Question about Emulex NETQue Print Server
How do you change the default gateway on a Netque print server?
Define node ip 35.131.1.50 gateway default
Posted on Apr 16, 2009
My print server cannot be reset to the factory default for some reason. I have tried holding the reset button for 10 secs, but without luck.
I have some devices where I have to hold the reset for 20 seconds. So try holding it longer. And make sure the print server is powered up when you do it.
Feb 17, 2016 | Belkin (F1UP0001) Print Server
Not able to change the default gateway. It just takes what ever the IP address is
Are you using DHCP to obtain the IP address? If so, typically the gateway will be automatically assigned, and if the DHCP server does not have a gateway programmed in the printer will default to it's own address. Change the IP setup to manual and you will be able to put in any address you want for the gateway.
Jul 12, 2011 | HP LaserJet 4250n Printer
Setting up my DP-G310 for network printing in Windows XP
Check your network settings in your computer.  If the gateway is different than 192.168.0.10 then use that address to get into the gateway.
Oct 07, 2008 | D-Link Wireless Products: DP-G310 AirPlus...
Unable to get DNS Server Addy
YOU HAVE TO TRY TO INSTALL ORIGINAL SOFTWARE , SOME
OF THAT MAY BE CHANGED BY USE - DELFO
Mar 20, 2008 | NetGear DG834G Router
D-Link DP 311U wireless setup
Had same problem. Got it to work!!
I have DLink DP-311U and 2Wire Gateway router/modem 2701HG-B.
Solution: Connect DP-311U to router via network cable.
Then you can see it either with PS Admin or with browser http://192.168.0.10 should be default IP address of DLink Print Server. Set Connection Mode=Infrastructure, ESS-ID=2WIRExxx (xxx is your number of the router) - this is your network name, and wireless channel=1.
And the most important - change your IP Address to 192.168.1.xxx - xxx=choose a number over 64 if it's not taken already.
On your Gateway page: http://gateway.2wire.net/xslt?PAGE=J46&THISPAGE=A02_POST&NEXTPAGE=J46
Set Network Name=2WIRExxx, WIreless Channel=1, enable SSID Broadcast, Disable wireless network Security.
Once you get those numbers in, check connectivity with above programs with cable connected, or typing new print server IP address in browser. Then disable cable and check again. You should be able to see the box. Then connect print server to printer and make sure your printer settings on computer point to new IP address.
Feb 09, 2008 | D-Link DP 311U (DP-311U) Print Server
How to install pocket printer server
Your DHCP server will keep track of which MAC Addresses have been given what IP addresses. From there, find the IP address of your Print Server. Ping the IP address to confirm IP connectivity between your computer and the print server. You should then be able to upgrade the firmware.
Aug 07, 2007 | Emulex NetQue Pro2 (NP02) Print Server
Cant change or remove the password.
with some system you will have to use ctlr H before the password system
this removes the space so the password is correct
Aug 03, 2007 | Emulex NETQue Print Server
Contact
The following link will tell you how to connect a serial cable & set the address: http://205.200.75.226/support/printer/emulex.html
Aug 02, 2007 | Emulex NETQue Print Server
Changing the IP address
check with the manual of the server that it is having web based management. If yes make your computer ip and subnet mask as per the ip and subnet mask of print server. open the internet explorer type the url as specified in manual enter the username & password as per manual. there will be the setting page displayed where you van change th eip of the print server. if not please write me which type of management it uses to access the settings.
May 10, 2007 | Emulex NetQue Pro2 (NP02) Print Server
Emulex NetQue Pro2 Print Server how do I connect to it
Oct 04, 2006 | Emulex NetQue Pro2 (NP02) Print Server
Emulex NETQue Print Server Logo
502 people viewed this question
Top Emulex Computers & Internet Experts
David Payne
David Payne
Are you an Emulex Computer and Internet Expert? Answer questions, earn points and help others
