Question about Canon CanoScan 4200F Flatbed Scanner
I have CanaScan 8000F Need instruction on how to adjust the settings to scan the 4 35mm slides from the mounting slide frame. I bought this scan, second hand, no instruction manuel. Thanks
    President:
  • 2,692 Answers
Here is your products support weblink for you to download an instruction manual for your model:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=235&modelid=10445#DownloadDetailAct
Posted on Feb 17, 2009
If I have it right your product scans photos but it also advertizes that you could do slides but I don't see any information about those. Please inform me of that process. Thanks Barbara
Hello Barbara,
I think you've come to the wrong place, this is a general advice website. Not specific to any manufacturer. Just a load of people trying to help you out.
I can offer a couple of tips though.
It looks like you're talking about a scanner, if your scanner is designed to scan slides, there should be a small frame, sometimes stored in the lid, which you mount the slides in.
For further advice and/or instruction, its best to go to your manufacturers web site, follow links for support and downloads, entering the model details of your scanner as you go. You should arrive at a page which offers a downloadable user manual for free.
Jul 07, 2010 | Cameras
My Canoscan 8000f now only produces a light green image in preview and scan mode. Have installed/uninstalled many times and this has not solved the problem. Wondering if it could be the lamp (broken?)....
I solved this problem twice with deep cleaning all the glasses and mirrors inside the machine, but not with first try.
Now, I have again the same probleme (after 1 year good working).
i'll try again ....
Apr 09, 2010 | Canon CanoScan 8000F Flatbed Scanner
I have a Halina Digital Photo Frame DPF070B with no instructions. The screen will display only one picture, I have to manually advance to the next photo vs. a slide show functioning automatically. I made...
Go into the folder where the pictures on your memory stick are stored. There should be thumbnails of all of them and you can select anyone with the red border. Select anyone so it shows up in the picture frame. Now press Enter. Five buttons should show up. Press the middle one to start the slide show. Press Esc to stop the slide show. You can also access the tools settings from here to adjust the interval time. Hope this helps.
Aug 15, 2009 | Cameras
How to scan slides with HP 1610
Will you help me help you with a little more information please?
Thanks. When you attempt a scan with your backlight setup are you able to instruct the scanner through its settings and options that you are using a transparency backlight at 6300K? If these options are there, what light temperature options do you have besides 6300 or is that the only one. And are your slides in standard tray or in a plastic jacket? A standard tray is a clamshell device where you lay your slides in frames and when done close and snap the clamshell closed.
Thanks,
Worldvet
Jan 04, 2009 | HP PSC 1610 All-In-One InkJet Printer
Cant scan 4cm x 4xm slides
The mounted slide scanning option is set for scanning 35mm mounted slides (24mm x 36mm). As far as I know there is no way to change this setting. You may want to try using the film scan option, do a preview scan, and then crop each individual slide for the final scan.
Oct 16, 2008 | Canon MP970 Photo All-In-One InkJet...
Scanned 35mm slide comes out as rectangle with dark edges
I've not ever seen "square" 35mm slides. By definition they are a rectangular positive film in an outer square "mount".
If you have a truly square piece of film then it is not a 35mm slide. You may have to use settings other than those for a 35mm film but these would be I don't know.
When were they taken (approximately)? What brand of film? Are they in a cardboard "mount?
Aug 01, 2008 | Epson Perfection 4490 Office Flatbed...
Glass on sliding door
this is the link to the information http://www.swisco.com/Screen/how-to-repl...
Opening your patio sliding glass door should be an easy task. If your sliding door is giving you a work out every time you open it, most likely it is your rollers that are causing the problem. The rollers are located on the bottom of the sliding door and give the door the ability to slide. Often times they get dirty and wear out, making it difficult to open the door. If you have an older sliding glass door your rollers may have become rusty because sliding door units did not always use stainless steel rollers.
Hiring a professional to replace your rollers could cost you around $100 not including the cost of the replacement parts. Below are detailed steps containing all the information you will need to know to replace your patio sliding glass door rollers yourself.
* Before you start, understand that you need to take the sliding glass door out of its frame to work on the rollers. The sliding glass door is heavy. You may need the assistance of another to help you remove the door.
1) Your patio glass door will have two separate glass units. One unit is the door that you slide and the other unit is stationary. First, stand outside your house and look at your sliding glass door. If the stationary unit is between you and the sliding unit you will most likely have to remove the stationary unit so that you can get to the glass sliding unit.
