Question about Bosch Kitchen Appliances - Others
Electric tripping i have a big house and have a lot of appliances but sometimes my electric keeps tripping is there anything i can buy to boost my electric,
  • 83 Answers
You most likely need to limit the number of appliances in use at one time. Microwaves , refrigerators typically have there own circuit. You will most likely need an electrician to run additional circuits for your kitchen.
Posted on Feb 15, 2015
  • 653 Answers
There is no way to boost the amount of electricity to your kitchen, short of having an electrician run additional outlets on a new circuit. It sounds like you have too many appliances plugged into one circuit. Most kitchens built since the adoption of building codes have two small appliance circuits, usually on opposite sides of the room. Try moving the electric kettle across the room. If that doesn't work, try unplugging or at least not using the toaster, toaster oven, electric griddle, coffee maker, microwave, or other high demand appliances at the same time.
Posted on Mar 01, 2009
  • Fahr Quad Mar 07, 2009
    So how did that work out???
MOD# C880-6402990 ser IMF0216838 Type 30S My issue is I had my microwave plugged into the extra outlet. I turned on the microwave and then it seems like it tripped something in the stove.
Check the circuit breaker for the house. It might be tripped. Sometimes a breaker will trip without moving the handle to indicate a trip. Reset the breaker several times.
May 15, 2017 | The Kitchen Appliances - Others
Goldstar dehumidifier dh404ey7 starts and runs about 5 mins., then trips house breaker in all different outlets.
any appliance that trips the fuse or breaker should not be tried to use by homeowner this is a fire hazzard as an electric short is a dangerous situation to have in any home , replace unit ! ck with mfg for recalls first and warrentys as well then contact your power company sometimes they give rebates for appliance upgrades but they require old ones back in order to pay u money on them
Oct 02, 2014 | Goldstar Dehumidifiers
Clarke power washers 150
Need more info:
What fuse? the one at the end of the cord on the pressure washer? Or the circuit breaker on your house?
If it is the one on the cord it may have gone bad. To test replace it with normal plug (non-GFI) and plug it into an outdoor or bathroom GFCI (GFI) outlet. If it still trips that outlet then there is a ground fault in the device which may be minor or major.
If it is a home circuit breaker remember that electric pressure washers use a lot of power - typically 1500 watts. If anything else is plugged in it can trip the house circuit breaker.
Jun 04, 2014 | Garden
When i start cutting grass for few minutes my lawnmower will trip the house breaker that is a problem
You may have an electrical circuit you are plugged into that has too many things running on it. Like appliances etc. To run an electric mower you should have a separate line right from the electrical panel as the mower does draw a lot of power. Most older homes are not wired to run these things. Sometimes a person will hook into a receptacle closest to the outside where they want the hydro run outside and they do not know what all is on that line.
Feb 18, 2014 | Black & Decker 19" Electric Lawnhog...
GE electrical house breakers keep tripping. Any problems or recalls
You may have overload that power circuit with too many appliances.
Check the load of each of the appliances on that power circuit, add them together and check to see that it does not exceed the rating of the circuit breaker.
You have an overload or short/fault on an appliance on the power circuit that is protected by that circuit breaker.
To identify the faulty appliance, disconnect all the appliances on that circuit and then connect each appliance one at a time to see when the circuit breaker trips out. When that happens you have identified the faulty appliance.
Jan 21, 2012 | GE Hammering
How do I boost the signal from an at&t 2wire dsl modem so that the signal will work better in some parts of the house.
for wireless signal 1st thing to consider is the EMI's (eletro-magnetic interference) anything that is near that modem that produces static electricity, radio frequency and magnetic energy (eg. cordless phone, speaker, anything electronic...) isolate the modem at-least 6 feet away from this said EMI's.
2nd you may check on the the wirelss settings on your modem's GUI(interface) see the link:
wireless channel and power settings and the only once you should change... channel such as 1,6,7 are sometimes used by other device (wireless phone, neighbor's router) power settings: as you place it on a higher number it gives longer distance but gets thinner space(area)
consider the red signals as you place the power higher the signal gets longer but thiner.
lastly wireless doesnt penetrate walls/ glasses it only bounce back and forth to it... so less wall or interference the better chance of going directly to the access point...
if you really havea big house try consider buying wireless booster/repeater...
Sep 02, 2011 | 2wire (1000-400108-001) Router
Electrolux EOB 6632 oven trips main house circuit breaker if used above 180c. Installation electrician has done whole house test, says everything normal, must just be a particularly sensitive ciecuit...
Hi, welcome to FixYa! my name is Shaun. I hope i can help you out with your question. Your main house breaker is tripping over 180C because of the amount of current your oven is drawing. Keep in mind that an oven is capable of pulling up to 1/4 the amount of amperage of your total house current capacity, up to 50 Amps. This is assuming you have a typical 200 Amp main breaker. Add this in with your heating/air-conditioning, up to 30A, if electric, your water heater, 25 A if electric, and whatever lights and appliances you have plugged in and turned on, you can imagine how quickly those amps add up when your oven is on. Your oven breaker won't trip because you're not exceeding 50A on that circuit, however if your total household load is exceeding 200A, your main will trip. Also, breakers lose efficiency over time. Sometimes they can drop current capacity by as much as 25%. So your best bet is to replace your house main and see if that fixes your problem. Hope this helps out. Have a good day!
May 05, 2011 | Electrolux EOB6632 Electric Single Oven
Grill trips my electrics on Stoves 720EF
I had problems with tripping and it was a faulty RCB on the consumer unit. But it wasn't just one appliance causing the problem.
Have you isolated it to the top or bottom oven. If it is the main oven, then it could be anything associated with the operation of that component, i.e. the oven control knob,the oven thermostat, the element, the element fan, the overheat thermostat all could have insulation that is breaking down that could cause this problem.
Before you go and buy anything and if you have the time and patience and confident enough and know what you are doing, I would remove the oven from the cupboard, take off the top and back covers, note the wiring for the element, take the leads off the element and run the oven with the element disconnected and see what happens. That should prove whether it is the element or anything else.
Jun 06, 2010 | Stoves 720EF Electric Double Oven
Our miele condenser dryer with the miele washing machine will often trip the whole house's electricity. Sometimes it will trip on the house circuit board. while other times it trips the external trip...
have the neutral power connection on that circuit and back to the main house panel and then have the neutral connection checked at the power companies side also, it sounds like you have a high resistance neutral connection somewhere in the circuit and its looking for another return path due to the high resistance on the line to another feed circuit line to make connection
Dec 07, 2009 | Miele Novotronic T220 Electric Dryer
The electric keeps tripping in my house, why is this?
it is something that is being pluged in or a short in 1 of the plugs on that circut
Dec 15, 2008 | Dewalt DW824 5" Electric Angle Grinder
Kitchen Appliances - Others Logo
636 people viewed this question
Top Bosch Kitchen Appliances - Others Experts
Martin Olney
Martin Olney
Level 1 Expert
Oloyede Monsuru
ray gallant
Are you a Bosch Kitchen Appliances - Other Expert? Answer questions, earn points and help others
