Question about HP LaserJet 9500hdn Printer
Error 10.90.02 I replaced the Magenta cartridge and Drum and still get error 10.90.02. Any ideas?
    Problem Solver:
  • 8 Answers
I have had a similar problem with my printer, It turns out that the aftermarket toners that I was using were using a sort of re-certified circuit board. When the chip embedded to the toner is not new some times it can not be read by the machine correctly.
Also have your pulled the cartridge and put it back in again? It is possible that the chip on the toner is not making proper contact with the printer.
Posted on May 23, 2011
59.6M PRINTER ERROR
This error indicates a problem with the magenta drum rotation motor. Remove the magenta drum unit and reseat it. Restart the printer. If the error still continues then replace the drum. You can also look in the install slot for the magenta drum to see if there is any visible damage.
May 28, 2011 | HP LaserJet 9500n Printer
141 error
From the manual --
141 -
Drum Up/Down, Color:Magenta
When the magenta drum has been detected in an abnormal position
If you have just done some maintenance on the printer, check to see if the magenta drum is properly
seated in the slot. Then also make sure that the magenta toner cartridge is mounted properly to the
drum assembly. Both have to be properly mated in the printer to avoid the error.
Mar 30, 2011 | OKI C9200 Led Printer
Error code E000020-01b0, E000020-0260
E020 is a Drum/developer error code
-01b0 is a yellow drum error
-0260 is a magenta drum error
drums need replaced
7622A001AA Yellow drum part#
7623A001AA Magenta drum part#
7624A001AA Cyan drum part#
7623A001AA Black drum part#
Aug 20, 2009 | Canon imageRUNNER C3200 Copier
141: fatal error OKI Printer
This can be caused by the transfer belt damage or the contact group damage. 141 is an error of Magenta ID up/down. Possible reason though - check the place next to the belt at the right hand side near the Magenta drum location. You'll see the terminals sitting in the housing with the spring. If the housing is fell off or the spring is missing - that can cause this error. Otherways you'll need to replace the transfer belt.
Jul 30, 2009 | OKI C7300 Led Printer
Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
51.22 is a Magenta laser scanner error.
Try removing the magenta restarting the printer and reinstalling.
If that does not work you likely need a laser assm.
You might want to call a tech. to replace.
Apr 01, 2009 | HP Color LaserJet 2600n Printer
LED Head Missing, Color:Magenta
Take out the magenta cartridge to the right upper indside wall of the printer you should be able to see a small rectangular window, give it a blow of wipe with a cloth, do the same to the corresponding part of the m toner, put the drum and toner back, shut the lid and everything should be ok. If not contact oki for a replacement drum/cart.
Mar 23, 2009 | Office Equipment & Supplies
"Install Cartridge" Error
Have you tried to clean the contacts on tonercartridges and the opposite HV contacts in printer? The contacts are on the left side of toner cartridges
Jun 18, 2008 | HP LaserJet 2500 Printer
Magenta cartridge empty
When you take the toner cartridge off the imaging unit, is there magenta toner in the open slot of the IU? Assuming that there is nothing wrong with the toner cartridge, you are possibly looking at a bad engine control board.
Jun 11, 2008 | Xerox Phaser 7300DN Laser Printer
HP LaserJet 9500hdn Printer Logo
609 people viewed this question
Ben Johnson