Before you go through the trouble of removing the stationary unit, first try to go inside your house and see if you can remove the sliding unit. Usually you cannot because there is a lip along the bottom of the patio glass door frame (it keeps moisture out of the house) that prevents the sliding glass door from being removed from the inside.
If the rollers on the bottom of the door are difficult to get over the lip, you can adjust them to help you create more room (go down to step 2). If it is not the rollers but the sliding unit�s frame preventing you from pulling the sliding unit out of the door frame, you are going to need to remove the stationary unit first before you can remove the sliding unit.
To remove the stationary unit, you first need to take out your screen door (if you have one). Lift one end of the screen door frame and use a screwdriver to lift the roller on the bottom of the screen door frame off of the track. Do this to both ends of the screen door and your screen door will pull out of the door frame.
The stationary unit is held in place by a metal piece that runs along the bottom of the track from the corner of the stationary unit to the bottom of the side jamb (there is a chance this piece is missing but if you do have one remove it from the track). After you have removed the metal piece, look for screws holding the stationary unit frame in place. After removing all of the screws try pulling the stationary unit out of the door frame. If you are having trouble pulling out the stationary unit, try placing a screwdriver between the stationary unit�s bottom frame and the track it is resting on. Lift up on the screwdriver while you have a helper pull out the stationary unit from the door frame. Be careful not to use too much force with the screwdriver so that you do not damage the door track.
2) You may need to create more room when you attempt to remove the sliding unit from the door frame. To create more room you can adjust the rollers on the bottom of the sliding unit. By turning the adjusting screws on the rollers clockwise the wheels move up into the sliding unit�s frame giving you more room. The adjusting screws are located either at the bottom of the sliding unit�s frame or in the sides of the frame. There is a chance that there are plugs covering the screws.
After you adjust both rollers (one on each side of the sliding units frame) try to remove the sliding unit from the door frame. If the unit is still getting stuck you may need to get someone to help you. Have your helper lift one side of the unit and pull outwards while you try to pry the other side of the unit over the track.
3) To remove the rollers from most sliding units you need to remove the bottom of the sliding units frame. Most likely the screw that holds the roller in place is the same screw that holds the frame together. Remove the screw from both sides of the unit. Then try to remove the bottom piece of the frame off of the sliding unit; you may need to use a rubber mallet or a piece of wood and tap on the bottom of the frame until it comes off of the sliding unit.
Now that you have removed the bottom of the frame you can take a close look at your patio glass door rollers. Remove one of the rollers and match it up with one of the rollers on this page http://www.swisco.com/page/SI/CTGY/patio...
It is a good idea to replace both sliding door rollers at the same time to prevent extra wear-and-tear to one new roller, which will have to work twice as hard when paired with an older roller.
4) After your new rollers come in, replace your old rollers with the new ones. To make it easier to install the sliding unit back into the door frame, adjust the rollers to be all the way up into the frame. Once you have the sliding unit back in the door frame you can adjust the rollers for optimal performance. Keep adjusting the rollers until the door is sliding back and forth easily
Jun 22, 2008 | 1996 Ford Windstar
Bertini M5 Shuttle
hi I think I could help I bought a bertini shuttle as well if you stand behind the pram on the right run your hand down the right side of the hood there is a push up lever there mine is grey ok you need to push the grey? lever but also on the left and right there is a black lever you must push up al together hope this helps good luck from debbie
Jan 09, 2008 | Bertini M5 - TS City Stroller
Scanning slides and b/w film negatives
have you set the Canon software to Scan Negative/transparency ? I assume you have. Try removing the Software and re installing it. If still in trouble Checkout the Canon website Scanners/Download and see if there is a download or software patch for your model. If all that is to no avail Canon web site Technical Support Team- see what they have to say
May 27, 2007 | Canon CanoScan 8000F Flatbed Scanner
Scanning slides with the Epson Perfection 1250
To be honest, I have no idea of how you were able to scan larger transparencies in the past. The scanner and its software were never designed to do this and there is no workaround.
Feb 04, 2007 | Epson Perfection 1250 Photo Flatbed...
Canon CanoScan 4200F Flatbed Scanner Logo
102 people viewed this question
old marine
old marine
Corne Viljoen
