Question about Samsung CLP 300 Laser Printer
Refusing to take paper
My CLP300 will not take paper from the tray at all. I have checked all rollers I can get to and no joy. As soon as the mechanism moves, and it does attempt to, it stops and says the paper has jammed in the tray.
I've made it accept paper by force feeding it and sometimes it will go but it's more trouble than it's worth. Any ideas (other than "dropping" it outside on the path!!!!)
  • 5 more comments
  • jon_fitness Feb 19, 2009
    Using two methods seen on this site, I seem to have got the thing to print.
    1. Clean the central take up roller with WD40
    2. The tray seems a sloppy fit in the printer and hangs down slightly.Place the printer on a flat surface and place a small prop under the front edge of the paper tray to lift it up.
    Seems to be ok now.
    Thank you to those who have posted advice.
  • Anonymous Mar 03, 2009
    I have the same problem and try those methods, but could not make the printer to take the paper.
    I have the same problem too. It warms up and runs for a few minutes then delays and restarts, just when it is about to take the paper it jams and the red light comes on. This has been going on since I got it. Usually it will clear with a few tries. Now it has taken 10 -15 cycles to get it to work. Then it works for a while. There is definitely a mfr defect on this product. I am getting very close to just giving up on this piece of junk. It is sad because other than that it is a good printer. I dread the idea of getting another inkjet, but can't afford another laser now.
  • enigma8 Mar 15, 2009
    Yep, same problem, same disasterous results. And yes the same wondering when some wonderful genius will post the answer miraculously before we log off our pc's with absolute disgust for technology.And yes still cursing silently to oneself "thought you could save yourself the aggrevation with not having to buy $50.00 in ink every month to print maybe 10 sheets of nothing important until you need one sheet of last minute necessity to find you need to spend an extra 50 a week later because someone touched your tempermental printer and you vowed that te laserjet was your only hope for printer redemption." Still depressed and still no answers.
  • enigma8 Mar 17, 2009
    I tried that and it didn't work. I also tried elevating it in the front, cleaned the roller, no paper anywhere in there. I guess I should send it back, if no one has a solution.
  • idiocrat Apr 01, 2009
    At the far end of the paper tray on the sides are two catches that restrain the spring loaded flap under the the leading edge of the paper stack. It sure looks like the are supposed to be released when the tray is fully inserted since there is mechansim on both sides to reengage them when the tray is pulled out. On my printer they never seem to release upon insertion which I assume is why my printer can't pick up a sheet to print on.
  • robtom2 Apr 02, 2009
    My printer started doing the SAME thing today. Will not pickup paper no matter what. Maybe the printer is a dud. It was cheap and nasty but the toner cartridges keep me broke!
Someone suggested to empty the gray toner waste container located on the left side of the printer next to the cartridges. Be careful when emptying this as toner can make a real mess. Clean up with toilet paper or paper towel - not water!
Easy fix and this fixed mine like a charm. No need to send the unit in!
Posted on Mar 16, 2009
Samsung CLP-300 Paper jam issue. Cleaning the waste toner container fixed this issue for me also! Yay.
Posted on Mar 18, 2009
    Problem Solver:
  • 13 Answers
Lift up the front of the printer a few inches at each corner. Paper will slide beautifully into the rollers.
Richard
Posted on May 25, 2009
Virtually refuses to print CD's. Have re-whitened the blocks on the CD tray and still refuses, just "jams" every time
You will need to check the rollers insiode the printer and the full printer path, cd paper is thicker than standard paper and will take less to block it, also look for stickyness on the print rollers
May 10, 2011 | Epson STYLUS R230 InkJet Photo Printer
MY SAMSUNG PRINTER CLP300 IS NOT LOADING THE PAPER AT THE TIME TO PRINT HOW CAN I RESOLVE THE PROBLEM?
Remove the paper tray. Lift the printer and you have to see paper feed roller it is rubber, just clean of dirt with cloth and alcohol or water.
Feb 13, 2011 | Samsung CLP 300 Laser Printer
Printer does not pick up paper
Good day keefer, maybe you have a technical problem with your printer. It seems that the feeder parts inside your printer needs for repair. You can go to your nearest technician in your area to solve it for you.
Hope this help.
Dec 18, 2009 | Samsung CLP 300 Laser Printer
My Samsung CLP300 has a paper feed problem. When
Lift up the front of your machine about 4 inches with a book.
The paper will now feed easier.
