Question about Canon imageRUNNER C3220 Color Copier
Scanning from a canon 3220
How do I scan to a network computer from a Canon c3220?
Thanks
  • brian martin May 11, 2010
    in order to scan to file (computer) your machine need to have Universial send
  • 149 Answers
Yes, the type of scanning mentioned by the previous answer is called 'pull scanning' and you will have limited functionality. You have to load the document on the copier, turn on the scanner (nobody can use the machine now) return to your desk which I hope is not far from the copier because the doc stays there until you 'insert picture from scanner' then the machine scans the document and you run back to the copier to get it before someone throws it in the trash! It's a free system but limited. To have a fully functioning 'push scanner' where you send a doc as you stand at the copier to either a file on your computer, server or an email address you would need a universal send kit installed. If your machine has one you'l see the option tab called 'SEND' along the top of your screen. If you have this you're in luck. All you need is to enter the necessary network and email settings which can be done by any half decent network administrator vis the 'system settings' area from the addtional functions screen (accessed by pressing the head key with a star in it). Once this is set up merely select the 'SEND' tab and insert your document. In the top right hand corner will be a drop down menu reading either 'FILE' 'EMAIL' or 'FTP' If you want to send it to a shared folder on your network (anywhere) you select the 'FILE' option and then use the drop down menu in the centre of the screen to search the network for your shared folder. Select it and then press ok then the start key - IT'S GONE - IF YOU'RE LUCKY. To send to email you just select the 'EMAIL' option and enter the email address of the recipient and ok then start and you're in business provided that all the network and email settings are correctly entered and permissions for network access is set up. The machine needs a email account registered for it as well. I'm tired now - good luck.
Posted on Jul 06, 2009
    Sniper:
  • 57 Answers
You have to install the colour network scan gear first. Run scangear and search for the canon. Ounce you have completed that, you can scan from the canon with any other application software.
Posted on Jun 20, 2009
Error code 000804-004
www.digitalcopiersolutions.com/clc-3220.html
Color Copier Canon ImageRunner C3220, Canon's true definition of multifunction has been met. should find all on here x
Mar 14, 2013 | Canon imageRUNNER C3220 Color Copier
I can not scan from my color image runner c3220 to my computer. Its on a network, and I installed the network ScangearTwain Driver. It see the scanner but does not allow me to scan. I can print to the...
its a titywity prob sir. i have also faced it .it sometimes work some times doesnt. if u have installed the scan gear then u have u use a scanner software life adobe etc to access the scanner through it. u can also use word,photoshop,corel etc to access it
May 26, 2011 | Canon imageRUNNER C3220 Color Copier
How can you print the Configuration Page on a Canon 3220? We are trying to find out what the IP address of the printer is.
For a Canon C3220:
- Choose the Printer tab on the touch screen - Under Printer Status, go to Settings - Go to Functions - Go to Print Pages - Select Configuration
The configuration page will print out. Thanks for using FixYa!
For configuration page instructions on other copiers, printers, and fax machines, check out the How to print config pages blog.
May 03, 2011 | Canon imageRUNNER C3220 Color Copier
How do you get into service mode on the canon irc3220 ?
To enter the service mode on the 3220 just press "additional functions" key then press 2 and 8 at the same time then press the additional functions key again. Be very careful what you do in the service mode as you can mess things up quickly if you change the wrong settings.
Good Luck and Thank You for using Fixya
WheatlandServices
Jan 24, 2011 | Canon Color C3220 Copier - Color...
How to install canon 3220 to the network for printing
Hello ,actually its a very easy way to install canon 3220 to a network just download the driver from canon official site :software.canon-Europe.com
go to printers and faxes add printer press local then next choose create port choose stranded tcp/ip write down the same ip of the copier then press next ,choose have disk and specify where the file u download it from the site and after that choose from the menu canon clc3220 c1pcl5 then press ok so now the printer driver is defined. now at the other side (photo copier ) press * system management network settings choose TCP/IP and give the machine IP turn off and the on the machine to save the changes .now the machine is connected through the network :) for more assistant t here is my email mramlawi@gmail.com regards :)
Nov 09, 2010 | Canon imageRUNNER C3220 Color Copier
Standby number of watts with a canon 3220
Hello. Canon rates the power consumtion in WH (watts per hour).The answer is 48 wh
Jun 08, 2010 | Canon imageRUNNER C3220 Color Copier
Network ScanGear can't discover Canon IR 3220
Had the same problem with my Canon IR2018i... After spending about all day stuffing around and ready to give up... I read in the Color Network Scangear User Manual that
"Only scanners on the same subnet (network with the same network ID) as your computer are displayed in the list"
So I went the the TCP/IP settings on my copier and changed my subnet mask from 255.255.255.0 to 255.255.255.255 and magically my scanner appeared....
Give it a go...
Jun 24, 2009 | Canon Office Equipment & Supplies
I have installed the drivers for both my canon imagerunner 3220 and my 3300 but i still cannot print to it or scan from it. I have the network cables connected... I can ping it do i have the right...
Enter the device IP into your web browser. This shoudl load its web management interface. If it does not, you have an IP connectivity issue. You must power cycle the unit after changing IP settings.
press additional functions, report settings, network, user data list, yes. Check to see if DHCP is enabled. If it is, the IP displayed in the report may not be correct. DHCP should be off in most cases. Verify IP shown here.
Double check for link lights on the network cable.
Jan 12, 2009 | Canon imageRUNNER C3220 Color Copier
Quality
Make sure you are only use canon toner NO compatible toner. Same thing on the drum unit. Also make sure scan lense under glass is clean and fixing film unit is good shape,good luck.
Jun 25, 2008 | Canon imageRUNNER C3220 Color Copier
Canon imageRUNNER C3220 Color Copier Logo
1,032 people viewed this question
old marine
old marine
