Question about Kenmore 24032\24036 Top Load Washer
My Kenmore 80 series washer won't agitate but it will spin. I have replaced a coupler before, but this problem seems different. Any help?
  • sg88 Feb 18, 2009
    Thanks for responding. I checked the lid switch. The "lid strike" is still there and makes contact. The screws are tight. Is there any way to know for sure if this is the problem? The model number is 110 20852 990. It started making a loud clicking sound when it should have been agitating and it was just spinning slowly. It will go into a complete spin and drain. What do you think?
  • sg88 Feb 18, 2009
    Thank you so much. I believe there has been something leaking. I'll check it a little further, but it sounds like it is probably the gearcase. You have been very helpful. I'm glad there are still people around willing to help. THANKS!!
I have the same problem with mine.. Did the gearbox change fix it?
Posted on Mar 21, 2009
  • 5,911 Answers
This problem is commonly attributed to a lid switch malfunction. If the model number you have this listed under is correct, the lid switch is mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If your washer is not configured in this manner, please post back with your COMPLETE model number (located along the tub rim under the lid) so I can confirm how your washer IS configured.
A replacement lid switch can be purchased on line at searspartsdirect.com, repairclinic.com or appliancepartspros.com. All three sites offer competitive pricing, so shop all three for the best price. For instructions on how to replace a lid switch, you can refer to my profile and look under my "Tips and Tricks" for links for Replacing a Lid Switch. If you still need assistance, please contact me and let me know.
Posted on Feb 17, 2009
  • Jeff Rockwell
    Jeff Rockwell Feb 18, 2009
    Thank you for posting your model number. This makes it much easier to diagnose. Confirm your coupler is not cracked or broken again. Sometimes they crack or part of it shears off and will still engage. When you replaced it before, did you replace it with a coupler that has a steel grommet in the center. These are the new improved couplers that resist breakage (not break proof, just resist breaking better). The part number is 285753A.
    If the coupler or bushing is not damaged, you may have a gearcase (transmission) failure. A tale-tell sign of a gearcase going bad is an amber colored oil leaking out of it, and/or a grinding sound. The slow spin is another sign. If you determine the gearcase is faulty, this is still a simple repair if you wish to attempt. The part number is 3360629 and can be purchased at appliancepartspros for a about $143. You can find step-by-step instructions on how to replace the gearcase under my profile in my "Tips and Tricks" section.
    If you still have questions, or require additional assistance, please let me know.
Lumpy816
  • 246 Answers
SOURCE: Kenmore 80 series won't spin
Some models will agitiate for a couple of minutes even with the lid open. Try listening when you close the lid for a "click". If it is missing you may have a bad lid switch.
Posted on Jun 13, 2008
  • 4 Answers
SOURCE: Kenmore 90 series washer, wont spin, coupler?
my washer wouldn't spin or drain and it was a baby sock stuck in the pump! unplug everything and then take the hoses off and look in the pump! hope this helps!
Posted on Mar 10, 2009
  • 112 Answers
SOURCE: I just replaced the transmission on my Kenmore 80. No agitation
your motor turns one way for the spin cycle and the other way for agitate. remove the coupler and test it that way.
Posted on Feb 04, 2010
  • 1937 Answers
SOURCE: Replaced Kenmore 90 coupler - now NOTHING works!
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
The first and easiest question is: Did you remember to re-connect the Lid Switch???
If it still won't agitate or spin, I'd check that the Motor coupler was installed correctly and hasn't destroyed itself.
I'd also test the switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part and only requires you to access the console and remove the cabinet.
Posted on Jun 01, 2010
blueextc3221
  • 15935 Answers
SOURCE: kenmore 80 series washer agitates but won't
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question((&&^^
Posted on Oct 01, 2010
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
Feb 04, 2010 | Kenmore 24832 Top Load Washer
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
The 80 series washer wont agitate or spin. all i
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Jul 07, 2009 | Kenmore 22422 Top Load Washer
Kenmore washer will not spin
KENMORE 80 SERIES 110.92582110 - NOT SPINNING. I REPLACED THE TRANI, CLUTCH, COUPLER BUT I FORGOT TO PUT BACK IN THE AGITATOR WASHER. IT STILL WON'T SPIN SO WHAT NEXT
Jun 12, 2008 | Kenmore 23822 Top Load Washer
Kenmore 80 series not agitating
Most likely you have a bad motor coupler. If you open the console and remove the two brass clips, this will let the front, sides and top all come off as you tilt it forward. At the botom center, you will find two metal clips holding the pump on. Remove. You will find 2 screws holding similar clips holding the motor on. Removed. On the back of the motor, is your coupler. Replace. Then re-assemble.
Jun 08, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
2,177 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
