Question about HP OfficeJet 7410 All-In-One InkJet Printer
2 sided deluxe addition prints upsidedown on the other side at the bottom of the page and can't use it because it should be at the top and not upside down, help
    President:
  • 2,692 Answers
How can I do a 2 sided print
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER
If your printer does not have a duplex unit then the printer cannot print double sided pages automatically.
You can print double sided pages but you have to do it one page at a time.
First print Page 1 then place the page back into the paper tray, but turn the page upside down and the print Page 2.
Then print page 3 on one side then page 4 on the other side and repeat for the rest of the document.
I suggest you try a test page first, to get the printing the right way up on both sides of the page so it reads correctly.
Mar 31, 2013 | HP OfficeJet Office Equipment & Supplies
Tip
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER If your printer does not...
DOUBLE SIDED PRINTING USING A SINGLE SIDED PRINTER<br /> If your printer does not have a duplex unit then the printercannot print double sided pages automatically.<br />You can print double sided pages but you have to do it one page at a time.<br />First print Page 1 then place the page back into the paper tray, but turn thepage upside down and the print Page 2.<br />Then print page 3 on one side then page 4 on the other side and repeat for therest of the document.<br />I suggest you try a test page first, to get the printing the right way up onboth sides of the page so it reads correctly.
on Dec 18, 2010 | Office Equipment & Supplies
Which way do I insert the transparency into my front loading MP 560 Canon Printer.Shiny side up or down Thank you V
It depends on which side you want to print on. For transparencies, you want to print on one side only. Most likely, you want to print on the shiny side; essentially as if it were a glossy photo. Load the transparency so that the shiny side gets printed on. Don't know that part? Front loading printers are the easiest to determine which side is printed on. Look at where the paper goes in and where it comes out. Think about it; for single sided printing, the paper isn't being turned around inside; merely rolled around an internal roller, then back out. Watch what happens to the paper the next time you print on a single side. See if the top of the printed page came out first, or last.
The most common designs of front-loaders have the paper come out above where it went in. The paper curls around the bottom of the internal roller and comes right back out on top. Therefore, the printed side started out on the bottom, then curled around the internal roller and came out with the printed side up.
Most front loading printers have the top of the printed page come out first; therefore, the same edge that went in first, got printed on first. With that in mind, if you ever want to print on the unprinted side of a piece of paper (that is already out of the printer), obviously keep the printed side up, but since the top of the printed side came out first, you need to make sure the top goes in first to come out first for the back side.
Your Canon 560 printer has duplex printing, so it is a good idea to run your test to see what happens when printed on a single side, and what happens if you use the duplex-mode. For duplex mode printing, after printing on one side, the printer pulls the paper back in to print the other side automatically. Think about how much space is inside the printer. Depending on how much data the printer can store, either the first page is printed, then the second page, or the second page is printed first, then the first page. It depends on how the printer wants the page to come out. You can run a simple test and see exactly what happens.
Since the printer cannot easily turn the paper around, it merely starts with the opposite end of the first printed side when it prints on the back. If the top of the page came out first for the first printed side, the printer prints the bottom lines of the second page of text working back to the top in reverse order. As a result, the bottom of the page comes out first, with the top coming out last.
Some duplex printers can store so much data that the determine how the second page will look, print it first, then print the first page. Watch to see what yours does.
Worse comes to worse, mark a sheet of paper in one corner, insert it into the printer, then print a document that contains only the period character and see where it is printed. By knowing how you put the paper in, and where the period was printed, you can tell how to handle any situation. By the way, the period character was chosen because it will be so small that most likely you can use that sheet again.
Jan 07, 2011 | Computers & Internet
Hi how do you print double sided please
This printer does not have a duplex unit and cannot print double sided prints automatically.
The only way to print double sided is to print page 1 and the insert the page back into the printer tray with the page upside down and then print page 2. Repeat this for the other pages.
You need to do a test print first to work out which way to insert the page upside down in the printer paper tray so the printed text is aligned correctly on both sides of the page.
Nov 29, 2010 | Canon PIXMA MP530 All-In-One InkJet...
How do you print on both sides of a sheet of paper
Unless you are using a duplex "Multifunctional" copier(with fax.) most plain fax. machines are not duplex and will only print on one side of the page.
If you have a machine capable of rx duplex printing please specify make and model for additional help.
Mar 22, 2010 | Office Equipment & Supplies
Describe your Ricoh SPC821DNX does not duplex Problem The 2nd page is turned upside down. How do I get it to print right side up.
Sir try this when making duplex invert the original the top part of your original be place at the bottom part
Feb 24, 2010 | Ricoh FT5832 Copier
Sharp arm355N/fx/srg
When you select double sided printing in the printing options, there are two choices--book mode or tablet mode. I think you want book mode.
Aug 28, 2008 | Sharp AL-1655CS Laser Printer
Biz hub 450
Change binding from auto to either left or top.
Jun 18, 2008 | Konica Minolta bizhub C450P Laser Printer
Double sided printing
There should be a setting in the 2-sided properties for binding orientation.
For a MAC, do this:
On the File menu, click Print.
Open the Two-Sided Printing panel.
Select the option to print on both sides.
Select the binding orientation by clicking the appropriate icon.
Change any other settings, and then click Print.
Feb 26, 2008 | Computers & Internet
Duplex printing problem
you will need to make sure that the printer software is set to align top-top or top-bottom. You will need to set this within the printer dialog set up.
Jun 14, 2007 | Adobe InDesign CS2 for Mac
HP OfficeJet 7410 All-In-One InkJet Printer Logo
Ben Johnson
