do this many times to dicharge fuzzy CRT(picture tube).When i was a tv Tech.for the SONY TV Corporation.
Oct 12, 2010 | Sanyo HT32546 TV
Magnavox tv has cable channels 2-13 only. Lost original remote. Using a universal remote. Tried to auto program. It started scanning but when channel 14 came around, just fuzzy snowy picture all through...
The set needs to be switched from antenna to cable in the setup menu. It is capable of either antenna reception or cable reception. Ch 2-14 are the same frequency for antenna and cable but above 14 they are different. That is why the picture is stoping at 14. After you switch it to cable auto program again. Thanks for using fixya.
Nov 12, 2009 | Televison & Video
I have a Sharp 32" Standard TV ... picture will get fuzzy either due to someone walking by or sometimes if sound coming from tv is vibrating. If we shut tv off and turn it back on it is clear again. The...
Hello: Your problem seems to be in or around the tuner of the television, More then likely you have cold solder joints on the turner that needs to be resoldered. Also check the coax end protruding from the back of the set where u connect the cable and make sure it is not loose, a bad ground on this connector to the turner shield will cause this symptom. My professional diagnostic is that when the television is cold the solder connections are making contact with the board, and as heat builds up in the television while watching these connections tend to seperate and make limited contact, causing fuzzy picture and in most cases no picture just snow...
Sep 06, 2009 | Sharp 32C-240 32" TV
BRAND NEW 42in. vizio 1080 LCD HD 120HZ picture not clear
the tv models in store are usually have samples from blueray dvds. standard dvd players will look fuzzy because it only submits standard dvd picture quality. you can try an upvert dvd player. tho i cant promise picture quality. i have an xbox 360 that upverts the quality. if you get a bluray player i recommend hdmi wires. if you get upvert dvd player and it has an hd outlet red, blue, green wires it might work. i havent tried one myself. if you dont want to spend money on bluray dvds. i recommend an xbox console. it upverts dvds through hdmi or hd red, blue, green wires
Aug 26, 2009 | Vizio VW32L 32 in. LCD HDTV
Poor picture
adjust the antenna! or the cable connection could just be loose or dirty!
Jun 18, 2009 | Televison & Video
I have got wharfedale lcd 42in and a wharfdale dvdr24hd how do you set up the hdmi cable to get clear picture i have tryed taking out the scart lead out and left the hdmi cable in but i only get a picture ...
Sounds like you either have a bad card or a bad HDMI cable. Scarts are not the most dependable when it come to HD imaging there is alot of converting going on espically if the TV isnt NTSC standard to begin.
Mar 06, 2008 | Televison & Video
Fuzzy picture
You might want to try a new cable, otherwise it might be a loose jack that if your daring enough, you could fix yourself
Jan 09, 2008 | Zenith D65W25 TV
Fuzzy and ghost picture
Sounds like Either the cable from the wall to the TV is bad usually this will cause ALL channels to be fuzzy.Or your cable on the outside of the house is damaged.another common problem is the outlet on the wall has a bad connection.If they get painted over with wall paint this will also cause the problem.change the wallplate.If its damaged outside the cable company will usually fix it for FREE.you pay for the service and it their responsibility to make sure you wiring outside the house is working properly.
Nov 03, 2007 | Televison & Video
Fuzzy or blurry picture
Ok with you I can skip the "do you have electronics experience?" questions. With 14 years under your belt you are a pro. So here we go. The problem you are experiencing is called blooming/loss of focus this occurs when there is an increase in CRT anode voltage and control of the electron guns (in the CRT) is lost. The result is the picture spreads and focus is affected. The problem can some times be taken care of by adjusting the focus control However if you have auto focus the auto focus circuitry might be the problem. The common parts (areas) to check are as follows: 1) Focus control (to see if the problem can be soled by adjustment) 2) IHVT anode (test to see if voltage is correct you will need a schematic and a high voltage probe) 3) CRT Socket board ( Check to see if the bias voltages and input signals are correct you will need a schematic, multimeter and oscilloscope) These would be the areas to check, I hope that you are seeing my point here. My next bit advise if not one of your experience, you have that, 14 years of it. However, you have little ones and they are your NUMBER ONE concern, So my advice would be to get the set repaired at a TV repair shop. The reason being is because even though I have named some places to start your troubleshooting, TV repair is not an easy thing and there may be other components that could have gone bad and you don't have the time to do investigative troubleshooting. I wish you well on this issue and take care of those little ones. Respectfully Submitted, Shuttle83
Dec 13, 2006 | Sharp 32C241 TV
Computers & Internet Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
