Question about Bryant 462AJC021BA Air Conditioner
COMPRESSOR VC/VH TRIP - Bryant 462AJC021BA Air Conditioner
  • Farley Redfield
    Farley Redfield May 11, 2010
    can you elaborate on VH and VC?
    Sergeant:
  • 340 Answers
It tripped for a reason 1. could just be dirty clean 2. more in depth problem .Tom
Posted on Jun 21, 2009
  • Frank Gibbons Nov 25, 2010
    This error code suggests start cap and relay are bleeding back during the off cycle. Nedd to replace the HSK.
Whirlpool gold dehumidifier trips ground fault
Compressor shorted to ground. You can verify by testing continuity from terminals to a piece of copper, or unplug compressor and run system. If no trip obviously bad compressor
Oct 21, 2016 | Whirlpool Heating & Cooling
I hear a electrical noise from alternator when turn on acc it stops when I remove + from ignition
Hi Could be worn brushes on slip ring or faulty diode on the rectifier. Check all the earths body to chassis, chassis to engine.
Check current draw with ac on and off may have a faulty fan motor or compressor overloading the alternator the old 253 only had a low amp output alternator.
Jul 24, 2016 | 1983 Holden VH Commodore
Registration key
fjhhhhhhhhhhhhdf;ghdfugryutxfvgxhkcsdf;vgjd;sflbvgfvsdkvgdsfljdsfvkdjvdaklfljsd;vlhvfilvh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;vh;udfvhdvhjfihvdfgvnhjxzdvffgbklvdfbjhvnzxlczx;vdfn;kvlb vnbhvk
Jun 22, 2013 | Computers & Internet
I have error code that the indicator flashes six times. It says compressor VC/VH trip. Can you tell me what this means?
could b run capacitor bad, contactor not working properly, the code means a call for cooling but no high voltage present
Oct 16, 2010 | Carrier 38CKC060 Air Conditioner
Need a point setting for ao smith air compressor ac motor model number opa-0297 s# c56b72b2316508j2 work on air machine with motor installed motor will hum and trip breaker can we set points to stop trip...
try running up this motor when its not installed on the compressor,, if it still blows the trips the motor is faulty,, if it runs ok, but hums when reconted to the compressor the compressor if far to tight for the motor to turn the compressor,,,you can not reset the points in a breaker trip they trip at a set curent if the motor is pulling more amps than the trip is set for it will trip the trip to turn off the curent, the motor will pull far more amps than it should if its over loaded thats why its humming its trying to spin up it but cant so it just keeps pulling more and more amps till the trip cuts out
Mar 25, 2010 | AO Smith 2 Hp Spl 3450rpm M56 Frame...
Look to find remote and power supply for vc-c4
The VC-C4 uses a Canon WL-V5 remote control, available at B&H Photo here. They also have a power supply for the VC-C50 here. The VC-C50 is almost identical in specification to the VC-C4, it's just a newer model. The electrical power requirements are the same.
Nov 11, 2009 | Canon VC-C4 Network Camera
What does the error code VC/VH trip mean on a Bryant out door hp cond.
vC/vh Trip or code 6. The start cap and or the start relay is bleeding voltage to the comp in the off cycle. Replace both the cap and relay for the fix.
Jul 09, 2009 | Bryant Heating & Cooling
The light on the control board if blinking 6 times, how do I get rid of it? the light is saying VH VC. David Stowers
I think that you need to turn off power to the unit and reverse the 240v wires that are on the transformer,I think that the polarity it backwards,I had a similar problom with 2 york units,good luck!
Jul 09, 2009 | Carrier 38CKC030 Air Conditioner
Wiring diagram for PowerBright VC-1500W Step Up&Down Transformer
I just had a similar problem but only a couple wires popped out. I took a guess at where they came from and it works again.
Top right corner - left hole - black wire
Middle, right side - left hole - brown, right hole white
bottom centre - left hole - blue and green, right hole yellow and green
Apr 03, 2009 | PowerBright Power Bright PW200-12 12 Volt...
Bryant 462AJC021BA Air Conditioner Logo
829 people viewed this question
Top Bryant Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Mike Squire
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
