Question about HP Officejet Pro L7680 All-In-One Printer
Fax confirmation Is there a setting so it will print out a confirmation stamping the date and time the fax went thru?
    President:
  • 2,692 Answers
How do I print the fax confirmation page on the x4270? Are the instructions printed anywhere? How to set the time?
here's the solution to enabling fax confirmation: press the fax button on the printer front panel,the press option 16 or until advanced fax appears.(you can also press the right arrow to get to that option). press select push options twice.fax confirmation menu will come on the front panel display.push the right arrow button. The following options are displayed: Off - Select this option to receive no confirmation. Print for all - Select this option to receive confirmation whenever a fax has been sent, whether successfully or not. Print for errors - Select this option to receive confirmation (an error page) only when a fax has not been sent/received successfully.
***************************** here's the solution for setting time on printer display on the printer control panel,push fax push options until EDIT DATE/TIME: appears on the printer display to change the date: - press select - use the keypad buttons to enter the date. Note: If you make an error entering the date, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction. - press select
To change the time: Press the right arrow once, and then press Select. Press 1 for 12-hour time or 2 for 24-hour time. Use the keypad buttons to enter the time you want your All-In-One to display. Note: If you make an error entering the time, you can use the left arrow button to navigate to the number you entered incorrectly, and then enter your correction.
Press Select. If you are using 12-hour time, press 1 for AM or 2 for PM. Note: If the time is entered incorrectly, the time shown will be the default.
************************************************** i will also put in the link for the manual for additional assistance: http://www.lexmark.com/publications/pdfs/4200/eng/frameset.html
Jun 12, 2011 | Lexmark X4270 All-In-One InkJet Printer
How do I change the date stamp on my fax machine?
just change the date under utilities, initial user data, date& time
Jul 13, 2010 | Konica Minolta Minolta FAX3900 Digital...
Is there a way for me to leave a date/time stamp when sending a fax on my intellifax 1940CN?
if you enable send report you can get an a4 page with time and date confirming that the fax has been sent, but when set up it will print for every fax. the other option is to have it print on error only and you can manually print report of sent recieved items( all date and time stamped) with the number sent to as a list.
Aug 10, 2009 | Brother IntelliFAX 5750e Laser Fax
Date & Time Stamp
The date is printed on the photos using the "pict bridge" software. The date printing option is set on the computer, not the camera. If the printer has it disabled or it is a printer that doesn't support it, you won't get the date.
Jun 19, 2009 | Fuji Finepix Z20fd Digital Camera
Wish to print outgoing fax log date/time/number
I don't think there's a log you can print but you can do the following. Not quite what you want, but better than nothing...
You need to set the fax confirmation option to log faxes before you send anything. The default option is off, so you won't be able to get a fax log for anything you've already sent unfortunately.
1. Press Setup
2. Press 2 then press 1. This displays the Print Report menu
3. Select Fax Confirmation
4. Press c00424037.gif to highlight one of the following, then press OK
Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
May 06, 2009 | HP Officejet 5610 All-In-One InkJet...
How do you update the time stamp on faxes/fax confirmations on a Ricoh Aficio 350?
should be under "user tools", "System settings, "timer settings"....."time/date", or something like that
Mar 10, 2009 | Ricoh Aficio 350e Printer
Print out confirmation with image on page
press
function
7
monitor key slowly 4 times
set
look on the sheet for confirmation + image parameter
set with above procedure but use number 74
set
Feb 04, 2009 | Panasonic Panafax UF-595 Plain Paper Laser...
HP Officejet Pro L7680 All-In-One Printer Logo
143 people viewed this question
Ben Johnson
