Question about Kenmore 62602 Electric Dryer
Whirlpool gas dryer makes buzzing sound when started, stops mid-c
The dryer will buzz the whole time it runs, turns off mid-cycle, will go thru the same procedure after it sits for @10 minutes.
  • Kenmore Master
  • 8,220 Answers
Maybe something fell down into the filter housing. Get the back off and inspect it with the power disconnected.
Posted on Feb 26, 2009
Dryer starts and runs fine but makes a loud buzzing noise from the motor that sounds a lot like the end of cycle signal
FIXED Dryer won't start. Makes electrical buzzing noise - model ...
www.applianceblog.com/.../7655-Dryer-won-t-start-Makes-electrical-buz...
Feb 12, 2007 - 10 posts - ‎1 author
It makes electrical buzzing noise when you press the start button. ... One would think that if it's the fuse that it wouldn't buzz at all but ... unplugged, re-assembled back, hooked back up to hose, turned on and running hot .... The belt was fine. ... Kenmore gas dryer 70 series is making very loud buzzing noise.
Troubleshooting Your Dryer Noises ' PartSelect.com ...
? 4:32
https://www.youtube.com/watch?v=Tk1YezyYMDY
Aug 26, 2011 - Uploaded by PartSelect
In this video you'll learn why your dryer may be making a variety of ... that is not only making a grinding noise but it also makes a loud banging noise. ... it's been drying about 15-20 min. it startsa loud humming sound. ... The dryer is working just fine, but I am concerned about the noise as it sounds electrical.
DRYER BUZZING NOISE - Dryer For Sale
Dec 18, 2015 | Amana DLE330RAW Electric Dryer
I have an electric dryer, Estate by Whirlpool, It runs perfectly fine on no heat, it also works well on the cool down cycle of a regular cycle. However, if you try to use it on anything else, when you push...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 16, 2011 | Dryers
Whirlpool Supreme Dryer rumbles while turned on then stops mid cycle. When I push the start button I hear a buzzing noise, then a click and then silence. After the dryer sits for a while, it will start...
Chances are it's the drive that drives the belt around the drum, or the motor is on its way out. Have a technician inspect the belt/belt drive system as well as the motor.
Jan 29, 2010 | Whirlpool LER4634J Electric Dryer
Whirlpool dryer makes buzzing sound when flame should start.
Sounds like the valve is trying to open and the buzzing is the restriction of it opening. Coil is obviously correct, but actual solonoid is sticking. Replace it and see. If flame isnt detected, it will stop.
Sep 21, 2009 | Dryers
Push start button but nothing happens but buzzing noise
Is Kenmore a Whirlpool?
  • Here is what happened.
  • Stopped running mid-cycle.
  • Dryer set idle for about two hours Then I pushed start butten again.
  • It ran fine to finish load.
  • Next load it was totall dead and silent and remains that way.
  • The vent hose was unobstructed.
May 04, 2009 | Whirlpool Dryers
Kenmore gas dryer buzzes but does not run
sounds like the start windings in the motor have gone bad. The only way to fix this is to replace the motor.
Feb 04, 2009 | Kenmore 73932 Gas Dryer
Kenmore Clean Touch dryer making buzzing sound and
Ya, happened to me. Sounds like you may have a clogged vent. (in the tube, or the dryer itself. Try cleaning that out really good. Then, double check that the venting is secured properly. If not, may overheat and shut down. I think that's what's going on. After you clean tubing (And the inside tube on dryer), the buzzing will continue for a while (days) until itr resets. If it runs after this, but still buzzes, that's your problem. Hope this helps you!
May 09, 2017 | Whirlpool LGQ9858P Gas Dryer
Kenmore 62602 Electric Dryer Logo
177 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