Richard
Oct 27, 2009 | Samsung CLP 300 Laser Printer
Getting u6-00 on arc172 checked all conectors switched m/c off/on no joy
the error code is for paper miss feed or tray not set properly make sure you have the paper cassette is put in properly and that the paper guide plates at the sides of the paper are set properly and the guide at the back is holding paper in tray correctly o-pen the paper tray take it out and check this and then reset open the side door and close it correctly and this should help reset youcan check the paper feed rollers as well as sometimes they get dirty and will not feed properly you can clean these with a little glass cleaner and a soft cloth good luck A
Jun 28, 2009 | Sharp Office Equipment & Supplies
Paper will not feed
Check if a piece of paper is still left from the paper jam. Sometimes pieces of paper get stuck behind the feeder roller if the paper is torn while removing the jammed paper
May 23, 2009 | Samsung CLP 300 Laser Printer
Printing problem with HP Laserjet P2015 printer
This can be an issue with one of the faulty sensor across the printer.
Please check if you are able to print from tray 1, e.g. a configuration page.
A config page can be printed by holding the Green Button and releasing it as soon as the Triangle light comes on. This would take approx 5 secs.
If the printer is able to print from tray 1, then it could be an issue with the tray 2 pickup sensor.
Check if the tray 2 pickup sensor ( a black plastic piece to the right of the tray 2 pickup roller) is moving freely (front and back), also check if tray 2 pickup roller is not able to rotate completely.
If the tray 2 sensor is not moving freely and of the pickup roller is rotating completely, then reseat the pickup roller.
Normal use with good media causes wear resulting in the need to periodically clean or replace the pickup roller. Additionally, the use of poor media might require more frequent replacement of the pickup roller. Replacing the pickup roller Complete the following to replace the pickup roller:
CAUTION: Failure to complete this procedure might damage the printer. Unplug the power cord from the printer, and allow the printer to cool.
Figure 1: Unplugging the power cord
mma01_13245_0
2. Open the print cartridge door, and remove the print cartridge.
Figure 2: Removing the print cartridge
mma01_13246_0
3. Remove the main input tray (Tray 2).
Figure 3: Removing the main input tray (tray 2)
mma01_13247_0
4. Open the front automatic two-sided path door (HP LaserJet 1320 series printer only).
Figure 4: Opening automatic two-sided path door
mma01_13248_0
5.Place the printer on the work surface with the front of the printer facing up.
Figure 5: Placement of printer
mma01_13249_0
6. Pull the white tabs outward, and rotate the tabs up.
Figure 6: White tabs
mma01_13250_0
7. Slide the right tab to the right, and leave the tab in this position throughout the procedure.
Figure 7: Right tab movement
mma01_13251_0
8. Slide the pickup roller assembly to the right, and remove the left end cap.
Figure 8: Pickup roller assembly movement
mma01_13252_0
9. Remove the pickup roller.
Figure 9: Pickup roller
mma01_13253_0
10. Insert the left side of the new pickup roller into the left slot (1), and insert the right side (with notches in the shaft) into the right slot (2).
mma01_13254_0
11. Rotate the shaft until the notches engage and the shaft clicks into place. 12.Place the end cap over the shaft on the left side, push the end cap to the right, and rotate the tab downward into position.
Figure 11: Pickup roller end cap
mma01_13255_0
13.Push the right tab to the left, and rotate the tab downward into position. 14.Place the printer on the work surface with the top of the printer facing up. 15.Close the front automatic two-sided path door.
Figure 12: Closed automatic two-sided path door
mma01_13256_0
16.Reinstall the print cartridge, and close the print cartridge door.
Figure 13: Print cartridge
mma01_13257_0
17.Plug the printer in to turn it back on.
Figure 14: Power cord in
mma01_13258_0
Cleaning the pickup roller
Perform the following to clean the pickup roller.
1.Remove the pickup roller as described in steps 1 through 9 of Replacing the pickup roller above.
2. Dab a lint-free cloth in water, and scrub the roller.
mma01_13259_0
Figure 15: Scrubbing the roller
3. Using a dry, lint-free cloth, wipe the pickup roller to remove loosened dirt. Figure 16: Wiping the pickup roller
mma01_13260_0
4. Allow the pickup roller to dry completely before you reinstall it in the printer (see steps 10 through 17 of Section with a task ).
mma01_13261_0
Figure 17: Reinstalling the pickup roller
Oct 27, 2008 | HP LaserJet P2015dn Printer
Paper not grabbing
There are two possible solutions for this problem.
Usually it is due to the pickup roller wearing or becoming contaminated with toner or paper dust.
Simple solution, clean the pickup roller, the best thing for this is WD40, put a very small amount on a clean cloth and wipe the roller underneath the printer. Use a clean dry piece of cloth to wipe off any residue.
More complicated solution, remove the roller and reposition, you will need two small flat-bladed screwdrivers to pry apart the retaining clips, remove the roller, a tight squeeze beneath the laser housing, reposition and clean as above then refit the roller. You should find that the paper is picked up cleanly once again.
I hope this helps,
Jan 18, 2008 | Samsung CLP 300 Laser Printer
Samsung CLP 300 Laser Printer Logo
496 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
